Results 1 to 17 of 17
    RWC needle bearing install on Rune
    Has anyone used installed the needle bearing kit on the rune? I'm have fit issues on the rocker pivot.
    Paste eater
    Reputation: Jwind's Avatar
    Mar 2006
    Huh? Needle bearing kit for the Rune?
    To replace du bushings in the shock.
    Paste eater
    Mar 2006
    Quote Originally Posted by Resnick View Post
    What bearing kit. I am unaware of such a thing?
    REAL WORLD CYCLING AFTERMARKET COMPONENTS, BEARINGS, & SEALS
    Look at needle bearings
    Btw this is not a linkage bushing replacement
    Paste eater
    Mar 2006
    oooooooooooooooh. The shock. All this pivot bushing talk has my mind elsewhere. So, no, I haven't. Sorry, I'm no help.
    Dec 2011
    I just bought 2 of the kits from RWC last week. I'm having them installed on my Rune at the local bike shop. I'll post up after I get my frame and shock back to let you know if there were any fit issues.
    Reputation: Gman086's Avatar
    You DID buy the spacers needed for it to fit, right?
    Have FUN!
    G MAN
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
    Reputation: juanbeegas's Avatar
    Oct 2007
    I have them on my Rampant and Spitfire. They definitely help both bikes be just a little more sensitive on the small bumps. Just a little.
    I bought a custom kit (made in France ) for my Rune and it fit well.
    If the kit is for 8mm axle and 43mm width there's no possible issue.
    is it smaller than the rocker span? theres supposed to be three .5mm spacers on either side(available from RWC) unless they changed it since last year. IMO it didnt make a lot of difference, i think the initial stiction in the bushings overshadows the benefit from removing stiction at the shock mount. On my bearing bikes it makes a more noticeable difference.
    '14 rocky mountain altitude, rally edition
    '11 transition blindside, 650b converted
    I got the shock in and I do notice a difference in a couple really chundery areas around my place.
    as for stiction in the bushings it's none existant in my bike. If you have a Rune get a good (click style) torque wrench when you do your bushing lube check you pivot torque.
    Ive been there and done that, I am all about proper torque. It still did not have the smoothness of bearing bikes, im not saying thats a flaw or anything, just an inherent property of bushings vs. bearings. I was just saying that as far as i can feel, the needle bearing shock mountt makes a bigger difference on my bearing bikes. After i cracked my Rune in 8 months i sold the warranty replacement and moved on to something else, before the pivot wear problems set in.
    Dec 2011
    I just got my frame back from the shop and from what I can tell, there doesn't seem to be any movement around the rocker pivot. The mechanic did say that the install was somewhat tricky although he really didn't say why it was. I still need to assemble the bike, so I guess that will be the real test.
    Sober for now...
    Reputation: bjammin's Avatar
    I just installed the full kit (both eyelets) on my Rune w/ DHX air. Huge difference in small bump but there's the tiniest amount of play at the shock now even with the "+" hardware installed.
    Anyone else notice this?
    Mine has some play when I "twist" the shock, I took a video of it and sent if off to rwc and got this back
    "The twisting action in the video is allowed because the rubber seals contact the shock body. The suspension should impart no force in this direction. As long as the seals contact the shock body and you have no actual space between them, you should be fine. Test by compressing the suspension and lifting up on the seat. If all feels good, give it a test on the trail. Please let me know if you have any issues or concerns after checking it out. Best regards, Chris Streeter"
    I have emailed the guys at RWC a couple times they are great and always get back to me within 12 hours.
