Page 55 of 72 FirstFirst ... 5 45 51 52 53 54 55 56 57 58 59 65 ... LastLast
Results 1,351 to 1,375 of 1798
  1. #1351
    Reputation: Colin+M's Avatar
    Re: Production Prime Photo/Build thread
    Steel may be real, but Titanium is a dream!
  2. #1352
    Reputation: eurospek's Avatar
    Nice rack.
    konahonzo
  3. #1353
    son of a boon
    nice ( . Y . ) rack
    Gesendet von meinem GT-I9300 mit Tapatalk
  4. #1354
    Quote Originally Posted by Colin+M View Post
    I haven't looked that hard, but have never came across a coil spring CCDB in the right size. Where did you find, and how do you like?
    Btw, your Pike and ENVE wheels are defective, please send them to me for evaluation.
  5. #1355
    I got the CCDB at Universal Cycles.
    As a bigger rider, it really helps with midstroke support. Loving it so far.
  6. #1356
    Reputation: qbert2000's Avatar
    yeah, coil is the way to go for bigger guys really. and really, there is no air shock that is equal to a coil, hence every maker of an air shock saying it offers a coil like ride.
  7. #1357
    CP
    Reputation: C.P.'s Avatar
    Oh, how I wish I ordered a CCDB coil with my prime...instead of the Air. All along I had this gut feeling it was the way to go...
    Already sent my CCDB Air in for sleeve issues...thankfully, covered by warranty.
  8. #1358
    I need all the midstroke support I can get!! haha
  9. #1359
    Badabing!
  10. #1360
    Hey Guys,
    I have had a looksie on the website etc.. however I can't find an exploded view of the prime frame.
    I need to replace the bearings and wanted to make sure it all goes back together correctly
    Also am I correct in thinking that a bearing tool such as this might do the trick?
    Superstar Components - High Spec Parts For Peanuts
    In the 608 and 6001 sizes.
    I already have the replacement SKF bearings.
    But could do with the tools.
    p.s. keep the photos coming
  11. #1361
    MTB B'dos
    Reputation: LyNx's Avatar
    From the looks of it, yes, should work for whatever bearings you need to remove/install on a lot of frames. If you want some other ideas, you could check out my thread from when I did my Trance Trance Bearing replacement How To.
    Quote Originally Posted by phat-ant View Post
    Hey Guys,
    I have had a looksie on the website etc.. however I can't find an exploded view of the prime frame. I need to replace the bearings and wanted to make sure it all goes back together correctly
    Also am I correct in thinking that a bearing tool such as this might do the trick? Superstar Components - High Spec Parts For Peanuts In the 608 and 6001 sizes. I already have the replacement SKF bearings. But could do with the tools.
    MTB Barbados
    My Phantom pics
  12. #1362
    WNC Native
    Reputation: nitrousjunky's Avatar
    Colin+M- That's a friggin sweet build, I always thought I liked the raw better. Yellow is it!
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
  13. #1363
    Thanks Lynx, I was toying with the idea of making my own but im quite lazy perhaps ill go over to the parents house and spin up the lathe! save a few pounds.
  14. #1364
    May 2014
    Wink My new Babe
    Hi,
    I'm Alex from France, and here is my new babe !
    A Banshee Prime 2013, Raw!
    It is my first hand built, do it myself for all the parts, i'm happy !
    Amazing bike, do everything i'm in love !!
    And thanx to all of you on banshee mtbr forum, i read you a lot and could get many usefull informations in order to build this bike.
    Production Prime Photo/Build thread-20140518_105941.jpg
    Complete Set Up :
    Frame : Banshee Prime 2013 Raw, medium size, neutral slack (68°)
    Rear Dropouts : 12x142
    Rear axle : RockShox Maxle Lite QR 12x142
    Fork : RockShox Revelation RCT3 solo Air 140mm 2014
    Shock : Fox Float CTD Kashima Trail Adjust
    Wheels : Race Face Turbine 29er
    F Tire : Maxxis High Roller II Exo 2.3
    R Tire : Maxxis Ardent 2.25
    Cranks : SRAM X9 (22-36+Bash)
    Bottom Bracket : SRAM GXP
    Shifters : SRAM X9
    F Derailleur : SRAM X0
    R Derailleur: SRAM X9 type 2
    Cassette : SRAM PG1050 12-36
    Chain : SRAM PG1071
    Pedals : Nukeproof Neutron
    Brakes : Hope Tech 3 E4 + 183mm Hope floating discs F/R
    Headset : Cane Creek 40 Zero Stack
    Stem : Thomson Elite X4 70mm
    Handlebar : Thomson Trail Alu 750mm
    Grips : Oury Mountain Lock On
    Seatpost : Banshee
    Seatpost collar : Hope QR
    Saddle : WTB Volt Team
    coming next : a RS Reverb of course !!
    Cheers
  15. #1365
    on a routine expedition
    Reputation: Marshall Willanholly's Avatar
    At the top of Time Warp in Ashland.
    Production Prime Photo/Build thread-imageuploadedbytapatalk1404333533.895681.jpg
  16. #1366
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    Quote Originally Posted by Marshall Willanholly View Post
    Nice... tell us about your fork, inquiring minds want to know!
  17. #1367
    Quote Originally Posted by FM View Post
    Sharp eyes! This Ashland trip was my first ride on the Avy cartridge. I found it to be a significant improvement over the stock Fox damper. I felt like it did a much better job of smoothing out the trail chatter while not diving under hard braking or cornering. Last year on the same trails my hands were really taking a beating. This year was a different story.
    To be fair, I did replace the wiper seals and air head seals at the same time I installed the cartridge. I also used the new Fox gold 20w oil in the lowers (at least on the air spring side, damper side is now open bath). I'm sure this also contributed to the lack of stiction, but the way the fork stayed up in its travel while remaining plush was all down to the Avy cart.
  18. #1368
    Reputation: MartinS's Avatar
    Nice pic from a ride out in Crowsnest Pass, AB. Nothing overly tech, but a scenic shot.
    Production Prime Photo/Build thread-img_10965951507672.jpeg
  19. #1369
    Hi guys,
    I need some help. Can anyone with a XL confirm that the wheelbase is actually 48 inches as per the website?
    I'm 5 foot 11 and can get a good deal on a XL, but afraid it may be too big for me.
    Cheers.
  20. #1370
    Quote Originally Posted by Willyswildride View Post
    Hi guys,
    Cheers.
    If you pass, please let me know where, I've been looking for an XL but refuse to buy new to experiment full-suspension first.
    konahonzo
  21. #1371
    Yep, 48". At 5'11" you are too small for an XL unless you have a freaky short inseam, like 28" and really long arms. XL Banshees are bigger than most other companies XL's. I'm 6'4" with shortish legs and run a 60mm stem on mine, fits like a glove.
    Hi guys,
    Cheers.
  22. #1372
    beater
    Reputation: evasive's Avatar
    Feb 2005
    I'm 6'3" on a (pre-production) large, and it fits me and my short legs/long torso perfectly. It also fit my friend well at 5'11" and 34" inseam. I suspect a XL will be too much for you.
    "Back off, man. I'm a scientist." - Dr. Peter Venkman
    Riding in Helena? Everything you need to know, right here.
  23. #1373
    Reputation: filbike's Avatar
    Way too big man!
    I'm 6"1 on L and 50mm stem and I've never felt better on a bike.
  24. #1374
    MTB B'dos
    As the others said, an XL is WAY too big for you, way too big. I'm 6'2.25" long a$$ arms and legs and I have an XL pre-production because that's what I always rode (XLs) and the Large was too small, ended up running a 65mm stem and 785mm wide bar and it was fun, but now on a Large Phantom with the 450mm Reach, same bar/stem and it feels much better.
    Hi guys,
    Cheers.
    MTB Barbados
    My Phantom pics
  25. #1375
    If you can wait a week or so I'll be getting rid of my medium yellow frame once my Phantom gets here. I'm 5'11 and it fits me well for a longer travel bike with a 60-70mm stem and 760mm bars.
