Results 1 to 2 of 2
    Mar 2012
    Rune V2 pivot bearing loose in frame
    Hi,
    My rune is making an annoying creak which I've tracked down to one of the upper pivot bearings which although 'snug' can be pushed out the rear triangle by hand. So I think it is the outer race moving slightly in the frame that is making the creak. Figured loctite was the stuff to use to fix it......if so, then what do folk use?
    Cheers
    Dave
    Reputation: qbert2000's Avatar
  1. JET 9 RDO - Loose frame insert (pivot mount)
    By xcbarny in forum Niner Bikes
    Last Post: 3 Days Ago, 09:32 PM
  2. Pivot sleeve loose in frame
    By Stumpjumper61 in forum 29er Bikes
    Last Post: 10-11-2013, 02:40 PM
  3. Loose bearing in Lopes Link
    By lemmy999 in forum Ibis
    Last Post: 05-17-2012, 07:07 AM
  4. RWC needle bearing install on Rune
    By Resnick in forum Banshee Bikes
    Last Post: 03-13-2012, 01:41 PM
  5. Rune/ISX shock needle bearing kit?
    By jgusta in forum Banshee Bikes
    Last Post: 08-26-2011, 11:27 AM
