Results 1 to 16 of 16
    Reputation: helimech's Avatar
    Mar 2006
    Spitfire - zero stack headset
    Quick question. Does anyone know the inside diameter's of the Spitfires headtube? I know its tappered, just trying to find the right ZeroStack headset for the upper and lower. Looking at Canecreek's web site and getting a little confused. Thanks .
    SHITBIRD
    Reputation: dunerinaz's Avatar
    You need a ZS44 top and ZS49 for the lower. The inner diameter of the lower depends on whether you're using a straight 1 1/8" or tapered steerer.
    "Don't feel bad. A lot of people have no talent"
    Mar 2006
    Thanks for the help. Looked over the geo chart again and found the inner dimentions. I'm limited by having a tapered steer tube. So no zero stack will fit a 49 inner dia tube, have to go with a traditional lower.
    SHITBIRD
    Cannonball!
    Reputation: coiler-d's Avatar
    Sep 2004
    FSA makes a cheap flush headset that allows for a tapered steerer to be used with the Spitfire, but you will need something else for the upper, as it is made for a straight 1 1/2 steerer and 49mm straight head tube. It's an open bearing design but it worked alright for me.
    Mar 2006
    Thanks coiler. I looked thru FSA tech data sheet for all the internal headsets. I found the 1.5 cups, but all the bearings are set for a 11/8 steerer. Would you happen to have a link for this lower your talking about? Thanks.
    SHITBIRD
    Mar 2006
    Got it: its the Gravity 2 = Lower cup is 49.5 inside dia. with a crown of 39.8. Sweet.
    SHITBIRD
    Cannonball!
    Sep 2004
    This is the one I used:
    Universal Cycles -- FSA Orbit E Headset
    one love
    Reputation: Ghea714's Avatar
    Dec 2008
    So i can run my Tapered steerer in my tapered headtube with this Lower?
    Cannonball!
    Sep 2004
    Yep, and that headset will come with two sets of bearings and seals, you will only be able to use the lower set, so you'll have spares! On mine, the caged bearing in the lower out lasted two Cane Creek cartridge bearings in the upper!
    Mar 2006
    Thanks. Got the FSA 1.5 Orbitz E coming and a Cane Creek 11/8 zero stack for the upper. Can't wait to ride this new to me spitfire.
    SHITBIRD
    one love
    Dec 2008
    As Mr Burns would say....."eeexcelent"
    Klunkin' Ain't Easy.
    Reputation: sjordan72's Avatar
    Jan 2005
    Interesting. No problems with the ball bearings? I'm running the CC external because I like angular contact bearings but its pretty tall with the Fox 36 fork I'm running.
    Obviously, you're not a golfer.
    Cannonball!
    Sep 2004
    No problems with the balls. Believe it or not I really felt like, when I had a 36 with external cup, I was having to work at keeping the front end down, but with flush headset not so much. I started with an older 36 TALAS with straight steerer and flush cups, then went to tapered steerer and external cup. It didn't make it unrideable, but I just felt like I was having to concentrate more than I wanted to keep the front end down at times. I then found the FSA and went back to flush and it was spot on!
    Jan 2005
    Cool! Good info! Thanks. I tend to run the bike in the slack setting too, so having the ZS lower should help. I don't have too much wander up front but it may help plant the front a bit more.
    Powered by ice cream.
    Reputation: Enel's Avatar
    Quote Originally Posted by helimech View Post
    Doooode you got a Spitfire!
    I want to check it out!
    Did it replace the Gonad?
    Mar 2006
    Quote Originally Posted by Enel View Post
    Sure you can! Will finish building it up this weekend? Nope, still have the gonad. Looking for a little lighter bike. Also looking FWD to riding the Dells with it and checking out this slack head angle. .
    SHITBIRD
  1. Zero Stack & Trad Mix Headsets for Spitfire
    By stunzeed in forum Banshee Bikes
    Last Post: 04-08-2011, 11:54 AM
  2. Headset for the Spitfire
    By Pandora's Box in forum Banshee Bikes
    Last Post: 04-08-2011, 10:03 AM
  3. Would this headset fit the Spitfire?
    By juanbeegas in forum Banshee Bikes
    Last Post: 09-22-2010, 10:09 PM
  4. Replies: 5
    Last Post: 08-21-2010, 06:32 AM
  5. Headset for Bottlerocket: Zero-stack or non-zero stack?
    By FlippinSweet in forum Transition Bikes
    Last Post: 08-05-2008, 03:25 AM
