FAT BIKES
WINTER APPAREL
TRAINERS
Page 18 of 29 FirstFirst ... 8 14 15 16 17 18 19 20 21 22 28 ... LastLast
Results 426 to 450 of 705
  1. #426
    Reputation: Mr. 68 Hundred's Avatar
    Day one of build done...need more parts
  2. #427
    Reputation: DanoXC's Avatar
    Dec 2009
    Hey Guys
    Just got myself a Banshee Paradox V2 frame and I'm in the process of building her up.
    Ive got all the parts except the Fork.
    Im gunna have full XT 10 speed drivetrain with SLX brakes,Sunringle Black flag pro wheelset,fat tyres short stem and wide bars. Plus I might use either a reverb or KS dropper seatpost.
    About the fork im not sure what to get.
    Ive narrowed it down to these three.
    # rockshox Sid RCT3 120mm
    #Fox Float 29 120mm CTD
    #Manitou Tower pro 120mm
    All are a 2013 model and have a tappered steerer and a 15mm thru axle.
    Im not concerned about the price Im just after the best matching one for this bike.
    What do you guys think would be best?
    My riding style is more on the aggressive side of XC but Im not a very heavy guy only weigh 160 pounds. I like to pop off all manner of terrain and often hit 2-3 foot drops. This bike will be my "XC' bike.
    I have a 6 inch dually that I use for the more rocky technical stuff.
    Attached Thumbnails Attached Thumbnails Paradox Updated for 2012-photo1859.jpg
  3. #428
    MTB B'dos
    Reputation: LyNx's Avatar
    I'm not cheap, but I don't like paying more than I need to for a product, hence out of those I'd say the Tower (Minute) would be my choice - loads of clearance in the arch, great damepening, much lower price tag than the others. This being said I'd also suggest you check out the X-Fusion stuff, for great bang for your $$. The new TRACE fork comes with 34mm stanchions and a slick ano coating, can be run anywhere from 140mm down to 80mm through internal travel adjust or you can get an external DLA model to do 140/110 and there's even a Uni-Crown version for a bit more $$, which should shave a bit of weight an eliminate any possibility of a squeaky crown/steerer interface. First Look! 2013 X-Fusion Forks, Hilo SL Dropper Post and the 165g Microlite Rear Shock! - Bike Rumor
    Quote Originally Posted by DanoXC View Post
    Hey Guys
    MTB Barbados
    My Phantom pics
  4. #429
    Dec 2009
    Hey LynX
    Thanks for the quick reply mate.
    Yeah, the X-fusion Trace forks were my original choice but my Bike parts supplier informed me that prodution models have been knocked back further. So theres no proper estimated time for release.
    I was steering towards buying the Manitou Tower fork because ive read nothing but glowing reviews on them but they just didnt have the fancy big brand name behind them.
    But at the end of the day its all about the performance on the trail and with the cash I'll save I'll probably get a dropper post.
    Cheers,
    Dan
  5. #430
    Waiting (impatiently) for spokes/nipples now
  6. #431
    Dec 2012
    Re: Paradox Updated for 2012
    Mr 68 and danon, looks like both of you have some awesome builds going. I got a complete build but just put some bling on it. Check pics from stock to now, pretty happy with how she looks for now but have a couple small ideas. Red zips for cable housing, removing rim stickers....
    Danon the tower rocks, im 195lbs use it for racing xc and hit drops up to 4ft so far no problems. Anno red cap might not go with your blue theme tjough...
    Sent from my GT-I9100 using Tapatalk 2
  7. #432
    Dec 2012
    Danon the tower rocks, im 195lbs use it for racing xc and hit drops up to 4ft so far no problems. Anno red cap might not go with yout blue theme though....
    Attached Thumbnails Attached Thumbnails Paradox Updated for 2012-uploadfromtaptalk1360255004598.jpg
  8. #433
    Nothing wrong with the Manitou Tower 120mm.
    Check out my build pictures.
    Parodox build tips please - Page 2
    I just got a set of wide Blackspire riser bars in PC white. I think I will cut them down the same width as the current Race Face bars which are pretty much the right width.
  9. #434
    Reputation: GTscoob's Avatar
    Snagged a ver2 Paradox the other day, starting to stockpile parts for the build but really just need a front fork and front wheel that will take a thru axle.
    Looking like it's going to be the same mixed XT/X9 build that I've got on my Access9r, Thomson cockpit, Truvativ boobars. Went really cheap on the Access build to see if I'd dig 29ers so having a nice new frame will no doubt further the upgradeitis.
  10. #435
    Dec 2009
    Bike looks great Steineken. I see alot of guys running the Tower forks on the Paradox but I think I'll try something different. I'm gunna go with a 2013 Rockshox Sid RCT3 120mm.
  11. #436
    XTR FD-M986-D (direct mount 2X10) rubs bad with 2.35 Nobby Nics. Plenty of frame clearance though.
    Any ideas/confirmed 2X10 Shimano FD's that work?
  12. #437
    Reputation: Ronnie's Avatar
    Quote Originally Posted by Mr. 68 Hundred View Post
    I think I've posted this picture before. I've got a XT 786 with a Nobby Nic 2.25. I cut the arm for bottom pull fitting of with a Dremel and there is sufficient space. I've never tried a 2.35 on the back. I'd like to but is does look a bit tight. Not so much in the frame but as far as the derailleur spacing is concerned.
    The trouble with having an open mind is that people will insist on trying to put things in it.
  13. #438
    Thanks Ronnie for the quick response. I just cut the arm off the derailleur and now the center knobs have plenty of space but the side knobs are still hitting the coil spring/spring cover around the lowest pivot. I thought about cutting off/down all the right side knobs but figured there might be a time or two I'd like to turn right.
    I definitely want to keep the 2.35's, and I wouldn't mind having space for the new 2.5" Minions for rough trails. 99% sure I'm going to just suck it up and go 1 X 10. I'm bummed about loosing the range I would have gotten with the 26/38, but I think I'll be able to live with a 32T.
    Maybe I can give up 2.35's on the Paradox when I get my 6" full squish...
    Proponent for an Evidence Driven Life.
    Occupation: Disposable gene transfer machine
    Current HTFU status: 4/10; increasing
  14. #439
    MTB B'dos
    I suggest that if you're running an external BB crankset to just add a 2.5mm spacer to the drive side to space the cranks out further and give the FD a bit more room. If you're running a double there's absolutely nothing bad to this as it will actually improve the chainline for the 2X setup, if it's a tripple will have to watch you Big Ring combos for cross chaining.
    Also if I'm not mistaken, some of the 2X specific cranksets already have this built it to put the spiders further outboard, think SLX.
    The new Direct Mount FD design helps in some ways, but hinders in others. I have the original Paradox and am using an old XT M750 FD and it has decent clearance with the 2.55" WW LT outback, I also do the extra 2.5mm spacer thing as well which adds a bit more.
    MTB Barbados
    My Phantom pics
  15. #440
    Wheels? Done.
  16. #441
    Thanks LyNx!
    Edit:
    ~26.5 pounds minus front 180 rotor, rear 160 rotor and a missing chain.
  17. #442
    Pucker Day is officially over.
    Took 4" off the front brake line, 9" off the rear, final cut on the steerer tube and took 6 cm off my bars. First time doing hydraulic lines and first time cutting carbon; thus the name Pucker Day.
  18. #443
    Reputation: Helmetless's Avatar
    We expect proper final pics!!!
    Banshee Paradox V2
    Santa Cruz Tallboy LT
  19. #444
    Quote Originally Posted by Helmetless View Post
    Will do; hopefully by next week; waiting on saddle and front chainring.
  20. #445
    MTB B'dos
    Curious how those carbon bars feel when you get your Prime built. What other bars have you ridden, carbon or alu? I ride the FUNN Fatboy bars on my 2 bikes and find they're super stiff, feel no flex at all, but I did a little ride around on a SJ FSR S-Works and could immediately feel that carbon flex under my paltry 170lbs. Expect the Enve would be a lot stiffer than those SpecialED bars.
    MTB Barbados
    My Phantom pics
  21. #446
    Dec 2012
    Thanks danon. The sid will probly save you some weight and the black/ano blue will lool sick on the polished frame. Look forrward to pix
  22. #447
    1) Various aluminum bars from the early 90's and later. No real issues but we didn't know anything then.
    2) Scott thermopastic/carbon CC bars; very strong (I think fatigue cycles was their best feature) but noodle like flex; hated them. Didn't realize what the problem was until I got something stiffer.
    3) Replaced them with a mid-range aluminum AM bar, might have been an Easton product. Seemed fine, especially coming from the noodle bars.
    4) Holzfeller's on my STP. These bars I do like and would have been more than happy to put them on this bike but kind of got the ENVE carbon buzz and their bars is what I could afford. I too am looking forward to comparing the ENVEs to the Truvativs. When I bought the ENVEs, I basically assumed they're strong and stiff because Santa Cruz races with them. We'll see.
    Steve
    Edit: Ok, so when you live in BFE, it takes the better part of 2 weeks to get stuff from England; even when paying for DHL delivery. "5 minutes Turkish..."
    Last edited by Mr. 68 Hundred; 02-15-2013 at 06:55 AM. Reason: I live a million miles from no where
  23. #448
    Dec 2009
    Quote Originally Posted by Steineken View Post
    No worries mate.
    But Ive changed my mind and bought a different fork. I got a really good deal on a 2012 Marzocchi 44 Micro TI 120mm fork. Im instaling them tomorrow. Will post up pics once complete.
    So ive actaully bought the heaviest 29er fork of the lot. Lol, I hope its plush atleast.
  24. #449
    Commence reactor powerup...
    ...so I can do a proper shakedown run. Need the snow (trail snow, not driveway snow) gone first though :| Anyway, all the parts are installed and it's ready to go; maybe a little tweaking of the chainline left so I might be ordering some longer chainring bolts, but I don't think so. Possibly will be fabricating a chain guide; depends on how well Shimano's clutch works.
    I've only ridden it for a couple of blocks and it seems OK; nothing bad or weird. I've been riding an STP for a couple of years and it seems very similar; just with the big wheel feel and a not-so-cramped cockpit.
    Especially happy about finding the saddle. Couldn't find it anywhere and it appeared to be simply unavailable. Bel-Air with titanium rails in brown straight from CRC along with the Hope IBR (or was it PBR; can't remember). B*tchin'.
    On a side note, I don't know if there's going to be space to run the new Maxxis 2.5" DHF's. Chainstays and seatstays have room but I'm literally 2.2 mm from hitting the seat tube/direct mount with 2.35" NN's. If I hadn't just set them up tubeless, I'd throw the HD on the back to check clearances.
    27 pounds even (+ .1 pounds)
  25. #450
    Nice bike up there!!! that saddle is really cool. Matches with kashima coat pretty well
    Banshee Paradox V2
  1. 2012 Trek Wahoo VS. 2012 Specialized Hardrock
    By smoothie7 in forum Beginner's Corner
    Last Post: 03-18-2012, 11:31 AM
  2. 2012 trek slash 9 vs 2012 remedy 9.8 or 9
    By Demorider in forum Trek
    Last Post: 01-20-2012, 12:51 AM
  3. 2012 Marin T3 XM8 or 2012 Scott Genius 20 ??
    By A2k Mike in forum Bike and Frame discussion
    Last Post: 10-01-2011, 04:12 AM
  4. Rocky has updated their site for 2012
    By powriderkevin in forum Rocky Mountain
    Last Post: 09-03-2011, 11:42 PM
  5. Updated R2R website with updated trail conditions
    By flipnidaho in forum Idaho, Montana, Wyoming
    Last Post: 01-02-2008, 03:07 PM
Follow MTBR on Facebook
