Results 1 to 3 of 3
    No Clue Crew
    Apr 2005
    Update: Phantom with Avalanche-tuned RP23
    I bought my Phantom used and it came with two shocks: an older Fox RP23 and a very basic Rockshox Monarch R. I've been running the Monarch and am absolutely in love with this bike.
    In the meantime, I spent some time talking to Craig at Avalanche Engineering. I'd previously had him do a custom tune for a shock on an older Bronson and was incredibly impressed. He said he could get better results using the Fox, so I sent that in and waited (Craig is kind of a one-man shop as I understand it, and his turnaround time is typically 3-4 weeks).
    Got it back Thursday, installed with new Enduro bearings on Friday and took it out for a shakedown at Phoenix Mountain Preserves this morning.
    In a word: Incredible.
    In more words: I won't pretend to understand the mechanics of the tune. It's the SSD tune customized to my specs (185 pounds, proficient technical rider, in Arizona gnar). The RP23 has a two-position switch, to the right (as you look down from the saddle) is fully open; to the left is the compression side which has a dial with three compression options, 1-2-3.
    Today, I rode on Compression 1, which is kind of the "recommended" setting. 155psi gave me about 30% sag. The route I rode to test is the "Too Stupid to Live" time trial. Begins with a pretty big climb, mildly technical with a hike-a-bike portion at the top. On Strava, it's a category 4 climb.
    I wanted to get a full ride in without fiddling with the shock. I've put a few miles in on my SS this week, too, so my legs weren't really fresh. To be honest, the shock felt incredibly sensitive but a little soft despite having the sag I typically run. That said, I PR'd the climb and felt super-fresh at the top; to be clear, although I only starting using Strava as a training tool recently, I've been doing this climb for years.
    The downhill portion starts extremely steep, loose rocks and a bunch of tight turns (the Upper Cheesegrater trail for Phx locals). This is slow, rock crawling stuff that transitioning into a smoother, more high-speed portion and finishing with a much more buff, very fast section with a good series of high-speed drops.
    On the DH stuff, this shock is pure butter. I mean, the Phantom already uses its short travel very efficiently. This takes it over the top.
    I need to do some front/back tweaking, particularly with rebound speeds. The rear is now making the Pike feel a little overwhelmed.
    This was $200 very well spent IMO.
    IMG_0883 by dbozman1173, on Flickr
    Reputation: Adim_X's Avatar
    Glad to hear this. I just bought the tuning package and will be sending in my rp23 off my sc tallboy. It was squishy and lost nitrogen. Hoping it revitalizes the frame a bit, the shocks been clapped out for a while.
    No Clue Crew
    Apr 2005
    It'll be great on the SC; I ran multiple shocks on my Bronson and the Avy-tuned CTD was far and away the best, blowing the CCDB-A out of the water on that particular bike.
    For my second ride, I pumped the air pressure up to 160 and it had a mild negative effect on overall ride quality. I'll drop back down 5 psi and call it good.
  1. Replies: 0
    Last Post: 1 Week Ago, 01:38 PM
  2. RP23 CTD - Push vs. Avalanche
    By bikerx40 in forum Shocks and Suspension
    Last Post: 05-08-2014, 09:29 PM
  3. Avalanche SSD HSB For RP23?
    By keen in forum Shocks and Suspension
    Last Post: 12-22-2013, 06:20 PM
  4. Replies: 1
    Last Post: 05-28-2012, 02:41 PM
  5. Epiphany custom tuned Fox RP23
    By alanjp in forum Ellsworth
    Last Post: 03-10-2011, 06:22 PM
