    Question for Prime owners - front derailleur and chain ring combos
    I have a question for all the Prime owners out there regarding 2x10 setups. Has anybody ran a 38/24 or 36/22 combo with SRAM derailleurs? I've been researching derailleurs and all I have been able to find is a 39T derailleur. Am I wrong in assuming that you are locked into a 39 tooth setup with this derailleur? Are there any interference issues anybody has come across with the chain rubbing on the derailleur on smaller chainring setups? Thanks in advance for your help.
    Reputation: MartinS's Avatar
    I ran the 39T front with a 34/24 combo, worked great. As far as I remember the 39T was a maximum.
    That's what I needed to know. Thank you.
    MTB B'dos
    Reputation: LyNx's Avatar
    I run 38/24 using the SRAM XO 39t S3 model FD and no issues. As Martin said, 39t is the max size you can use.
  1. Front Derailleur won't shift to Granny Ring before or during Climb
    By zance789 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-14-2013, 11:33 AM
  2. chain poping off on front ring
    By Gilly32 in forum Downhill - Freeride
    Last Post: 05-15-2011, 12:53 AM
  3. sram X-9 front derailleur for a 2 ring crank
    By Roc1 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-09-2011, 04:02 AM
  4. Front Chain ring issue
    By VicnPA in forum Singlespeed
    Last Post: 04-06-2011, 07:42 PM
  5. Best shimano front derailleur for double ring set up?
    By Teigansdad in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-07-2011, 01:56 PM
