• 10-31-2012
    builttoride
    Ano frames are lightest, compared to ano powdercoat adds maybe 100-150g depending on size, and clearcoated frames add about 150-200g depending on size.
  • 10-31-2012
    kalkhoffpink
    Originally Posted by JansonJanson View Post
    @AdrianoMTB - nice build! good to see the first rune v2 built up to life!
    Keith, could you estimate the difference in weight between the anodized and the powder couted oneīs?
    Would also be interesting if the 6.5lbs for a RUNE with M-frame on the banshee homepage is actual???
  • 10-31-2012
    builttoride
    I thinkt hat was for the lighter duty V1, we are in process of updating the website.
  • 10-31-2012
    MalcolmX
    although medium, anno without shock is probably not far away from 6,5#...
  • 10-31-2012
    cave dweller
    Are the "raws" clear coated or polished?
  • 11-01-2012
    Danshee
    They're clear coated.
  • 11-01-2012
    Haus Boss
    If raw is 7.3ish pounds, I'm guessing a medium is around 7. It'll be interesting to see what the posted official weight is. I don't have a problem with the extra few grams if it translates into better longevity/durability.
  • 11-02-2012
    XavM
    Hi,
    I've a bunch of Rune 650b suspension questions:
    1) Does the 650b specific lower link reduce the travel?
    2) Is the CCDB which comes with the frame pretuned for Rune?
    2) What fork w/ travel adjust would you choose for a 650b Rune?
    thanks
  • 11-02-2012
    Haus Boss
    - High quality sealed bearings like the Prime >> CHECK
    - Increased strength (gusseting) around the bottom bracket >> CHECK
    - Slightly longer top tube >> CHECK
    - Replaceable rear dropouts (w/ ability to run multiple rear hub setups) >> CHECK
    - Adjustable geometry like the spitfire >> CHECK
    - 10-15mm more of rear travel >> CHECK
    - Beefed up frame- I honestly don't mind a slightly heavier frame if it means the Rune can be ridden that much harder >> CHECK
    - Carbon offering >> NOPE
    - Shorter Chainstays >> CHECK
    I was just looking at the original post and first few replies of this thread. Not bad Bashee!
  • 11-03-2012
    Gman086
    You forgot slacker HTA's - probably most important change if you ask me. But yeah, Keith nailed it. Now the question is... do I wait for a carbon version? :)
    Cheers,
    G
    PS - This thread has strayed so far off of the original intent (I mean really - who cares what color to choose, lol) maybe we need a new one for just "The new Rune V2!"
  • 11-03-2012
    AdrianoMTB
    Originally Posted by lostboyz View Post
    Will Flips Chips be provided with the frame?
    Yes, are provided.
  • 11-03-2012
    dangerousmav
    So black it's the lightest??
  • 11-09-2012
    BeezKneez
    I got a question regarding available colors for the rune.
    For the first batch there are blue ones.
    Will they remain available for the next batches also?
    There was a statement on an upcoming yellow option.
    Is it the fluorescent one that came on the prototype or more like shown on the renderings of the prime?
    There was a post about all of this somewhere but I can't find it anymore.
    Can you help me out?
  • 11-10-2012
    Gman086
    ENOUGH WITH THE COLORS ALREADY, LOL! How does that even remotely pertain to the thread's initial question??? Start your own "color options" thread!
    Have FUN!
    G MAN
  • 11-10-2012
    uzurpator
    I have a wish for the next Rune to be available in Orange Ano :P
  • 11-10-2012
    builttoride
    Orange ano can't happen I'm afraid. They higher quality alloy we use on our frames means that we only have a small selection of dark ano colours that will work.
  • 11-10-2012
    Nescafe
    root beer
  • 11-10-2012
    JansonJanson
    nice question ...
    Keith is it really fluorescent (like the special m9 colour option) or more an sun bright yellow ?! :D
    sorry for bothering about that!
  • 11-12-2012
    builttoride
    It will be same shade as the proto.
  • 11-17-2012
    gurp
    Will the frame's leverage rate allow the use of a coil shock?
  • 11-17-2012
    kalkhoffpink
    Isnīt it time to close this thread and post every further question in the Rune build thread?
    Wishes for the bike are not longer taken into account anyway - itīs done!....:rolleyes:
  • 11-18-2012
    builttoride
    yes
  • 11-18-2012
    gurp
    yes
    :) Thanks
    Any recommendations? I'm guessing something with an air chamber like an RC4 to provide some ramp up, sent to PUSH to get the valving correct.
  • 12-05-2012
    max.zorro
    builttoride, can you please tell what is bottom bracket rise/drop for Rune V2?
    I'm try to do direct compare with Killer-B... it seems to Killer-B has lower BB height that Rune in low position...
  • 12-05-2012
    builttoride
    BB drop on the rune V2 in low position is -2mm.
