Results 1 to 6 of 6
    Reputation: Calhoun's Avatar
    Nov 2008
    Scythe: Short Shock or DC w/ Angle Set
    I need some input to help me which direction to go with this.
    Over the winter I want to update some things on my Scythe. The bike was inspiring over the last season, but towards the end I started to wonder about changes. The biggest thing I would like to change is BB height. I ride the bike in the 7" DH or FR settings. The 8" settings make the bike feel too tall.
    Now this was with a Totem up front. So I was thinking of putting a Boxxer with some kind of angle reducing headset (Works, K9) but after reading this, I am conflicted:
    Quote Originally Posted by builttoride View Post
    Another thing to consider for the Scythe is that if you switch to a shorter shock (8.5x2.5") then you get slightly small travel options at 6.4" and 7.3". The less travel it is set up with the lower the BB and the slacker the headangle becomes.... just something I figured you might be interested in potentially.
    This is where I need a geometry lesson. With a 8" fork the BB height increases. Will an angle set bring that back down? Or would I be better off with a shorter shock?
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
    Reputation: Hardtails Are Better's Avatar
    May 2005
    The fork won't make the BB higher. A Totem and a Boxxer, for example, are almost exactly the same height. The angleset will lower it a little but not very much. If lower is what you want the shorter shock is the way to go.
    Here is the chart Keith sent me on the short shock option. Hope this helps.
    Rear Travel Fork Travel Head Angle Seat Angle BB Height
    6.4" FR 7" 65.7 70.7 357mm
    6.4" DH 7" 65.2 70.2 351mm
    6.4" FR 8" 64.7 69.7 363mm
    6.4" DH 8" 64.2 69.2 358mm
    7.3" FR 7" 66.7 71.7 366mm
    7.3" DH 7" 66.2 71.2 360mm
    7.3" FR 8" 65.7 70.7 379mm
    7.3" DH 8" 65.2 70.2 374mm
    Nov 2008
    That chart is exactly what I needed. I put it into excel for easier reading.
    Name:  Screen shot 2012-01-13 at 9.40.50 PM.png
    -cabra cadabra
    Your welcome, I thought it was in excel format when I posted it, weird. Wait you even converted the BB height to US standard, awesome. Thanks for that.
    Nov 2008
    colds14: it was kinda funny that everything was in inches except the BB height. looks like a short shock is the way to go.
    and Hardtails Are Better: you are right the Totem and Boxxer have the same a to c, but according to the geo chart there is a difference. I wonder what a to c measurements were used for this chart.
    edit: site says 570mm
    Scythe: Short Shock or DC w/ Angle Set-screen-shot-2012-01-13-8.05.12-am.png
    -cabra cadabra
  1. Replies: 2
    Last Post: 01-10-2012, 03:53 PM
