Results 1 to 17 of 17
    Short Cage D on Spitfire
    Just got my new Spitfire frame. I normally run a short cage 10 speed rear D on my AM bikes. Anybody know if I am going to run into troubles with chain growth?
    Medium cage front derailleur is a much safer bet.
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
    I rode a short cage X9 on 1 x 9 setup 32T front 11-34 cassette and it did not work. I removed the shock, cycle the suspension and everything was looking ok but on the trails it failed. As soon as I pedaled when the suspension was compressed the derailleur hanger broke.
    one love
    Reputation: Ghea714's Avatar
    Dec 2008
    Thanks for this info Lefty...almost bought a shorty the other day to try it. Ill stick with the medium cage.
    Reputation: JustMtnB44's Avatar
    I also tried a 1x9 setup with short cage Sram X.9 derailleur with 11-34 cassette and 32T front ring on my Spitfire when I first got it and it did not work. To have enough chain slack with the suspension fully compressed, there was not enough tension in the highest gear. Mid cage X.9 derailleur has been working perfectly though.
    Reputation: juanbeegas's Avatar
    Oct 2007
    I've been running 1x9 on my bike for about a year now, with a short cage derailleur with no problems. None of the issues already mentioned.
    Thanks guys
    Quote Originally Posted by juanbeegas View Post
    What range cassette are you using?
    Gear Whore
    Reputation: mudpuppy's Avatar
    I am running a short cage 11-36 with a 28 granny in the front on my RUNE and it is working fine...I don't know how much different the Spitty is...
    Reputation: Hardtails Are Better's Avatar
    May 2005
    Successfully running a short cage X.9 with an 11-32 cassette and a 32t ring. e.13 LG1+ guide.
    Te mortuo heres tibi sim?
    Yep, ran short cage 9 and 10 speeds, single ring setups, no troubles at all. Don't think it's any issue with a single ring, thoughlikely trouble with a two.
    Oct 2007
    34T front chainring and 11 or 12-34T cassette
    Dec 2010
    38T / 11-32 1x9 no problems with short cage Saint here.
    Sunshine & Slippery Trail
    Reputation: andyb721's Avatar
    I have been running a short cage X9 on my Spitty for 18months now—no issues at all! I currently run it with an 11–34t cassette and a 34t front chainring with guide. Anyone having 'not enough chain' probably set it up incorrectly and had exactly that—not enough chain—nothing to do with the short cage d. I run my chain as short as possible to help minimize chainslap.
    Thanks again, I like the second half of this thread answers better.
    Just gonna have to try it. Beats waiting for new parts.
    Reputation: helimech's Avatar
    Mar 2006
    Running a 32F single and a 32 rear with a short with no problems. Just take the shock off and make sure you have enough chain when fully compressed. Just like what was said above .
    SHITBIRD
    Dec 2010
    With an air shock you don't even need to remove it, just let all the air out and make sure you compress the bottom out elastomer fully.
  1. Shimano long cage rear replaced with short cage. Problems?
    By pfb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-07-2010, 08:06 AM
  2. Hybrid Shimano Mech - XT shadow long cage with 105 or Tiagra short cage????
    By freeride_gear in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-16-2008, 10:05 AM
  3. Convert short cage XTR rear to long cage?
    By lpranal in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-30-2008, 02:15 AM
  4. Replies: 17
    Last Post: 12-07-2006, 01:34 PM
  5. Changing long cage to short cage on an X-9 rr der, + sealed pulleys?
    By SoCalDesertRider in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-02-2005, 09:27 PM
