Page 18 of 19 FirstFirst ... 8 14 15 16 17 18 19 LastLast
Results 426 to 450 of 452
  1. #426
    Ano frames are lightest, compared to ano powdercoat adds maybe 100-150g depending on size, and clearcoated frames add about 150-200g depending on size.
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
  2. #427
    Reputation: kalkhoffpink's Avatar
    Quote Originally Posted by JansonJanson View Post
    @AdrianoMTB - nice build! good to see the first rune v2 built up to life!
    Keith, could you estimate the difference in weight between the anodized and the powder couted ones?
    Would also be interesting if the 6.5lbs for a RUNE with M-frame on the banshee homepage is actual???
  3. #428
    I thinkt hat was for the lighter duty V1, we are in process of updating the website.
    Banshee Blog
  4. #429
    although medium, anno without shock is probably not far away from 6,5#...
  5. #430
    Reputation: cave dweller's Avatar
    Feb 2005
    Quote Originally Posted by builttoride View Post
    Are the "raws" clear coated or polished?
  6. #431
    Quote Originally Posted by cave dweller View Post
    They're clear coated.
  7. #432
    Reputation: Haus Boss's Avatar
    Jun 2010
    If raw is 7.3ish pounds, I'm guessing a medium is around 7. It'll be interesting to see what the posted official weight is. I don't have a problem with the extra few grams if it translates into better longevity/durability.
  8. #433
    Hi,
    I've a bunch of Rune 650b suspension questions:
    1) Does the 650b specific lower link reduce the travel?
    2) Is the CCDB which comes with the frame pretuned for Rune?
    2) What fork w/ travel adjust would you choose for a 650b Rune?
    thanks
  9. #434
    Jun 2010
    - High quality sealed bearings like the Prime >> CHECK
    - Increased strength (gusseting) around the bottom bracket >> CHECK
    - Slightly longer top tube >> CHECK
    - Replaceable rear dropouts (w/ ability to run multiple rear hub setups) >> CHECK
    - Adjustable geometry like the spitfire >> CHECK
    - 10-15mm more of rear travel >> CHECK
    - Beefed up frame- I honestly don't mind a slightly heavier frame if it means the Rune can be ridden that much harder >> CHECK
    - Carbon offering >> NOPE
    - Shorter Chainstays >> CHECK
    I was just looking at the original post and first few replies of this thread. Not bad Bashee!
  10. #435
    Reputation: Gman086's Avatar
    You forgot slacker HTA's - probably most important change if you ask me. But yeah, Keith nailed it. Now the question is... do I wait for a carbon version?
    Cheers,
    G
    PS - This thread has strayed so far off of the original intent (I mean really - who cares what color to choose, lol) maybe we need a new one for just "The new Rune V2!"
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
  11. #436
    Quote Originally Posted by lostboyz View Post
    Will Flips Chips be provided with the frame?
    Yes, are provided.
  12. #437
    So black it's the lightest??
  13. #438
    I got a question regarding available colors for the rune.
    For the first batch there are blue ones.
    Will they remain available for the next batches also?
    There was a statement on an upcoming yellow option.
    Is it the fluorescent one that came on the prototype or more like shown on the renderings of the prime?
    There was a post about all of this somewhere but I can't find it anymore.
    Can you help me out?
  14. #439
    ENOUGH WITH THE COLORS ALREADY, LOL! How does that even remotely pertain to the thread's initial question??? Start your own "color options" thread!
    Have FUN!
    G MAN
  15. #440
    Dec 2005
    I have a wish for the next Rune to be available in Orange Ano :P
  16. #441
    Orange ano can't happen I'm afraid. They higher quality alloy we use on our frames means that we only have a small selection of dark ano colours that will work.
    Banshee Blog
  17. #442
    root beer
  18. #443
    Reputation: JansonJanson's Avatar
    Oct 2012
    Quote Originally Posted by BeezKneez View Post
    nice question ...
    Keith is it really fluorescent (like the special m9 colour option) or more an sun bright yellow ?!
    sorry for bothering about that!
    freedom is the ability to go where you want, when u want
  19. #444
    It will be same shade as the proto.
    Banshee Blog
  20. #445
    Will the frame's leverage rate allow the use of a coil shock?
  21. #446
    Isnt it time to close this thread and post every further question in the Rune build thread?
    Wishes for the bike are not longer taken into account anyway - its done!....
  22. #447
    Quote Originally Posted by gurp View Post
    yes
    Banshee Blog
  23. #448
    yes
    Any recommendations? I'm guessing something with an air chamber like an RC4 to provide some ramp up, sent to PUSH to get the valving correct.
  24. #449
    builttoride, can you please tell what is bottom bracket rise/drop for Rune V2?
    I'm try to do direct compare with Killer-B... it seems to Killer-B has lower BB height that Rune in low position...
  25. #450
    BB drop on the rune V2 in low position is -2mm.
    Banshee Blog
  1. GPS wishlist
    By matt_brodie in forum GPS, HRM and Bike Computer
    Last Post: 10-08-2007, 11:54 PM
  2. a wishlist for nino
    By peabody in forum Weight Weenies
    Last Post: 01-31-2007, 07:04 PM
  3. wishlist for HH frames for 05???
    By hammerheadbikes in forum Titus
    Last Post: 05-26-2005, 11:25 AM
  4. Keystone Wishlist
    By ezweave in forum Downhill - Freeride
    Last Post: 09-03-2004, 08:12 AM
  5. Keystone Wishlist
    By ezweave in forum Colorado - Front Range
    Last Post: 09-02-2004, 01:23 PM
