• 10-29-2012
    Danshee
    Cheers NoStyle, I did actually see those posts a few days ago but I couldn't find them just now.
  • 10-29-2012
    bikeman_2
    Originally Posted by NoStyle View Post
    Danshee and uzurpator, please read back one or two pages, because I have asked this question here a few days ago. Keith mentioned that all KS-Link-Bikes do have S3-Directmount-Standard and all SRAM DM-Frontderailleurs do work. Shimano XT does work too, but not the SLX. There will be a list to come when compability is fixed. :thumbsup:
    auch wenn man 9 fach fährt (22-32 vorne und hinten 11-34) bzw. einen 3x9 XT Umwerfer vorne?
    Ich glaube der 3x9 Umwerfer wird an der Schwinge oder Stebe stossen. Muss man halt probieren, wenn der Rahmen da ist.
  • 10-29-2012
    NoStyle
    @ Danshee
    Uhh sorry mate, I have posted this question in the "Spitfire 2013-Thread", not here! :madman:
    @ bikeman_2
    Iīm sorry, but I canīt give really proper Information, especially for Triplering-Setup in Front! Keith used a Shimano XT on his Proto-Spitty and his answer was: XT works, SLX does not. Think he runs Dualring, but I donīt really know. Maybe Keith has some new Information and can chime in according to this again ...
  • 10-29-2012
    builttoride
    I personally would recommend buying a SRAM S3 FD, as they have more clearance than any Shimano offerings we have tested so far. We have tried all 2x10 and 3x10 2012 and SRAM FD's and they all clear, although the 2x10 options have more clearance. That said if you do want Shimano, then the option I'd recommend is the FDM-985-E2.
  • 10-29-2012
    JansonJanson
    it is really good to see that companies care about their customers!
    i also orderd my rune v2, and cant wait to shred it, unfortunally i have to wait for the 2nd batch ...
    hope the decals on the yellow frame is just as awesome, as seen on the exposition pics over the internet!
  • 10-29-2012
    Danshee
    Cheers Keith.
  • 10-29-2012
    grazertourer
    Do you have any experiences with the fd-771-d?
  • 10-29-2012
    bikeman_2
    this one:
    Shimano XT Umwerfer E-Type FD-M770E Dual Pull
  • 10-29-2012
    NoStyle
    Those two are not DM S3!!!
    These ones should work from Shimano:
    XTR FD-M985 2-fach
    XT FD-M785 2-fach Top-Swing
  • 10-29-2012
    Danshee
    There was something waiting for me when I got home today.
    Thanks Keith and Jay!! Stoked!
  • 10-29-2012
    bikeman_2
    XTR FD-M985 2-fach
    The Shimano XT Double Front Derailleur FD-M785 has been designed to optimize its function with two chainrings. To this end, the cage length and shaping is specific to the smaller diameter differential between the big and little rings on a 2x10 DynaSys drivetrain. Whether you run a 26/38t or a 28/42t crank, this is the changer you'll want.
    Same Biker have (like me) 2x9 and wanted to use this.
  • 10-29-2012
    bikeman_2
    And I? UK get the first Frame?! Are you order by Banshee?
  • 10-29-2012
    Danshee
    I ordered a long time ago, directly to Banshee.
  • 10-29-2012
    MalcolmX
    is it a medium?
  • 10-29-2012
    grazertourer
    Nice! :)
    @fd
    Ah! I didn't know that direct mount and e-type without the alloy plate are colmpletely different. Thanks. :)
  • 10-29-2012
    AdrianoMTB
    3 Attachment(s)
    Well... the First RUNE V2 in Europe... SIMPLY SICK!!!!!
  • 10-29-2012
    phat-ant
    Lush! :d
  • 10-29-2012
    elsinore
    Tests?
    Are there any ride reviews of this rig floating around on the web yet?
  • 10-29-2012
    coiler-d
    Wow! weight?
  • 10-29-2012
    jgusta
    Very nice indeed! Medium or large?
  • 10-30-2012
    Mud Pig
    Originally Posted by Haus Boss View Post
    One thing to consider is the reach. The new Rune has a steeper seat angle, but same horizontal TT length. If it were running the old seat tube angle, you end up with a longer horizontal TT. Most bikes that seem to run this type of geo with a steeper seat tube, don't have as long of TTs because the front center (BB to headtube) has actually been lengthened.
    Does that mean I have to move up to a medium? I'm a tweener.
  • 10-30-2012
    Danshee
    Woah, that looks awesome. Unfortunately, I'm not going to be able to finish my build until the weekend. You should start a new thread for the production V2 as you're the first to build one up ;)
  • 10-30-2012
    AdrianoMTB
    Originally Posted by coiler-d View Post
    Wow! weight?
    Right now with the 2ply high roller tire in the rear plus slime tube --> 14,7 kilos (32,4)
    but i will change the rear tire asap (IīLL put the new schwalbe hans dampf super gravity) so the final weight will be 14,2 kilos (31).
    I think itīs a right weight for a very rasonable build...
    Large frame!
    Originally Posted by phat-ant View Post
    Lush! :d
    Ok, thatīs my turn so! ;)
  • 10-30-2012
    coiler-d
    Awesome, can't wait til mine comes in next week.
  • 10-31-2012
    JansonJanson
    @AdrianoMTB - nice build! good to see the first rune v2 built up to life!
    Keith, could you estimate the difference in weight between the anodized and the powder couted oneīs?
  • 10-31-2012
    builttoride
    Ano frames are lightest, compared to ano powdercoat adds maybe 100-150g depending on size, and clearcoated frames add about 150-200g depending on size.
  • 10-31-2012
    kalkhoffpink
    Would also be interesting if the 6.5lbs for a RUNE with M-frame on the banshee homepage is actual???
  • 10-31-2012
    builttoride
    I thinkt hat was for the lighter duty V1, we are in process of updating the website.
  • 10-31-2012
    MalcolmX
    although medium, anno without shock is probably not far away from 6,5#...
  • 10-31-2012
    cave dweller
    Are the "raws" clear coated or polished?
  • 11-01-2012
    Danshee
    They're clear coated.
  • 11-01-2012
    Haus Boss
    If raw is 7.3ish pounds, I'm guessing a medium is around 7. It'll be interesting to see what the posted official weight is. I don't have a problem with the extra few grams if it translates into better longevity/durability.
  • 11-02-2012
    XavM
    Hi,
    I've a bunch of Rune 650b suspension questions:
    1) Does the 650b specific lower link reduce the travel?
    2) Is the CCDB which comes with the frame pretuned for Rune?
    2) What fork w/ travel adjust would you choose for a 650b Rune?
    thanks
  • 11-02-2012
    Haus Boss
    - High quality sealed bearings like the Prime >> CHECK
    - Increased strength (gusseting) around the bottom bracket >> CHECK
    - Slightly longer top tube >> CHECK
    - Replaceable rear dropouts (w/ ability to run multiple rear hub setups) >> CHECK
    - Adjustable geometry like the spitfire >> CHECK
    - 10-15mm more of rear travel >> CHECK
    - Beefed up frame- I honestly don't mind a slightly heavier frame if it means the Rune can be ridden that much harder >> CHECK
    - Carbon offering >> NOPE
    - Shorter Chainstays >> CHECK
    I was just looking at the original post and first few replies of this thread. Not bad Bashee!
  • 11-03-2012
    Gman086
    You forgot slacker HTA's - probably most important change if you ask me. But yeah, Keith nailed it. Now the question is... do I wait for a carbon version? :)
    Cheers,
    G
    PS - This thread has strayed so far off of the original intent (I mean really - who cares what color to choose, lol) maybe we need a new one for just "The new Rune V2!"
  • 11-03-2012
    AdrianoMTB
    Originally Posted by lostboyz View Post
    Will Flips Chips be provided with the frame?
    Yes, are provided.
  • 11-03-2012
    dangerousmav
    So black it's the lightest??
  • 11-09-2012
    BeezKneez
    I got a question regarding available colors for the rune.
    For the first batch there are blue ones.
    Will they remain available for the next batches also?
    There was a statement on an upcoming yellow option.
    Is it the fluorescent one that came on the prototype or more like shown on the renderings of the prime?
    There was a post about all of this somewhere but I can't find it anymore.
    Can you help me out?
  • 11-10-2012
    Gman086
    ENOUGH WITH THE COLORS ALREADY, LOL! How does that even remotely pertain to the thread's initial question??? Start your own "color options" thread!
    Have FUN!
    G MAN
  • 11-10-2012
    uzurpator
    I have a wish for the next Rune to be available in Orange Ano :P
  • 11-10-2012
    builttoride
    Orange ano can't happen I'm afraid. They higher quality alloy we use on our frames means that we only have a small selection of dark ano colours that will work.
  • 11-10-2012
    Nescafe
    root beer
  • 11-10-2012
    JansonJanson
    nice question ...
    Keith is it really fluorescent (like the special m9 colour option) or more an sun bright yellow ?! :D
    sorry for bothering about that!
  • 11-12-2012
    builttoride
    It will be same shade as the proto.
  • 11-17-2012
    gurp
    Will the frame's leverage rate allow the use of a coil shock?
  • 11-17-2012
    kalkhoffpink
    Isnīt it time to close this thread and post every further question in the Rune build thread?
    Wishes for the bike are not longer taken into account anyway - itīs done!....:rolleyes:
  • 11-18-2012
    builttoride
    yes
  • 11-18-2012
    gurp
    yes
    :) Thanks
    Any recommendations? I'm guessing something with an air chamber like an RC4 to provide some ramp up, sent to PUSH to get the valving correct.
  • 12-05-2012
    max.zorro
    builttoride, can you please tell what is bottom bracket rise/drop for Rune V2?
    I'm try to do direct compare with Killer-B... it seems to Killer-B has lower BB height that Rune in low position...
  • 12-05-2012
    builttoride
    BB drop on the rune V2 in low position is -2mm.
  • 12-05-2012
    helidave
    Opps wrong thread:thumbsup:
  • 03-28-2014
    Dirk77
    I'm split between getting a custom tuned Xfusion Vector Air HLR, or the CCDBair. I have the a vector on my wildcard right now, can't imagine a shock being that much better than it...
    Did you go with the Vector HLR?
    Has anyone put a Vector Air hlr on the Rune V2? if so How do you like it?
    Thanks, I know this is an old thread but Im really interested on how the vector air performs on this frame.
