FAT BIKES
WINTER APPAREL
TRAINERS
Page 13 of 19 FirstFirst ... 3 9 10 11 12 13 14 15 16 17 ... LastLast
Results 301 to 325 of 452
  1. #301
    Quote Originally Posted by builttoride View Post
    The 135x10mm option is the same interface as the old rune and spitfires.
    This actually has nothing to do with what I quoted, i just wanted to get your attention....Seems weird that I get advertisements to buy other bikes on the Banshee site when I click on the video/pictures of the Rune.
  2. #302
    Quote Originally Posted by Mishtar View Post
    Haha, good point. We have an official rune V2 video that will go up shortly so we don't just link to Vital and their various website sponsors.
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
  3. #303
    Good! Not that someone would choose that GT of a Rune or spitfire
  4. #304
    Quote Originally Posted by jgusta View Post
    On the Banshee site with recently added geo specs for the V2 there is a weight listed of 6.5lbs for medium at bottom of spec sheet. I assume that is without shock, so 7.0lbs for medium w/RP23 and like 7.25-7.75lbs for bigger volumed air shocks. I figured a large V2 w/Monarch RC3 plus is going to weigh about 7.5lbs (the same as my large V1 w/ISX Evolver shock).
    That would be a sick weight... I thought it would lean more towards 8,5 lbs in Large with CTD Float because of the bushings...
    Lets see
  5. #305
    Reputation: bikeman_2's Avatar
    Rune V2
    Test!
  6. #306
    Quote Originally Posted by MalcolmX View Post
    Yes, that would be amazing!
  7. #307
    i wonder, which ist the right tune for the vivid air @ Rune V2 ?
  8. #308
    Quote Originally Posted by MR.A View Post
    Regarding its a virtual pivot point and the shock measure its 216x63
    Probably it will fit a MEDIUM tune...
    in fact, Ive got a vivid coil rc2 in M tune waiting to put on my rune when I decide to go to the Bike Parks!!
  9. #309
    Quote Originally Posted by Arl5555en View Post
    I'm also glad to hear there will be no internal cable routing, what a pain in the ass!
    Have you ever changed a shifter without liner? Or changed on a Trail / Holiday-Trip?
    Ridley Noah Internal Cable Routing Solution Video - Part 2 of 2 - YouTube
    Never a internal Cable!!!!!!!!!
  10. #310
    Quote Originally Posted by bikeman_2 View Post
    Haha I regularly have to defend my descision not to go with internal cable routing. I think anyone who has ever had to build or change components (especially hydraulic brakes) on a frame with internal cable routing will fully understand why I avoid it. I'm trying to save Banshee customers time, money and frustration.
    Banshee Blog
  11. #311
    Reputation: Fix the Spade's Avatar
    I've only ever had one frame with good internal cable routing, my Prophet MX, that came with big thick rubber tubes pushed all the way through the swing arm, changing cables on that was a breeze and they silenced any rattles too. All these bikes with tiny plastic grommets are rubbish...
    Good call on using zip-tie saddles throughout Keith, proper full length muck proofing!
  12. #312
    Are there 135X10mm dropouts for 650b wheels?
  13. #313
    Quote Originally Posted by belljeffw View Post
    The 650B dropouts will only come in 142x12mm standard to start with. if demand increases then we may expand the options. Most good hub manufacturers offer conversion kits.
    Banshee Blog
  14. #314
    Just deciding which hubs to use. I have some Hope 2s laying around, but I hate the way they sound ; )
  15. #315
    Oct 2007
    @keith
    would the below shocks work well with the V2 rune?
    - Elka stage 5 with the v1 tune
    - X-fusion vector air HLR
    - Fox DHX air
    What is the current tune settings for the fox CTD shock?
    I was thinking of rebuilding my Elka for the V2 but the local elka representive has zero idea on how to tune it for the V2....
  16. #316
    powered by bacon
    Reputation: helidave's Avatar
    Quote Originally Posted by sxross View Post
    send it to Elka. they can change the valving and length/stroke
  17. #317
    Oct 2007
    Quote Originally Posted by helidave View Post
    The local representative is elka certified and can do all the hardware changes. Problem is they say they have no information on which valving combination to use for the V2.
  18. #318
    powered by bacon
    send keith a pm, he can send them the info.
  19. #319
    Elka have all the leverage info for the new bikes, so your local elka dealer should be able to get it from them. All the mentioned shocks should fit.
    The Fox Float CTD tune is as follows for the Rune V2:
    Boost Valve Pressure 200 PSI
    Valving Assy: 2013 FLOAT CTD BV, VTL, RTM
    Sleeve-Option LV
    Air Volume Space = 0.4
    Kashima Label Gold (Std)
    Banshee Blog
  20. #320
    Reputation: lostboyz's Avatar
    Will Flips Chips be provided with the frame?
    DDKS
  21. #321
    The dropout kits that come with the frames (or separately if you buy a second set aftermarket) will contain bth sets of flip chips.
    Banshee Blog
  22. #322
    biking is fun
    Reputation: climbingbubba's Avatar
    So as far as the black color option. Is that paint or Anodizing? I don't know if this is covered anywhere (but I have looked for a good 30 minutes).
  23. #323
    What would running 650B dropouts with a 26er wheel do to the BB height and CS length?
    Looking very closely at this frame now. Would love to get a raw frame to have it custom painted by Toxik Labs in Vancouver, would Trident be able to get me one?
  24. #324
    Quote Originally Posted by PUNKY View Post
    CS length would be the same as with a 650b wheel, since the axle position is the same. Assuming you used 26 inch wheels on front and back, BB height would be 3/4 inches lower than with 650b wheels.
  25. #325
    Quote Originally Posted by climbingbubba View Post
    Black frames are ano
    Banshee Blog
  1. GPS wishlist
    By matt_brodie in forum GPS, HRM and Bike Computer
    Last Post: 10-09-2007, 12:54 AM
  2. a wishlist for nino
    By peabody in forum Weight Weenies
    Last Post: 01-31-2007, 08:04 PM
  3. wishlist for HH frames for 05???
    By hammerheadbikes in forum Titus
    Last Post: 05-26-2005, 12:25 PM
  4. Keystone Wishlist
    By ezweave in forum Downhill - Freeride
    Last Post: 09-03-2004, 09:12 AM
  5. Keystone Wishlist
    By ezweave in forum Colorado - Front Range
    Last Post: 09-02-2004, 02:23 PM
Follow MTBR on Facebook
