Results 1 to 7 of 7
    Spitfire V2 front derailleur?
    Hi,
    Building up new Spitty V2s for me and my girlfriend and ran into some clearance issues with a Shimano XT E-type front mech. The rear of the cage has to be sanded down a couple of mm's to clear the upright on the swingarm it seems.
    Can anybody tell me any front deraillers that fit without modification? Thinking of getting one for myself as well (currently on 1x9). Prefferably in the X7-X9 / SLX-XT range.
    Swedish trail/AM/Enduro/DH-rider - Currently rides Spitfire V2 & Devinci Wilson SL. Spending the summer 2013 in Whistler, BC.
    I too had to sand down my 3x10 front XT derailleur to clear the frame. I just bought an XT 2x10 front derailleur that fits without modification. Unfortunately my chain keeps derailling to the outside because the cage doesn't sit close enough to the crank. I would go with SRAM for a closer fit.
    Feb 2012
    Re: Spitfire V2 front derailleur?
    Quote Originally Posted by Professional View Post
    Did you switch to the 2x specific cranks?
    Banshee recommends SRAM front derailleurs due to their more compact design eliminating frame clearance issues.
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
    Reputation: theraggyone's Avatar
    Jun 2013
    im using a sram x7 low direct mount s3 with no clearance issues whatsoever it also sits really close to my 36t ring as its 36t specific the rest of my drive train is SLX though as I much prefer shimano to sram
    SLX M675 E2 works without any issues or mods
    (2x10 derailleur which I use for my older 2x9 btw)
    Quote Originally Posted by builttoride View Post
    Thanks for the clarification and input guys.
    Can anybody tell me which SRAM front derailler to buy to run 22/32t? A double or a triple? Most front deraillers seem optimized for bigger rings.
  1. 3x9 front derailleur on a 3x8 setup (to solve rockhopper 29 front shift issues)
    By samandkimberly in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-15-2013, 04:37 AM
  2. Spitfire & Rune Front derailleur compatability
    By Professional in forum Banshee Bikes
    Last Post: 04-27-2013, 02:54 PM
  3. will 2x10 shimano m980 xtr front shifter work with sram xx front derailleur?
    By gideon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-01-2012, 06:28 AM
  4. spitfire front derailleur cable??
    By PSI in forum Banshee Bikes
    Last Post: 09-21-2011, 11:33 PM
  5. Front der for Spitfire and seatpost setback?
    By Gman086 in forum Banshee Bikes
    Last Post: 07-01-2011, 03:16 PM
