Results 1 to 13 of 13
    Rune shock bolt torque spec?
    Hey, what is the recommended torque for the shock mounting bolts on the rune? couldnt find it on the website... thanks.
    Thanks keith! Took it out for first ride yesterday, fantastic bike,so much better than my Heckler. Love the 45 mm stem!
    Glad you like it mate. I hope you find that you have the confidence to progress and improve to go faster, further, higher and bigger!
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
    Are these specifications still valid for the Rune V2?
    15Nm max for the rear 8mm shock bolt (through rear triangle), and 8Nm for the front shock 8mm axle.
    Banshee Blog
    www.sillylines.com
    Reputation: Third eye's Avatar
    The 15 Nm are for the M8 screw on the back, what about the front (M5 or M6)?
    15 Nm for the front one seems a little bit to high?
    What torque for the M8 for the rear dropouts on Rune V2 / Spitfire V2?
    Hard funkinī Kraut
    Reputation: NoStyle's Avatar
    May 2005
    Quote Originally Posted by Third eye View Post
    15 Nm ??? Woahh, thatīs a massive Torque. Keith, are you really sure?!?!? Just remembered the old Discussion about Torques back in 2008, when they where as high at first and went down to 7 - 9 Nm at maximum - for everything including Bearing-Bolts and Shock-Bolts ...
    Horst, please tighten them by hand up to the first coming resistance. Thatīs more than enough, as I can tell from the old Wildcard or new Spitfire. 15 Nm must put seriously damage to the Bolt or wrench - seems way to tight for me!
    Reputation: jgusta's Avatar
    Quote Originally Posted by NoStyle View Post
    I did mine to about 5Nm like the upper pivots with just past resistance. Felt about right to me.
    Ride On!
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    it's fifteen jizza-watts!
    www.sillylines.com
    I did approximately 10 - 12 Nm for the M8, 5 -7 Nm on the front.
    15 Nm seems also too much for me.
    Sorry, I must have been really tired when I wrote that. max 15Nm for the back 8mm shock bolt into RT, 8Nm for front 8mm shock axle... corrected that now. Thanks for questioning!
    Banshee Blog
    Hi what are shock bolt torque spec for Banshee Legend mkII?
    Quote Originally Posted by tymbarek View Post
    man, its an M8 screw... just snug it up and you are good to go...
    don't use an 40cm cantilever, and you can't really go wrong...
