Results 1 to 10 of 10
    Reputation: Haus Boss's Avatar
    Jun 2010
    Spitfire v2 and fox float ctd spacer kit
    I'm coming off a rune v2 with a dbair, and now ride a spitfire with a fox float ctd and pike up front. I had difficulty bottoming out the rune, and I'd guess I was left with a good 20-30 mm of travel to spare on most of my rides, and it still felt super plush. I'm having quite the opposite issue on my spitfire. I easily get full travel on medium size hits, and I can even bottom it out bunny hopping in the parking lot. I weight approx 170lb, and I've increased the psi to around 180, but still not much change. I guess since we're talking about a fox product I shouldn't be surprised at the lack of mid-stroke support. I'm wondering if anyone else has tried the fox spacer kit and what the result was.
    Reputation: jlf.ski.bike.sail's Avatar
    i had mine pushed and it made a big difference in mid-stroke support. I would think a spacer kit would help.....or just get a float x...
    Ride fast. Take chances.
    www.stinride.com
    Oct 2013
    I had the same problem and simply added a few cc's of float fluid at a time until I had the spring rate where I wanted it. Really should get the spacer kit, but hey it worked.
    Jun 2010
    Float x, yah right. Fox pretty much reaffirmed they produce sub-par products at above avg msrp!!
    Mr. Knowitall
    Reputation: hssp's Avatar
    Send it to Avalanche for the AVA experience. Best upgrade I made to my Lyrik, and everything is better than Float. It doesn't do it for harder riding!!
    I added the smallest spacer and it fixed my bottom out issue. I weigh 200 lb and run it at 160 psi I think. I might still go the avalanche way in the near future.
    Reputation: dirtrider76's Avatar
    Sep 2012
    Was there any spacers in it before?
    Quote Originally Posted by cooldaddy View Post
    I like to fart when I'm in front of you on a climb
    No, I added the smallest. Might try a larger one soon and see what it does with what I expect will be lower pressure. Once winter is done.
    I got mine pushed and still run the largest spacer. I find that the largest spacer livens up the rear end a bit. So far getting it pushed was worth it.
    Jun 2013
    Quote Originally Posted by dirtrider76 View Post
    I see this has your wheels turning too......... Think I'm going to order a set of spacers up.
    14 Banshee Spitfire 27.5
    15 Transition TA29
  1. Fox float volume spacer kit
    By trap121 in forum Shocks and Suspension
    Last Post: 02-23-2015, 04:51 AM
  2. Should I consider a Fox Air Volume Spacer? Float CTD
    By yboc in forum Shocks and Suspension
    Last Post: 04-20-2013, 04:41 PM
  3. Fox Float Air-Volume Spacer Kit
    By mountainbiker24 in forum Shocks and Suspension
    Last Post: 09-09-2012, 06:01 PM
  4. 2013 Fox Float 34 spacer kits?
    By maynard in forum Shocks and Suspension
    Last Post: 07-09-2012, 12:35 PM
  5. fox float volume spacer kit ?
    By keen in forum Shocks and Suspension
    Last Post: 11-21-2011, 09:26 AM
