Results 1 to 6 of 6
    Feb 2007
    Scythe Geometry???
    I could not understand what is the bb height of the Scythe frame if i have 180 mm fork and 7 inch rear suspension.
    And what will be with 200mm at front and 8 inch rear suspention.
    Any one can help?
    Another question, can I put to chain rings in front so i could pedal with it? how does it pedal in general...currently I have wildcard and love it but i want more suspension.
    Thanks.
    Reputation: juanbeegas's Avatar
    Oct 2007
    It's all there in the geometry chart on the Banshee website. There are two settings for each of the combos you'd like to try out
    and yes, it is front-derailleur compatible. It uses a top pull, high 34.9mm diameter clamp.
    Feb 2007
    What is the difference between travel on the right and rear travel on the left?
    Quote Originally Posted by juanbeegas View Post
    Whats the difference between the travel on the right of the table and the rear travel on the left? the bb heights are different...
    Oct 2007
    0.3" between the 7" settings and 0.6" between the 7" and 6.4" setting.
    Feb 2007
    I don't understand what you mean...
    The fork is the same but the rear if it is 7 inch then it is 7 inch, what do they mean 6.4 or 7.3, how does that change? move of a bolt?
    So I can ride the Scythe with 6.4 rear travel? 7.3? and 8?
    Reputation: Calhoun's Avatar
    Nov 2008
    The chart on the right is if you decide to use a shorter shock.
    Left chart: 8.75x2.75
    Right Chart: 8.5x2.5
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
  1. Slack Ass Scythe
    By Calhoun in forum Banshee Bikes
    Last Post: 03-16-2012, 06:42 PM
  2. Slack Ass Scythe
    By Calhoun in forum Downhill - Freeride
    Last Post: 02-23-2012, 09:54 AM
  3. 2012 Scythe
    Last Post: 11-14-2011, 04:07 AM
  4. New Scythe
    Last Post: 03-08-2011, 05:10 PM
  5. Scythe CCDB?
    Last Post: 01-11-2011, 01:57 PM
