Results 1 to 9 of 9
    Spitfire & Rune Front derailleur compatability
    I'm building up a V2 spitfire, and I want to make sure I get the right front derailleur. I remember reading somewhere that Keith recommends SRAM over shimano, but has anyone had luck with SLX or XT? I have a 2x9 shimano setup, so not only do I have to deal with the derailleur clearing the frame, but also a 10 and 9 speed compatibility. Is anyone else in this situation. Having spent all my money on the frame, I'd like to not have to pop for XTR or XO.
    I got a Shimano SLX M675 E2-type 10 speed front derailleur for my Shimano XTR/XT 2x9 set-up on my Spitfire V2 and it works perfectly. I run 34 / 22 rings up front.
    thanks, thats great info
    Hard funkin´ Kraut
    Reputation: NoStyle's Avatar
    May 2005
    You can use the 2-Speed Front-Derailleurs (2x10) for 2x9 without any Trouble, they´re compatible.
    I have a SRAM X0 2-Speed Front-Derailleur (2x10) which works great for my 2x9 XT-Drivetrain. I know about Riders with Shimano XT Front-Derailleur and the only Thing they do is mounting it as high as possible to have maximum Clearance.
    There were some Clearance-Issues with SLX. I would go with XT or SRAM X9/X0 ...
    Reputation: el_guillyt's Avatar
    Mar 2013
    Quote Originally Posted by cooldaddy View Post
    I'm on the same config on the rune, and fitted as low as possible and no issues at all
    Quote Originally Posted by el_guillyt View Post
    that's how I have the SLX bolted on.
    Calm like a Bomb
    Reputation: stunzeed's Avatar
    Does anyone know the model # for the compatible XT front derailleur for the rune v2?
    DBY
    DBY is offline
    Quote Originally Posted by stunzeed View Post
    does anyone know the model # for the compatible xt front derailleur for the rune v2?
    fd-m785-e2
    Jun 2012
    Anyone running a FD-M785-E2 with a 3x XT M770 shifter? Do you get a lot of chain rub with a fatter 9 speed chain?
  1. V2 Dilemma - Spitfire or Rune??
    By dirtysurfer in forum Banshee Bikes
    Last Post: 04-03-2015, 10:27 AM
  2. Where are the bearings on the new rune and spitfire?
    By dansMTB in forum Banshee Bikes
    Last Post: 01-20-2013, 05:34 PM
  3. Replies: 20
    Last Post: 10-02-2011, 10:54 AM
  4. spitfire front derailleur cable??
    By PSI in forum Banshee Bikes
    Last Post: 09-21-2011, 11:33 PM
  5. Help me decide - Rune or Spitfire
    By uzurpator in forum Banshee Bikes
    Last Post: 04-26-2011, 04:01 PM
