Results 1 to 5 of 5
    Jan 2009
    Tallest fork on a spitfire V2 and ride qaulity
    Looking for input from anyone that has ridden a taller/more travle fork on the v2 spit. Something like 170mm??
    asking cause two forks Im looking at MRP stage and Manitou Mattoc adjustable to 170mm and just curious how the bike rides with a taller fork.
    Hard funkin´ Kraut
    Reputation: NoStyle's Avatar
    May 2005
    As far as I know Banshee "allows" only for 140 to 160 mm Fork (with internal/external Headset) on the V2 Spitfire. A taller Fork is going to affect Warranty ...
    Maybe it depends on the maximum A-to-C-heigth ...
    I have test-ridden the Spitfire v2 with a Fox Float 34 27,5 160mm, which is 555m A-C, the same a-c a Float 170mm 26 would have. I like the feeling of the bike a lot and am planning to build up the bike with a 180mm FLoat, reduced to 170mm to reach the A-C 555mm.
    The A-C for a 170mm 26 Float is just 10mm above the recommended A-C, for which banshee reports geometry, so I would think it is within tolerance what the frame can take. Ihave not found any infor on this topic on the Banshee webpage (fork height restriction).
    MTB B'dos
    Reputation: LyNx's Avatar
    Have to ask the WHY? If you want that much travel and/or to slack it out that much, then sounds like a Rune is the better choice
    Hard funkin´ Kraut
    May 2005
    Same here. I´m riding a BOS Deville 160 mm travel 26"-Fork with 650B-Wheels (A-to-C 545 mm), ZS-Angleset and the Geometry (neutral Flip-Chips) feels damn perfect for my terrain. Wouldn´t like it higher up front or need more travel.
    If I were you I would ask Banshee what´s the maximum A-to-C-heigth for the Spitfire ...
  1. Rigid steel fork with tallest axle-crown length?
    By dragbike in forum 29er Components
    Last Post: 06-03-2012, 06:17 PM
  2. Help for UK Spitfire fork choice
    By duckcm18 in forum Banshee Bikes
    Last Post: 08-09-2011, 05:25 PM
  3. 180mm fork on a spitfire
    By mzorich in forum Banshee Bikes
    Last Post: 06-22-2011, 10:36 AM
  4. Sag on Fork on your Spitfire
    By horriefic in forum Banshee Bikes
    Last Post: 04-13-2011, 08:27 AM
  5. Spitfire Fork Decisions
    By stunzeed in forum Banshee Bikes
    Last Post: 04-10-2011, 10:48 PM
