Page 4 of 20 FirstFirst 1234567814 ... LastLast
Results 301 to 400 of 1921
  1. #301
    Reputation: qbert2000's Avatar
    No one's running a 120mm fork on their Prime, why would they? Prime is designed around a 140mm fork, BB height is perfect with it, as is the HA, why would anyone purposely lower the BB and steepen the HA? I had intentions to try a 120mm fork on mine, but once I got it I quickly realised what a silly exercise it would be. If you want a bike with less travel or steeper angles, maybe the Prime isn't for you.
    so you roll your eyes at someone who is thinking of doing the same thing you were thinking of??
  2. #302
    MTB B'dos
    Reputation: LyNx's Avatar
    If you are seriously considering the Prime, definitely sell the 120mm and buy a 140mm fork, I think if you don't run the Prime with it's intended travel/A2C fork you'd really be missing out on the entire experience the entire package gives..
    You could run it in the steep setting which would raise the BB 1/2" over the slackest setting, but then your HTA would be about 69.25*, which I guess is not too bad, but about the same as the RIP. In running the 120mm fork you'd be dropping the BB probably more than the 1/2" down close to 13" UNsagged, SAGged then it's probably be close to 12", which where I ride equals lots of pedals strikes or lots of pedal timing and the really nice thing about the Prime is it's ability to just sit and pedal (plow) over/through stuff, which doesn't quite mesh with having to time pedal strikes to avoid pedal strikes. Now there was one tester I'm aware of who said he'd like a lower BB, but the majority I think liked the higher BB and hence the height stayed the same from pre-production to production.
    Quote Originally Posted by Sasquatch1413 View Post
    Cause thats all i got:-) i come from a niner rip9 which has a steep hta compared to the prime. I havent checked the rip bb height comparatively though. If i buy a prime ill be trying the 120. Hopefully such blasphemy wont bring the end of the world upon us.
    Where do you see I rolled my eyes? No where I said crazy, that's different As to the why I was thinking it, because I was a tester, that's why, you know, the people who test stuff out to see if it's a good idea or not and that was a general consensus AFIK, hence it was not changed, just an in between setting added.
    Quote Originally Posted by qbert2000 View Post
  3. #303
    Quote Originally Posted by sakucee View Post
    Keith, what size chainring is the Prime optimized for? 32 or 30t? Wondering should i order 30t for my XX1..
    Thre is no such thing as a single optimal chainring size. It depends on what characteristics you want and where you are in the travel. That said the range I would recommend goes from 28-34 if running a XX1 setup to match the 29" gear ratios, and I have matched the linkage kinemtaics to this chainring range.
    Personally if running 1x11 I would opt for a 32 tooth chainring on the prime, as that would be plenty easy enough on the climbs, and give good speed on fast descents and reduce pedal kickback slightly over a smaller chainring option.
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
  4. #304
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    Cause thats all i got:-) Hopefully such blasphemy wont bring the end of the world upon us.
    Sasquatch- 120mm won't be quite ideal, but it'll get the job done and you'll still love the bike.
    Giving up 20mm travel is not a huge deal, the impact to the geometry is the concern.....
    Keeping it in perspective- 20mm difference in front will steepen the head angle around 1 degree and lower the BB around 6mm. Some prime owners are running internal lower headset cups, they're already giving up 10mm+ of fork length. Look for a headset with an external lower cup, to help keep the head tube where it should be.
  5. #305
    tester? you paid for the privilege, you aren't a professional "tester" by any stretch, sorry to burst your bubble.
    like fm stated, en external cup with a 120mm fork won't ruin the geometry. he could also add a + 5mm crown race to get it even closer
  6. #306
    Mar 2011
    Quote Originally Posted by FM View Post
    <nitpick> i think production frame is supposed to be with internal cups with 140mm fork </nitpick>
  7. #307
    May 2012
    Is this bike "too much" to be a "trail bike", with XC-terrain and necessary pavement bits? Is this AM bike with clear downhill flavor? Or is this more like a strong build, go-anywhere, how far you want, trail bike? No proper mountains here, more like constant climbing and descending hills and a lot of flat areas, some steep parts but mostly short-lived. Roots and rocks and dense woods. I'm also a lightweight dude who has habit of standing and smashing climbs. I think it looks absolutely beautiful in every way, but I have feeling it may be like drooling after an off-road vehicle that eats up too much gas and that I wouldn't drive where it were meant to be driven anyway. I'm just wondering if the suspension design and geometry options and such would make it fine all-rounder. Also whether it's bike you climb to enjoy the descents or enjoy the whole thing pretty equally.
  8. #308
    Reputation: eurospek's Avatar
    First yellow completes that I've seen anywhere.
    konahonzo
  9. #309
    FM
    FM is offline
    Apr 2003
    Sakucee, looks like you're right- I see the production head tubes are 44/56mm. 1.5 head tubes are 49mm and I don't see any 56mm external cups available.
    welcome to the trainwreck that is MTB headset "standards"!
  10. #310
    Mar 2011
    Quote Originally Posted by Horros View Post
    I have to pedal a lot on my trails, no long downhills and everything is infested with roots and rocks and wheelie drops, no complaints so far, i do run 28t single in front, i have no idea whats the current build weight, really should measure it..
    Alot of it depends what shock you decide to run, CTD shocks have massive platform on climb mode.
  11. #311
    Reputation: MartinS's Avatar
    I don't see where he said he was a 'professional' tester. He is part of the group who got a 'proto' frame at a pretty good deal and we did have our own discussion page where the 'testers' did discuss pros and cons of various set-ups. BTW there currently isn't an external headset for the 56mm tapered headsets.
  12. #312
    Reputation: Colin+M's Avatar
    Quote Originally Posted by eurospek View Post
    Best color I've seen. If I decide to get one it will have to be yellow. The color definitely fits the aggressive nature of the bike.
  13. #313
    Dang loving the yellow!! and I've Just heard that my Raw Frame has finally arrived in the UK I just need to sneak him through customs lol
  14. #314
    Reputation: Znarf's Avatar
    I've read somewhere on this forum that for 2014 there will be a 562mm 160mm 29er fork.
    Would such a fork be ok to use on a Prime? Warranty etc.?
    The yellow ones look absolutely fantastic. I want to buy/build a large frame for bike park and shuttle days.
    I'd put a 150mm 34 on there, as they're already available.
    But if a 160mm 29er fork would/will be available, I'd love to fit one. IF Banshee allows that.
    Maybe someone can chime in and enlighten us.
    As a side note: The Prime is really a stunning bike. Wonderful shape and design. Congratulations, Banshee.
    Greetings Znarf
  15. #315
    Powered by ice cream.
    Reputation: Enel's Avatar
    Built.
    34.75 lbs
    It required grinding the front derailleur a bit, but not a big deal. Everything shifts with two plus bash up front and 150 rear.
    This is a very, very robust and stiff frame.
    I like the CCDB around the driveway. It will truly do anything you want it to do.
    When set to slack, it appears to be a geometric twin to my 2010 Stumpy: Perhaps 1/2 degree slacker, no more up front. Cockpit is identical. BB height identical, Chainstay identical.
    It just weighs 3.5 lbs more.
    1 lb is in the fork. The wheels probably account for 1/2 to 1 lb, and figure another lb in the frame/CCDB shock.
    Hopefully some ride impressions with pics tomorrow.
  16. #316
    MTB B'dos
    That's with the Shimano XT FD then that you had to grind? No issues with the SRAM XO, so something learned I guess in that maybe the Shimano's are still not a perfect fit.
    With regards to your Stumpy, was it a 26er or 29er? If it was the 29er you're right, everything but the HA is almost identical, but the HA should be about 2 degrees slacker. Was/is this a feeling you're going by? If so, if you used an F34 140mm fork, it has a 51mm offset and the Stumpy used a 120mm with 46 or 48mm offset, so the greater offset makes the Prime handle snappier than you think it should and why it might feel only slightly slacker when in fact it's 2 degrees
    Quote Originally Posted by Enel View Post
    Built............34.75 lbs
  17. #317
    It's the Jenson Shimano derailleur linked to above. I had to do a more aggressive grind on my Lenz bikes. It hits the up and down part of the main rear triangle. And the triangle will push the body of the derailleur slightly on full compression with the shock disconnected.
    Production Prime Photo/Build thread-imageuploadedbytapatalk1357310472.004444.jpg
    I am pretty impressed with the cable routing and guides. Good design Keith.
    Angles are measured: Fox 36 with machined crown on the Prime 68-68.5. Reba 140 on the Stumpy 68-68.5. Both have a 545mm A-C. The Prime is absolutely, positively no slacker.
  18. #318
    FM
    FM is offline
    Apr 2003
    Cool, what settings are your drop-outs in? Ah I see- slack.
  19. #319
    MTB B'dos
    Ah crap, so despite changes to fix this, still an issue with Shimano FDs or at least older models. Did you try compressing the suspension with the shock in place just deflated? I'd expect there's a bit of play that the travel doesn't use and disconnecting the shock would then let it hit. I'm guessing the Shimano cage is longer/deeper than the SRAMs, hence causing it to hit the stay, think for the newer 780 model they shortened/narrowed this up. I've about 3/8" clearance between the stay and my XO FD on full compression, even when I remove the shock it still has just a smidge less clearance.
    Yeah routing is very good. Did they put a cable boss inside the seatstay for the rear brake cable to be tied to? Curious, it was something I mentioned in my feedback as I thought it could use it, although I haven't had an issues with mine that doesn't have it and I've run it with a cable tie holding the line in place and without, just always cautious.
    Ah OK, so not a stock Stumpy, longer fork, got it - 2010 Stumpy specs list it as coming with a 120mm fork. Interested to hear your thoughts on how they compared, especially stiffness wise. For me the stiffness just inspires so much confidence that I'm trying and riding stuff I never thought I would.
  20. #320
    FM
    FM is offline
    Apr 2003
    Yeah, all things in context... comparing the geometry charts, looks the the stumpy with a 140 fork will be pretty close, except a slacker seat angle/longer TT within a similar wheelbase.
    All conjecture
    Looking forward to some ride reports!
    As for the cable routing- there is "secret cable guide"- just wrap a zip-tie diagonally around the swingarm just above the cross-brace. sorry for the rotated pic.
  21. #321
    Reputation: jncarpenter's Avatar
    I came up with a similar resolution to FM, but added an extra loop to keep the line from sawing into the frame with time.
    EDIT: It looks like we also share the same ardent obsession with a meticulously cleaned bike
    Lynx...you mean this bad boy?
  22. #322
    Glamour shots
    Production Prime Photo/Build thread-imageuploadedbytapatalk1357360787.503158.jpgProduction Prime Photo/Build thread-imageuploadedbytapatalk1357360798.741632.jpgProduction Prime Photo/Build thread-imageuploadedbytapatalk1357360815.803112.jpgProduction Prime Photo/Build thread-imageuploadedbytapatalk1357360832.848662.jpg
    It rides very nicely indeed. It is not much different than the Stumpy, but this is very preliminary. I can say it does not have any noticeable bad habits at least at slower speeds.
    The CCDB is going to take some time to tune. It will behave just about any way you like though.
    Vids to follow.
  23. #323
    MTB B'dos
    Yup, that's the one I'm talking about Bit obsessive about keeping lines/cables OUT of the wheels Good to see that us un-paid "proffessional testers" feedback was maybe of some value
    Quote Originally Posted by jncarpenter View Post
    Man Enel, you sure do have some nice terrain for the Prime, you're going to have a blast on that stuff, for me especially the slow speed, chunky stuff where the stiffness really makes a difference is where I love the Prime. Would love to be able to try a CC DB, have only heard excellent things about them, unfortunately my pocket doesn't have those $$ right now so I'll be going with a X-Fusion 02 RLX or RCX first and then maybe the Vector AIR after.
    Glamour shots
    Vids to follow.
  24. #324
    Good news Prime has finally landed!
    Couple of build pics.
    Medium, Fit seems very good just riding around the street, I am sure will need to tweak once out on the trail tomorrow
    Still trying to dial in the gears and need to figure out how heavy I am to set the suspension up a wee bit better.
    No idea how heavy the bike is either
    Production Prime Photo/Build thread-p1010975.jpg
    Production Prime Photo/Build thread-p1010976.jpg
    Production Prime Photo/Build thread-p1010985.jpg
    Production Prime Photo/Build thread-p1020004.jpg
  25. #325
    Vids. Cover your ears if they are sensitive
    Climbing:
    <iframe src="http://player.vimeo.com/video/56798845" width="500" height="281" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe> <p><a href="http://vimeo.com/56798845">Ugly but Effective</a> from <a href="http://vimeo.com/user457842">Enel</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
    Rolling:
    <iframe src="http://player.vimeo.com/video/56798775" width="500" height="281" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe> <p><a href="http://vimeo.com/56798775">Gap Roller</a> from <a href="http://vimeo.com/user457842">Enel</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
    Tight chunk:
    <iframe src="http://player.vimeo.com/video/56778294" width="500" height="282" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe> <p><a href="http://vimeo.com/56778294">Chess</a> from <a href="http://vimeo.com/user457842">Enel</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
    I don't know what happened with the camera on that one.
  26. #326
    The more I ride this bike, the bigger the grin
    Currently sitting at 31.8 lbs
  27. #327
    good thing you have long arms otherwise patting yourself on the back might be more of a challenge for you. thank god for banshee you were a tester. tell us some more about your 2x7 drivetrain, seems the way all the major manufacturers are going 1x10 and 1x11 are so passe
  28. #328
    You must spread some Reputation around before giving it to qbert2000 again.
    And to jncarpenter, that's a very dialed looking Prime! Love it!
    konahonzo
  29. #329
    FM
    FM is offline
    Apr 2003
    JNC, Phat-Ant, Enel, bikes are looking awesome!
  30. #330
    the bikes do look great btw. the graphics look good on the raw, a little to bold on the coloured frames.
    so jnc, how much bettre than the sultan?
  31. #331
    Quote Originally Posted by MartinS View Post
    you can use a cc angleset in the neutral setting or with the offset gimbals too
    AngleSet
    they make a zs44/ec56 model
  32. #332
    AngleSet
    Good (if expensive) find!
  33. #333
    it is expensive, but cheaper than a new fork for someone if they do want to try a 120mm fork or just an extra 10mm in lower stack height
  34. #334
    live long and huck
    Reputation: Optimus's Avatar
    What do you think of your CTD, jn? I wasn't too crazy about mine in the chunk that I ride, tomorrow is test and tune day for my new DBair.
  35. #335
    MTB B'dos
    So, pay $150+ for the angleset to give a 120mm fork a try, which is not what the frame is designed around or take that $150+, sell the 120mm fork and then maybe add a few more $ to get it right Sounds like a great plan to me
    AngleSet
  36. #336
    give it up dude. the link is there for anyone to try if that's the way "they" want to go. if you don't, then don't.
    i think it's retarded to run 2x7 gearing when 1x10 and now 1x11 is dialed, but you are free to continue to do so just like anyone is free to try a 120mm fork if they so desire.
    stop trying so hard to be relevant. it's the internet. no one cares that you recommended a cable boss other than you. who else that tested is here patting themselves on the back about it??
  37. #337
    Well, "better" is obviously relative...in this case, the Prime works much better for me. The Sultan was more of a xc/trail bike...despite all my efforts to make it work for me, I just couldn't get there with it. Mostly we are talking geometry; the Sultan had me feeling like I had too much weight on the front end of the bike. I tried a taller fork, ran the rear shock a tad softer, riser bars....still front heavy. The Prime (in slack setting) feels much more natural to me descending. I like to have my weight on my feet, and move around the bike while standing...the Prime is a superb descender. The faster you push it, the more controlled and solid it feels.
    Also, I initially thought overall stiffness was a wash between the two, but the more time I spend on the Prime it has proven itself to be the more stout feeling chassis (especially with the 150mm rear wheel). Cornering is where you can really feel this...the shorter rear doesn't hurt either.
    All in all, the Banshee has me grabbing a FS for my rides more than ever before. It honestly feels like a fully suspended version of the ByStickel
    Optimus, I am also struggling with the CTD shock. Initially it felt to harsh when setup with proper sag. I removed the white spacer from the air can, and that helped alot with the overall plushness...but now I can easily bottom it if I try. I need to spend a bit of time grinding the spacer down some and try putting it back in the air can before I bail on the Fox. I think an Avalanche Chubby would be a nice match
  38. #338
    Mar 2011
    Just chuck the CTD and get piggyback shock on it.
    Liking my DHX-A on mine.
  39. #339
    beater
    Reputation: evasive's Avatar
    Feb 2005
    Vector HLR Air
    There's always this option, as well. I've been really happy with the performance, and the price is pretty good, too.
    Production Prime Photo/Build thread-xfusionvector.jpg
  40. #340
    First ride out today, The fit is great! Medium seems to be just how I like it so panic over
    Only a short loop 18km or so but all single track trail centre fun fun fun
    The bike handles fantasticly well I had to apply the brakes many times for fear of breaking my self :P
    I Look forward to taking it for a spin around my local bog filled mud pits tomorrow
    Production Prime Photo/Build thread-p1020022.jpg
    Production Prime Photo/Build thread-p1020029.jpg
  41. #341
    phat-ant,
    How tall are you? Stem length? I'm torn between a medium and large.
  42. #342
    Have to agree that the Prime was one of the first bikes I've ridden where the DHX-A didn't feel like crap....
  43. #343
    Hi Colin, its a 70mm Stem and 711mm bars. I am around 5 foot 11 inches. certainly does feel a good fit for my size and shape.
  44. #344
    MTB B'dos
    Good news is, you won't have to worry about mud clearance with the Prime, there's gobs. I would however maybe install a mud guard or two if you ride in muddy conditions often (you live in Britain, so that's a for sure), FM fashioned one for the rear and his drawings in this thread someplace, pretty simple but effective. I made one for the fork and it helps keep gunk off the seals quite well, never installed one for the rear as I don't hold that area as so sensitive as the fork seals and stanchions and never have had to stop to clear it out since owning the Prime despite going through some nasty stuff.
    Quote Originally Posted by phat-ant View Post
  45. #345
    Cheers LyNx. I will be making up some mud gaurds for sure just havent had chance to get any bits to do so yet. We have had the wettest winter on record or something like that, and aside from the odd day here or there its basically been raining for at least a month. Fingers crossed for some cold dry weather to firm up the local woods some what! I will let you know how it gets on after tonight!
  46. #346
    Mar 2011
    I have shimmed seatpost for the first time on my bike, i noticed today the shim length is 5.7cm inside seat tube, is this enough or should i get 10 cm shim?
    The current shim extends easily past the gusset on top tube.
  47. #347
    Missouri sucks...
    I've always been of the understanding that 4", or approximately 10cm, is the minimum you should run for a shim. 5.7cm seems really short.
  48. #348
    FM
    FM is offline
    Apr 2003
    I've seen & owned a few frames that did funky things after having been shimmed. Other frames have no problem.
    One thing to watch out for, using a shim adds another set of tolerances. If the shim diameter is a slightly loose fit in the frame, and the post diameter is a slightly loose fit in the shim, it can have the same effect as running an undersize seat post... you end up crimping the frame at the seat collar.
    If you've got to run one, I'd say get the longest one possible, and "shim the shim" with pop-can to make it a really snug fit. If you're running shim, and will still be adjusting the post height frequently with a QR... that's risky in my experience.
    It could be a non-issue 90% of the time, but I've seen it get ugly once or twice!
  49. #349
    Mar 2011
    It is because of the dropper post comes in 27.2 only larger sizes are done with shims, the fit seems good,on the diameters, the length concerns me now since it does not reach top tube, i only have few rides on it and i don't weigh much so i don't think there is damage done, yet.
  50. #350
    Ok 2nd ride on the prime and for this area it was actually pretty dry considering, but I think I will be making up some rear mud catchers for sure!
    Production Prime Photo/Build thread-p1020044.jpg
    Good fun out in the night though loving it
  51. #351
    Sorry to bump again.
    Still no info about warranty and 150mm (or even 160mm) 29er forks on the Prime?
    I am so tempted to buy one
    Greetings Znarf
  52. #352
    Oct 2011
    Are there 29er forks with 160mm?
  53. #353
    MTB B'dos
    No single crown forks, unless they're prototypes that are being tested. You can get the Dorado, which I think when limited for 29er gets 170mm, but the warranty clearly states no dual crown forks for the Prime. There are the 26" F36 160mm forks with arch mods that some are using, not sure on if travel needs to be limited on those or warranty - Enel is running one on his Prime.
    Quote Originally Posted by Kreisel View Post
  54. #354
    No 160mm "official big brand" 29er forks - yet!
    Ive read several times that one will be released by a big brand in summer 2013.
    @Lynx:
    Maybe I am blind (or stupid), but I cant find warranty information on the prime on the Banshee site. Do you happen to have a link?
    Would be very thankful =)
    Greetings Znarf
  55. #355
    MTB B'dos
    Yeah, I heard that rumor too and I guess at Sea Otter we'll find out - although that was the rumor last year as well though
    On the warranty, guess maybe it's that I've been talking with Keith about the Prime since early days and he's repeatedly stated it's not designed for such a fork and warranty would not cover dual crown forks. Best bet is to e-mail them and ask them directly.
    Quote Originally Posted by Znarf View Post
    @Lynx:
    Greetings Znarf
  56. #356
    Fork limit for the Prime is a 160mm single crown. If you run a double crown, or anything over 160mm then warranty will be void.
    Thanks,
    Keith
    Banshee Blog
  57. #357
    Travel on my 36 fork is limited to 130mm, and A-C is identical to any 140mm 29" fork.
    After riding the Prime a bit I realize probably the only fork on the market stiff enough to match the frame is a Dorado.
  58. #358
    Great,
    Tranks for the Input, Keith!
    That will be my Park bike then :-)
  59. #359
    I rode the Prime Back to back on a well known to me trail loop with my 2010 Stumpy FSR yesterday and it was eye opening.
    These bikes are identical except for:
    Fork: Reba 140 on the Stumpy and modded Fox 36 on the Prime;
    Wheels: 150mm X12 rear with 36 spoke wheels on the Prime compared to 135 bolt on rear and 32 spoke wheels on the Stumpy;
    Drivetrain: The stumpy has stump pulling low range supergranny drivetrain allowing gearing down to 20X26, the Prime is standard 32X22 front and 11/34 rear
    Weight: The Prime is about three pounds heavier between the wheels, fork and frame.
    Terrain was slow chunk/finesse stuff with a section of moderate speed (11-12mph), but very chunky descent. Climbs were similarly short, but chunky and quite steep at times requiring standing bursts and momentum to crest.
    The bikes ride/perform very similarly as they should given the numbers. I was no more capable or faster on one versus the other. This is good to me because I have been very pleased with the Specialized. However: these two bikes/builds could not feel more different from the standpoint of flex and general solidity. The Prime is hands down the stiffest frame I have ever ridden in any category. (Note: No time on serious DH or Freeride rigs).
    The difference is similar to the difference between a thin tubed steel rigid frame and a burly tubed aluminum frame. I felt like I had to have a bit more body english/anticipation of the flex with the Stumpjumper. It was not bad or unmanageable, it just felt completely different. If you have spent any time back to back on a burly longer travel AM bike versus a cross country race type bike, you will know exactly what I am talking about. I think the differences would be even more obvious at higher speeds as the stress on the frames increases.
    The Prime felt simply better planted than the Stumpy in all terrain and conditions. I think I had a wee bit more traction. It wasn't a mind blowing difference, but it was different. I am looking forward to dialing it in more, but I am quite comfortable on the Prime after only two rides.
    I played with the CCDB air and ended up at 25% sag (for me near 200 lbs geared up it was 110 psi), 80% (20 clicks) low speed rebound, 80%(20 clicks) low speed compression damping, zero HSC and about 15% (3/4 turn) HSR damping. After my trail ride, I am going to dial in a touch more HSR and HSC damping. I am getting pretty close.
    I hope to get the Prime down to South Mountain in Phoenix this weekend for a real thrashing.
    For now, I would absolutely recommend the Prime, especially if you weigh over 200lbs and/or have had issues with flex in other 29" frames. I am not sure a lighter primarily XC rider really needs what this frame offers (along with the associated weight penalty).
  60. #360
    Cool!
    I figured you'd dig the uber-stiff chassis of the Prime. Now...if we could only get a suitable fork!
  61. #361
    Cool!
    Agreed. Imagine that. This frame really deserves a production fork worthy of it.
  62. #362
    Mar 2011
    Tomorrow i'm bolting on last XX1 bits, and then i have winter vacation at gravel-pit called Tenerife and a volcano called Teide, last time i was there with prime proto it kicked ass there, now i have 12mm bolt thru axle on rear and production frame...
  63. #363
    <iframe src="http://player.vimeo.com/video/57255279" width="800" height="450" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe>
    I got to ride an extremely fun ride called Goat Camp in Phoenix today.
    It starts with a steady 9 mile 2500 ft climb. The Prime proved a competent steady climber. I finally noticed the mechanical help the suspension gives in the pedaling department: with standing uphill spring type moves, the bike just squirts forward with minimal wallow. Not XC stiff, but it is nice.
    I like that the frame achieves this without so much stiffening that it loses traction on loose stuff. I personally prefer more traction with some pedal bob over great pedaling characteristics with traction loss.
    Anyhoo, it's a decent climber and took care of switchbacks and chunky sections as well as I could.
    The downhill on this ride is relentless, slow, chunky, loose, steep tech for three miles. I hesitate to show the video because it really can't do justice to the terrain. If slow tech is your thing, ride this trail. The Prime had no bad habits I could find under braking and rolling steep things into chunk.
    On the lower 1/2 mile of the descent I was finally able to open it up speed wise on smooth mixed with small chunk and that was a hoot.
    I have officially determined that the Specialized is out of a job. The Prime does everything just as well, and a few things decidedly better.
  64. #364
    live long and huck
    Nice job on Goat Camp, Enel. Doesn't surprise me that you nailed the staircase, considering the type of riding that you typically do. You are right, that video does not even come close to portraying that section accurately. There is a whole lot of serious pucker on Goat Camp.
    I'm finding similar with my newly installed DBair, lots of low speed dialed in, very little high speed, DBair is WAY better than the CTD.
  65. #365
    FM
    FM is offline
    Apr 2003
    Enel, good to hear you're diggin' the bike- especially as I haven't ridden a SJ.
    Good review of the Prime in the new Bike magazine bible. Although I am a little confused by their apparent bias towards 26" trail/xc bikes over 29" AM bikes. Personal preference!
    Just threw a KS Lev 150 on my Prime. Breaking in a new local feature- we tweaked the run-in after this so more speed can be carried (basically fast walking speed shown here).
    <a href="http://www.flickr.com/photos/10323561@N07/8328579256/" title="IMG_4925 by emailsucks98, on Flickr"><img src="http://farm9.staticflickr.com/8219/8328579256_1a52edc489_c.jpg" width="800" height="600" alt="IMG_4925"></a>
  66. #366
    Got mine yesterday, and while a ton of bike is reviewed, I somewhat enjoyed last year's Bible a whole lot more.
    konahonzo
  67. #367
    Finally got time to upload another GC vid from Friday's ride.
    <iframe src="http://player.vimeo.com/video/57295778" width="800" height="450" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe>
  68. #368
    Need more pics in this thread. Keep it up.
  69. #369
    live long and huck
    Good stuff Enel, and FM.
  70. #370
    Production Prime Photo/Build thread-imageuploadedbytapatalk1358120836.804230.jpg
    Big bro versus little bro.
    I bounced a bit on the Rune and it is sweet. Mikey sez it pretty much blows his Nomad away. I am very jealous if the Lyric fork.
  71. #371
    beater
    Feb 2005
  72. #372
    FM
    FM is offline
    Apr 2003
    Thanks for posting that, much more detail than the magazine copy. Good review!
  73. #373
    Nice pictures, nice bikes and beautiful trails!
    @Enel:
    I currently ride a 2011 Stumpjumper FSR Comp 29er, which is identical frame wise to your 2010 as far as I know. I'd be very interested in the weight difference between those two frames.
    You didn't weigh the frames by chance? ;-)
    Does the Prime climb as good at the Stumpjumper?
    Thanks a lot for all the good intel so far!
    Greetings Znarf
  74. #374
    @Enel:
    Greetings Znarf
    Prime climbs just as well and more planted in chunk. I don't know the weight difference. But I imagine it is around a pound. Weight below includes dropouts and CCDBa shock.
    I don't think the Prime will change your life over the Stumpy, but it is a nice upgrade. The lighter you are the less difference you will notice, IMO.
    Attached Thumbnails Attached Thumbnails Production Prime Photo/Build thread-image.jpg
  75. #375
    Yeah, my Stumpjumper is actually doing great. I keep saying to myself that I will "upgrade" in 2014.
    I see some sort of new bike in 2013 though =)
    Greetings Znarf
  76. #376
    Quote Originally Posted by evasive View Post
    They're doing video this year:
    Banshee Prime Review
    "Like Godzilla!!!"
    This would definitely be my first choice for a 29er FS if my terrain called for such a beast.
    konahonzo
  77. #377
    Reputation: 7HVN's Avatar
    Which fork?
    Contemplating a Prime.
    But wondering if it is a major up-grade from a Behemoth with a shaved and modded Fox 36 or a 09 Sultan with a WB F135.
    And...
    Which fork for the Prime: new F34 or the shaved Fox 36 with 1 1/8 steer tube?
    A closer comparo would be the Behemoth to Prime. Geometry is similar. "Major" upgrade? Doubtful. Enjoyable getting something new to play with? Absolutely!
    I had a handful of Devin's bikes, not a Behemoth though, and I think he makes some of the best ones out there especially from a geometry standpoint. The Prime proto I had was such fun that I'm getting a Production model next week. I feel that the major differences would be the adjustable geometry, options for rear spacing and a capability for piggyback shocks. The Prime is a super stiff frame as well much like the Lenz bikes I've owned (Lunchbox, PBJ, Mammoth).
  79. #379
    Mar 2011
    So i did 5 days of riding with the production frame on mt. Teide, which is very harsh terrain, i ran DHX-A on rear and 34's on front and the bike certainly didn't hold me back, my lack of skill riding on loose gravel/upper torso strength was limiting factor for me, DHX worked really well pretty much on all stuff i did on it, high speed double track and technical descents and long climbs (if 500m vertical over 11km is long, it is for me).
    Zero over the bars moments, which is rare there, techier sections of those trails are steep and full on head/tv sized rocks for 5-10minutes per section, could keep up with bigger bikes until i ran out of juice on upper torso.
    Some of the trails had steep climbs which worked great with the XX1, pedal kickback was minimal/nonexistant so rear suspension felt really good when climbing over rough sections, good traction, didn't have steering problems when doing technical climbs.
    Rolling off drops was super fun, easy to lift the front/do little manual, it was fun to jump on small jumps at high speeds also on faster trails.
    Overall, very happy with the frame and i think it is a keeper.
  80. #380
    Reputation: highrustler's Avatar
    sizing
    Anybody with a Prime on the CO front range? I am in between a MED / LRG and need to throw a leg over one. Currently on a Large Tallboy LTc which is a perfect fit.
  81. #381
    May 2012
    Quote Originally Posted by highrustler View Post
    I also tried a L LTa for a few days which had a very good fit. I went for the M Prime. If you compare the geo specs the reach from the L LTa(c) is nearly exactly as the one from the M Prime. I think the largest difference is the seatpost angle ... but you can move your seat some cm so it should be fine.
  82. #382
    Reputation: filbike's Avatar
    Quote Originally Posted by 7HVN View Post
    36 with 29"rims???
    can you explain me??
  83. #383
    Reputation: zoorlen's Avatar
    Quote Originally Posted by filbike View Post
    36 with 29"rims???
    Modded Fox 36
  84. #384
    ..can't believe it.
    I thougth about that alteration a few days ago, but I soon realized it was a crazy thing.
    ...and now I see out there people riding happily shaved 36!!!
    ..just thinking something insane about my VAN 36
  85. #385
    Just got my size Large Yellow frame in today from Chad @ The Barn and the color is absolutely killer in person. I'll try to get some pics up tomorrow. Build weight came in at 31.92lbs with 150mm rear, CCDB and Hans Dampfs. I was surprised it was that light.
    P.S. - Chad @ The Barn is great to deal with and I can't recommend him enough. I'm in Georgia but I might has to make a little shop in Montana my new LBS.
  86. #386
    beater
    Feb 2005
    That is light!
    It is impressive what Chad has been able to do outside a town that's small even by Montana standards.
  87. #387
    FM
    FM is offline
    Apr 2003
    Bring on the pictures!
  88. #388
    May 2012
    Quote Originally Posted by zoorlen View Post
    Would this also work, maybe even better, with some 650b Fork?
  89. #389
    Let's see the yellow Colin!
    konahonzo
  90. #390
    Quote Originally Posted by pinkey View Post
    I read somewhere that the 36 arch fits some (most?) 650b tires... but I don't know if you have to limit the fork travel to avoid contact between tire and crown. I bet someone in the 650b forum can give you a more precise answer.
  91. #391
    The yellow hotness is coming this afternoon as soon as I get home from work.
  92. #392
    beater
    Feb 2005
    Looking forward to it. Probably not as much as you are, though.
  93. #393
    The sun was going down so these pics don't really capture the color all that well. I still have some cable trimming and steerer trimming to do as well.
    This bike is the epitome of "in the bike" feel to me. Very pleased.
    More pics to come.
  94. #394
    FM
    FM is offline
    Apr 2003
    Hell yeah that looks awesome
  95. #395
    I love that yellow!!!! <3
    konahonzo
  96. #396
  97. #397
    I am getting along well with the Prime. I have had some short tech sessions and a longer climbing/descending singletrack ride. I noticed the weight toward the end of the longer ride, but that is more fitness than anything.
    The CCDB air shock is pretty remarkable. It will allow you to tune it to pretty much whatever you want. I went too firm, then I went too soft on the low speed damping. In the soft setting, the little stuff just disappears. The shock becomes more sensitive to small hits than I thought possible. In the firm setting, it stays firm until the hits go beyond the low speed threshold and then it smooths right out. Right now the settings are pretty dang close to the Banshee factory recommended settings.
    I don't really notice the suspension. If I go light on the LSC/LSR, I will notice the shock shaft bobbing 3mm if I look at it. This is from the reciprocating mass of my legs or body if I stand. I don't notice that pedal input makes the suspension do much if anything at all. I don't notice the suspension under braking, I don't notice it pedaling through chop. That is good.
    I did blow through all the travel and bottom the shock many times today going off the 2-3ft drops noted in photos above. Never once did I feel it, I just noticed the O-ring was maxed. I have 25% sag right now and am reluctant to add any more air or compression damping. I think I am going to add one of the thingies to reduce air volume to the shock. My friend with the V2 Rune/CCDBa just put the biggest spacer in and it seems to be working well for him.
  98. #398
    Reputation: helimech's Avatar
    Mar 2006
    Looking good Enel .
    SHITBIRD
  99. #399
    FM
    FM is offline
    Apr 2003
    Yeah good stuff Enel.
  100. #400
    <iframe src="http://player.vimeo.com/video/58234027" width="600" height="337" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe> <p><a href="http://vimeo.com/58234027">Prime</a> from <a href="http://vimeo.com/user457842">Enel</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
