Results 1 to 6 of 6
    PSI
    PSI is offline
    I want that one
    Reputation: PSI's Avatar
    Mar 2005
    New question here. spitfire front derailleur cable??
    hi
    my front derailleur outer cable keeps "blowing up" and of course i keep loosing use of the front derailleur... seems like its under an abnormal amount of pressure when shifting. I've tried a few different derailleurs,both low and hi, and shifters but still no joy.
    my frame is a proto but judging from the pics of production frames its the same routing... any help?
    thanks, peter.
    p.s. im using shimano 9 speed shifters/derailleurs with plain old shimano outer housings and it happens with both plastic and metal housing ends.
    i would guess this is a routing issue rather than a frame issue...
    Reputation: Gman086's Avatar
    You need a lot of slack to prevent that when your bars get twisted in a crash. You need to allow enough slack so you can rotate your bars 180 deg without binding that cable. This will leave a little loop down by the bottom bracket (which I wasn't very keen on when I first did it but I've had no problems with snagging it).
    Have FUN!
    G MAN
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
    or even better, take it as a sign, grow some balls and go 1x9/1x10....
    PSI
    PSI is offline
    I want that one
    Mar 2005
    Quote Originally Posted by Gman086 View Post
    Have FUN!
    G MAN
    seemed plenty long but ill try your advise... thanks
    PSI
    PSI is offline
    I want that one
    Mar 2005
    Quote Originally Posted by MalcolmX View Post
    for nothing other than the purpose of compensating for crotch related inadequacies i could never figure out what the whole 1x fad is all about.... at least for real riding in real terrain
  1. '05 Hardrock Front Derailleur Cable
    By dok1313 in forum Specialized
    Last Post: 10-09-2010, 07:14 AM
  2. spitfire front derailleur
    By sanjosedre in forum Banshee Bikes
    Last Post: 02-23-2010, 09:03 AM
  3. Need Front Derailleur cable help!
    By esim300380 in forum Specialized
    Last Post: 08-09-2008, 07:30 AM
  4. new front derailleur cable
    By gold3nrul3 in forum Downhill - Freeride
    Last Post: 07-26-2006, 04:51 PM
