Results 1 to 6 of 6
    Reputation: dirtrider76's Avatar
    Sep 2012
    Rune V2 Fox CTD volume spacers
    I looked for the info before and asked once in the Rune thread and never found the info. I opened my shock up tonight and found that the shock has the 2nd from the smallest or 0.40 spacer in it stock.
    http://service.foxracingshox.com/con...SpacerProc.htm
    I moved up one size(0.60) hoping to make it a ramp up a bit more. I'm a big guy and could use all the travel pretty easily. I may end up messing with it more but its really easy to change. The change can be done in a few minutes. Having never done it before it took less than 15minutes total time. I lost no float oil since I didnt pull the can all the way off and just added maybe 1cc as lube and just to keep it wet inside.
    I like to fart when I'm in front of you on a climb
    Feb 2013
    Interesting, let us know how it goes with the next size up!
    Sep 2012
    So the trails are clear enough I got to ride it some and it ramps up quicker and didnt bottom out. I'm going to drop a bit more pressure out and try it again. Its deffinitly a step in the right direction though.
    Sep 2012
    I let out a bit of pressure since last time out and rode twice since last week. After riding some single track yesterday and some DH sections I know well this deffinitly helped. It got close to bottoming but didnt and small bump compliance is better. Theres no drop's in the area I rode so not bottoming it is good cause I means I have some left for drop's. I'm going to leave it as is and get a few more rides on it and see how it feel's at a few other trail's.
    Sep 2012
    I moved up 1 size spacer today and will report back after getting a few rides on it. I can still use all the travel and it rides awesome. I just can use all the tavel a bit easier than I'd like. I've been pounding on it pretty hard and getting a bit more ramp up might help some.
    Sep 2012
    Quick update compression side feel's good and ramps up perfect but I ran into one issue. Its rides fine for me but the rebound adjuster is maxed to keep it from trying to buck you. I guess the ramp up to keep it from hitting full crush easily is making it hard for the shock to control the rebound. It was not maxed till I did the last spacer change. It works great for me this way but its at its limit.
  1. Volume spacers on Tallboy with CTD shock?
    By CrozCountry in forum Santa Cruz
    Last Post: 03-31-2014, 01:32 AM
  2. Replies: 15
    Last Post: 02-11-2014, 11:32 PM
  3. Bronson, CTD shock and volume spacers.
    By Rick Draper in forum Santa Cruz
    Last Post: 10-22-2013, 08:37 AM
  4. Float volume spacers on Enduro auto sag shock
    By coolatt in forum Specialized
    Last Post: 07-26-2013, 10:51 AM
  5. Reign owners: float volume spacers
    By GFWD in forum Giant
    Last Post: 08-02-2011, 10:14 AM
