Results 1 to 2 of 2
    V1 replacement axle help!
    Hey, I have a v1 spitfire and am in need of a replacement axle due to serious wear. The play in the rear end is quite ridiculous. Does anyone know of where i could locate one? I've contacted Banshee directly and they were no help as well as the local distributor.
    Where are you located? Your local distributor should have stock of axles. If they don't then I'd like to talk with them to help resolve this for you.
    Banshee Bikes Designer
    Banshee Blog
  1. Replies: 5
    Last Post: 03-15-2015, 03:06 AM
  2. Lost my Fox 15mm QR thru-axle - replacement?
    By spartticus in forum Shocks and Suspension
    Last Post: 01-30-2013, 07:30 AM
  3. 12mm x 142+ thru-axle hub replacement
    By jmang in forum Specialized
    Last Post: 09-06-2012, 08:05 AM
  4. Pure XCR Axle Replacement
    By biga6462 in forum Wheels and Tires
    Last Post: 07-24-2012, 08:28 AM
  5. Tips For Shimano B-Axle Assembly Replacement
    By ryanstrive in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-16-2012, 08:43 AM
