Results 1 to 12 of 12
    The Mountain Bike Life
    Reputation: mudpuppy's Avatar
    Prime + Fox Float CTD Trail Adjust settings?
    Just put my new Prime together (photos in a few days) and am wondering how others with the float CTD shock have them set up. How much sag and what trail settings are you using?
    Mar 2011
    Quote Originally Posted by mudpuppy View Post
    23-25%ish, i ran 130 psi but i was bottoming out on ditch crossings and drops to flat, i got 150 psi on back now, it still soaks small bumps quite good and climbs great.
    MTB B'dos
    Reputation: LyNx's Avatar
    Not sure if you saw the small discussion in the big Prime production thread, but Keith chimed in with the correct SAG in MM for a given percentage, basically 25% SAG= 13mm and around 15mm was 30%. Was going by percentage of the shafts length, but the compression curve isn't constant, so that's not right, ended up putting in about 15 PSi more in my shock for 25% SAG and like the change.
    Thanks for the help guys...getting it dialed now. Feel clunks in the rear once in a while...trying to narrow that down now. As well it seems my trail adjust knob is stuck...can't seem to move it and done tons of google searches to see if I am just missing something simple...anyone else have that issue. Maybe my girly fingers just can't get enough grip on it...lol.
    Mar 2011
    You need to lift the trail adjust collar to make it turn.
    Haha....see I thought I tried that and it didn't budge...decided to try it again after reading this and boom....man I feel like an idiot. Thank you Sakucee.
    Mar 2011
    You are not the first one asking this, trust me
    Haha, I had the trail adjust turning issue when testing a proto last year... thought I needed to man up! Yeah, wasn't imediatly obvious, and back then I didn't have many resources to help work it out... embarassingly my girlfriend solved it after I had made my finger bleed trying to turn it! D'oh
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
    hahahahahahaha
    Hah, thank god I am not the only one. Good to see you around Keith...don't see you on the boards that much lately...must be a busy guy (can't wait to see what you are working on).
    I have been very busy with work over last few months, but I took last week off to de stress and get some sun and fresh air. Back now tho feeling fresh and working hard.
    Banshee Blog
    Well man, it's good to see you back. Hopefully you got some riding in. I am LOVING the prime so far...damn fun bike. Thank you!
  1. Fox 34 float travel adjust help
    By Rick Draper in forum Shocks and Suspension
    Last Post: 12-16-2012, 12:13 PM
  2. Adjust Rebound on Fox Float 29???
    By Edcft in forum Shocks and Suspension
    Last Post: 10-12-2012, 03:08 PM
  3. Replies: 0
    Last Post: 07-02-2012, 07:28 PM
  4. Replies: 16
    Last Post: 03-16-2012, 11:18 AM
  5. Float 170 settings
    By Mt.Biker E in forum Pivot Cycles
    Last Post: 07-16-2011, 08:16 AM
