Results 1 to 6 of 6
    Rune Owners - chainring size/Blackspire
    Can't use a 22 tooth granny gear or Truvativ HammerSchmidt Cranks, also I have not been able to put a Blackspire Stinger on my bike without modifying the frame or the device.
    The above was in one of the reviews.
    I was planning to use a 22 ring and the Blackspire for a frame I have on order.
    Is this true?
    Reputation: Hikers Only's Avatar
    Oct 2010
    If you are going to use a granny ring I wouldnt go any lower than a 24t, otherwise you are going to get noticeable pedal feedback. As far as the blackspire i dont know, when i was riding 2X9 I ran 24-36 upfront in conjuntion with A E13 DRS. I did have to use a thinner granny ring as the blackspire ring was too thick. I would consider going 1x9 or 1x10, I just made this change and I'm loving it! Especially with the Straitline Silent Guide.
    go 1x10 with 32 up front and 11-36 cassette... can't beat that...
    Reputation: Gman086's Avatar
    If your Rune has tabs around the ISCG mount holes like my Spitty did then you can just grind them down to flush with the ISCG mount plate (and grind the bolt heads down some too) and the Stinger will then work with a 22 tooth ring; works great on mine and I almost threw my Stinger out!
    Have FUN!
    G MAN
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
    Reputation: romar's Avatar
    I built up my Rune with a Stylo 2.2 crankset (24/36/bash) and ISCG05 Stinger with no modifications. been running it since July and so far, so good!
    Thanks for the replies.
    I have been running 1*9 for some time on a yeti asx....
    perhaps its age, lack of skill, lack of fitness or all of the above but I've been having trouble on some (most) climbs...was looking forward to the granny for the grinders....
    There are so many choices out there it makes it hard to decide where to start....maybe I'll just run a 26 tooth single ring and be a bit different
    Time to keep researching what combo's are out there...
  1. Question on XTR M960 Chainring differences
    By IRONMAN1518 in forum Shimano
    Last Post: 11-26-2017, 04:41 AM
  2. 1x8 with SS chainring?
    By Roasted in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-19-2009, 12:13 AM
  3. space between chainring and crank arm spider?
    By eman2 in forum Singlespeed
    Last Post: 04-17-2009, 10:06 PM
  4. Replies: 3
    Last Post: 12-31-2006, 09:06 PM
  5. Chain catching outer chainring
    By Jos Oss in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-17-2005, 11:30 AM
