Page 8 of 38 FirstFirst ... 45678910111218 ... LastLast
Results 351 to 400 of 1864
  1. #351
    Reputation: Znarf's Avatar
    Sorry to bump again.
    Still no info about warranty and 150mm (or even 160mm) 29er forks on the Prime?
    I am so tempted to buy one
    Greetings Znarf
  2. #352
    Oct 2011
    Are there 29er forks with 160mm?
  3. #353
    MTB B'dos
    Reputation: LyNx's Avatar
    No single crown forks, unless they're prototypes that are being tested. You can get the Dorado, which I think when limited for 29er gets 170mm, but the warranty clearly states no dual crown forks for the Prime. There are the 26" F36 160mm forks with arch mods that some are using, not sure on if travel needs to be limited on those or warranty - Enel is running one on his Prime.
    Quote Originally Posted by Kreisel View Post
    MTB Barbados
    My Phantom pics
  4. #354
    No 160mm "official big brand" 29er forks - yet!
    Ive read several times that one will be released by a big brand in summer 2013.
    @Lynx:
    Maybe I am blind (or stupid), but I cant find warranty information on the prime on the Banshee site. Do you happen to have a link?
    Would be very thankful =)
    Greetings Znarf
  5. #355
    MTB B'dos
    Yeah, I heard that rumor too and I guess at Sea Otter we'll find out - although that was the rumor last year as well though
    On the warranty, guess maybe it's that I've been talking with Keith about the Prime since early days and he's repeatedly stated it's not designed for such a fork and warranty would not cover dual crown forks. Best bet is to e-mail them and ask them directly.
    Quote Originally Posted by Znarf View Post
    @Lynx:
    Greetings Znarf
    MTB Barbados
    My Phantom pics
  6. #356
    Fork limit for the Prime is a 160mm single crown. If you run a double crown, or anything over 160mm then warranty will be void.
    Thanks,
    Keith
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
  7. #357
    Powered by ice cream.
    Reputation: Enel's Avatar
    Travel on my 36 fork is limited to 130mm, and A-C is identical to any 140mm 29" fork.
    After riding the Prime a bit I realize probably the only fork on the market stiff enough to match the frame is a Dorado.
  8. #358
    Great,
    Tranks for the Input, Keith!
    That will be my Park bike then :-)
  9. #359
    I rode the Prime Back to back on a well known to me trail loop with my 2010 Stumpy FSR yesterday and it was eye opening.
    These bikes are identical except for:
    Fork: Reba 140 on the Stumpy and modded Fox 36 on the Prime;
    Wheels: 150mm X12 rear with 36 spoke wheels on the Prime compared to 135 bolt on rear and 32 spoke wheels on the Stumpy;
    Drivetrain: The stumpy has stump pulling low range supergranny drivetrain allowing gearing down to 20X26, the Prime is standard 32X22 front and 11/34 rear
    Weight: The Prime is about three pounds heavier between the wheels, fork and frame.
    Terrain was slow chunk/finesse stuff with a section of moderate speed (11-12mph), but very chunky descent. Climbs were similarly short, but chunky and quite steep at times requiring standing bursts and momentum to crest.
    The bikes ride/perform very similarly as they should given the numbers. I was no more capable or faster on one versus the other. This is good to me because I have been very pleased with the Specialized. However: these two bikes/builds could not feel more different from the standpoint of flex and general solidity. The Prime is hands down the stiffest frame I have ever ridden in any category. (Note: No time on serious DH or Freeride rigs).
    The difference is similar to the difference between a thin tubed steel rigid frame and a burly tubed aluminum frame. I felt like I had to have a bit more body english/anticipation of the flex with the Stumpjumper. It was not bad or unmanageable, it just felt completely different. If you have spent any time back to back on a burly longer travel AM bike versus a cross country race type bike, you will know exactly what I am talking about. I think the differences would be even more obvious at higher speeds as the stress on the frames increases.
    The Prime felt simply better planted than the Stumpy in all terrain and conditions. I think I had a wee bit more traction. It wasn't a mind blowing difference, but it was different. I am looking forward to dialing it in more, but I am quite comfortable on the Prime after only two rides.
    I played with the CCDB air and ended up at 25% sag (for me near 200 lbs geared up it was 110 psi), 80% (20 clicks) low speed rebound, 80%(20 clicks) low speed compression damping, zero HSC and about 15% (3/4 turn) HSR damping. After my trail ride, I am going to dial in a touch more HSR and HSC damping. I am getting pretty close.
    I hope to get the Prime down to South Mountain in Phoenix this weekend for a real thrashing.
    For now, I would absolutely recommend the Prime, especially if you weigh over 200lbs and/or have had issues with flex in other 29" frames. I am not sure a lighter primarily XC rider really needs what this frame offers (along with the associated weight penalty).
  10. #360
    Reputation: jncarpenter's Avatar
    Quote Originally Posted by Enel View Post
    Cool!
    I figured you'd dig the uber-stiff chassis of the Prime. Now...if we could only get a suitable fork!
  11. #361
    Quote Originally Posted by jncarpenter View Post
    Cool!
    Agreed. Imagine that. This frame really deserves a production fork worthy of it.
  12. #362
    Mar 2011
    Tomorrow i'm bolting on last XX1 bits, and then i have winter vacation at gravel-pit called Tenerife and a volcano called Teide, last time i was there with prime proto it kicked ass there, now i have 12mm bolt thru axle on rear and production frame...
  13. #363
    <iframe src="http://player.vimeo.com/video/57255279" width="800" height="450" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe>
    I got to ride an extremely fun ride called Goat Camp in Phoenix today.
    It starts with a steady 9 mile 2500 ft climb. The Prime proved a competent steady climber. I finally noticed the mechanical help the suspension gives in the pedaling department: with standing uphill spring type moves, the bike just squirts forward with minimal wallow. Not XC stiff, but it is nice.
    I like that the frame achieves this without so much stiffening that it loses traction on loose stuff. I personally prefer more traction with some pedal bob over great pedaling characteristics with traction loss.
    Anyhoo, it's a decent climber and took care of switchbacks and chunky sections as well as I could.
    The downhill on this ride is relentless, slow, chunky, loose, steep tech for three miles. I hesitate to show the video because it really can't do justice to the terrain. If slow tech is your thing, ride this trail. The Prime had no bad habits I could find under braking and rolling steep things into chunk.
    On the lower 1/2 mile of the descent I was finally able to open it up speed wise on smooth mixed with small chunk and that was a hoot.
    I have officially determined that the Specialized is out of a job. The Prime does everything just as well, and a few things decidedly better.
  14. #364
    live long and huck
    Reputation: Optimus's Avatar
    Nice job on Goat Camp, Enel. Doesn't surprise me that you nailed the staircase, considering the type of riding that you typically do. You are right, that video does not even come close to portraying that section accurately. There is a whole lot of serious pucker on Goat Camp.
    I'm finding similar with my newly installed DBair, lots of low speed dialed in, very little high speed, DBair is WAY better than the CTD.
  15. #365
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    Enel, good to hear you're diggin' the bike- especially as I haven't ridden a SJ.
    Good review of the Prime in the new Bike magazine bible. Although I am a little confused by their apparent bias towards 26" trail/xc bikes over 29" AM bikes. Personal preference!
    Just threw a KS Lev 150 on my Prime. Breaking in a new local feature- we tweaked the run-in after this so more speed can be carried (basically fast walking speed shown here).
    <a href="http://www.flickr.com/photos/10323561@N07/8328579256/" title="IMG_4925 by emailsucks98, on Flickr"><img src="http://farm9.staticflickr.com/8219/8328579256_1a52edc489_c.jpg" width="800" height="600" alt="IMG_4925"></a>
  16. #366
    Reputation: eurospek's Avatar
    Quote Originally Posted by FM View Post
    Got mine yesterday, and while a ton of bike is reviewed, I somewhat enjoyed last year's Bible a whole lot more.
    konahonzo
  17. #367
    Finally got time to upload another GC vid from Friday's ride.
    <iframe src="http://player.vimeo.com/video/57295778" width="800" height="450" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe>
  18. #368
    Need more pics in this thread. Keep it up.
  19. #369
    live long and huck
    Good stuff Enel, and FM.
  20. #370
    Production Prime Photo/Build thread-imageuploadedbytapatalk1358120836.804230.jpg
    Big bro versus little bro.
    I bounced a bit on the Rune and it is sweet. Mikey sez it pretty much blows his Nomad away. I am very jealous if the Lyric fork.
  21. #371
    beater
    Reputation: evasive's Avatar
    Feb 2005
    "Back off, man. I'm a scientist." - Dr. Peter Venkman
    Riding in Helena? Everything you need to know, right here.
  22. #372
    FM
    FM is offline
    Apr 2003
    Thanks for posting that, much more detail than the magazine copy. Good review!
  23. #373
    Nice pictures, nice bikes and beautiful trails!
    @Enel:
    I currently ride a 2011 Stumpjumper FSR Comp 29er, which is identical frame wise to your 2010 as far as I know. I'd be very interested in the weight difference between those two frames.
    You didn't weigh the frames by chance? ;-)
    Does the Prime climb as good at the Stumpjumper?
    Thanks a lot for all the good intel so far!
    Greetings Znarf
  24. #374
    @Enel:
    Greetings Znarf
    Prime climbs just as well and more planted in chunk. I don't know the weight difference. But I imagine it is around a pound. Weight below includes dropouts and CCDBa shock.
    I don't think the Prime will change your life over the Stumpy, but it is a nice upgrade. The lighter you are the less difference you will notice, IMO.
    Attached Thumbnails Attached Thumbnails Production Prime Photo/Build thread-image.jpg
  25. #375
    Yeah, my Stumpjumper is actually doing great. I keep saying to myself that I will "upgrade" in 2014.
    I see some sort of new bike in 2013 though =)
    Greetings Znarf
  26. #376
    Quote Originally Posted by evasive View Post
    They're doing video this year:
    Banshee Prime Review
    "Like Godzilla!!!"
    This would definitely be my first choice for a 29er FS if my terrain called for such a beast.
    konahonzo
  27. #377
    Reputation: 7HVN's Avatar
    Which fork?
    Contemplating a Prime.
    But wondering if it is a major up-grade from a Behemoth with a shaved and modded Fox 36 or a 09 Sultan with a WB F135.
    And...
    Which fork for the Prime: new F34 or the shaved Fox 36 with 1 1/8 steer tube?
    Reputation: Colin+M's Avatar
    A closer comparo would be the Behemoth to Prime. Geometry is similar. "Major" upgrade? Doubtful. Enjoyable getting something new to play with? Absolutely!
    I had a handful of Devin's bikes, not a Behemoth though, and I think he makes some of the best ones out there especially from a geometry standpoint. The Prime proto I had was such fun that I'm getting a Production model next week. I feel that the major differences would be the adjustable geometry, options for rear spacing and a capability for piggyback shocks. The Prime is a super stiff frame as well much like the Lenz bikes I've owned (Lunchbox, PBJ, Mammoth).
  29. #379
    Mar 2011
    So i did 5 days of riding with the production frame on mt. Teide, which is very harsh terrain, i ran DHX-A on rear and 34's on front and the bike certainly didn't hold me back, my lack of skill riding on loose gravel/upper torso strength was limiting factor for me, DHX worked really well pretty much on all stuff i did on it, high speed double track and technical descents and long climbs (if 500m vertical over 11km is long, it is for me).
    Zero over the bars moments, which is rare there, techier sections of those trails are steep and full on head/tv sized rocks for 5-10minutes per section, could keep up with bigger bikes until i ran out of juice on upper torso.
    Some of the trails had steep climbs which worked great with the XX1, pedal kickback was minimal/nonexistant so rear suspension felt really good when climbing over rough sections, good traction, didn't have steering problems when doing technical climbs.
    Rolling off drops was super fun, easy to lift the front/do little manual, it was fun to jump on small jumps at high speeds also on faster trails.
    Overall, very happy with the frame and i think it is a keeper.
  30. #380
    Reputation: highrustler's Avatar
    sizing
    Anybody with a Prime on the CO front range? I am in between a MED / LRG and need to throw a leg over one. Currently on a Large Tallboy LTc which is a perfect fit.
  31. #381
    May 2012
    Quote Originally Posted by highrustler View Post
    I also tried a L LTa for a few days which had a very good fit. I went for the M Prime. If you compare the geo specs the reach from the L LTa(c) is nearly exactly as the one from the M Prime. I think the largest difference is the seatpost angle ... but you can move your seat some cm so it should be fine.
  32. #382
    Reputation: filbike's Avatar
    Quote Originally Posted by 7HVN View Post
    36 with 29"rims???
    can you explain me??
  33. #383
    Reputation: zoorlen's Avatar
    Quote Originally Posted by filbike View Post
    36 with 29"rims???
    Modded Fox 36
  34. #384
    ..can't believe it.
    I thougth about that alteration a few days ago, but I soon realized it was a crazy thing.
    ...and now I see out there people riding happily shaved 36!!!
    ..just thinking something insane about my VAN 36
  35. #385
    Just got my size Large Yellow frame in today from Chad @ The Barn and the color is absolutely killer in person. I'll try to get some pics up tomorrow. Build weight came in at 31.92lbs with 150mm rear, CCDB and Hans Dampfs. I was surprised it was that light.
    P.S. - Chad @ The Barn is great to deal with and I can't recommend him enough. I'm in Georgia but I might has to make a little shop in Montana my new LBS.
  36. #386
    beater
    Feb 2005
    That is light!
    It is impressive what Chad has been able to do outside a town that's small even by Montana standards.
  37. #387
    FM
    FM is offline
    Apr 2003
    Bring on the pictures!
  38. #388
    May 2012
    Quote Originally Posted by zoorlen View Post
    Would this also work, maybe even better, with some 650b Fork?
  39. #389
    Let's see the yellow Colin!
    konahonzo
  40. #390
    Quote Originally Posted by pinkey View Post
    I read somewhere that the 36 arch fits some (most?) 650b tires... but I don't know if you have to limit the fork travel to avoid contact between tire and crown. I bet someone in the 650b forum can give you a more precise answer.
  41. #391
    The yellow hotness is coming this afternoon as soon as I get home from work.
  42. #392
    beater
    Feb 2005
    Looking forward to it. Probably not as much as you are, though.
  43. #393
    The sun was going down so these pics don't really capture the color all that well. I still have some cable trimming and steerer trimming to do as well.
    This bike is the epitome of "in the bike" feel to me. Very pleased.
    More pics to come.
  44. #394
    FM
    FM is offline
    Apr 2003
    Hell yeah that looks awesome
  45. #395
    I love that yellow!!!! <3
    konahonzo
  46. #396
  47. #397
    I am getting along well with the Prime. I have had some short tech sessions and a longer climbing/descending singletrack ride. I noticed the weight toward the end of the longer ride, but that is more fitness than anything.
    The CCDB air shock is pretty remarkable. It will allow you to tune it to pretty much whatever you want. I went too firm, then I went too soft on the low speed damping. In the soft setting, the little stuff just disappears. The shock becomes more sensitive to small hits than I thought possible. In the firm setting, it stays firm until the hits go beyond the low speed threshold and then it smooths right out. Right now the settings are pretty dang close to the Banshee factory recommended settings.
    I don't really notice the suspension. If I go light on the LSC/LSR, I will notice the shock shaft bobbing 3mm if I look at it. This is from the reciprocating mass of my legs or body if I stand. I don't notice that pedal input makes the suspension do much if anything at all. I don't notice the suspension under braking, I don't notice it pedaling through chop. That is good.
    I did blow through all the travel and bottom the shock many times today going off the 2-3ft drops noted in photos above. Never once did I feel it, I just noticed the O-ring was maxed. I have 25% sag right now and am reluctant to add any more air or compression damping. I think I am going to add one of the thingies to reduce air volume to the shock. My friend with the V2 Rune/CCDBa just put the biggest spacer in and it seems to be working well for him.
  48. #398
    Reputation: helimech's Avatar
    Mar 2006
    Looking good Enel .
    SHITBIRD
  49. #399
    FM
    FM is offline
    Apr 2003
    Yeah good stuff Enel.
  50. #400
    <iframe src="http://player.vimeo.com/video/58234027" width="600" height="337" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe> <p><a href="http://vimeo.com/58234027">Prime</a> from <a href="http://vimeo.com/user457842">Enel</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
