Results 1 to 6 of 6
    Reputation: darkslide18's Avatar
    Monarch Plus RC3 Tune
    I'm going to be swapping out the Fox CTD shock on my Rune V2 for a Rock Shox Monarch Plus RC3. Just wondering what tune I should get. I'm pretty sure its the mid tune but I am not quite sure.
    Mid tune is best suited for average rider weight. If you are a light rider (under 70kg) then low would also probably work for you.
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
    Quote Originally Posted by builttoride View Post
    Thanks! I'm 185 lbs kitted up so Ill go with the mid tune. Ill probably end up getting one of those rubber band kits that go in the air can to tune the volume to my liking.
    krj
    krj is offline
    Reputation: krj's Avatar
    Aug 2005
    Quote Originally Posted by darkslide18 View Post
    Let us know the result of your upgrade because is on my list too.
    Quote Originally Posted by krj View Post
    Well, Id like to but it happens that I acquired a new CC DB air for a way better deal than the Rock shox. Couldn't pass it up.
    krj
    krj is offline
    Aug 2005
    Which how is required to install a monarch plus ?
    Is the same of the factory instaled fox ctd ?
    Or are the same db air cs published size ?
  1. Which tune do I need for the Monarch Plus?
    By El Chingon in forum Ibis
    Last Post: 07-06-2012, 03:01 PM
  2. Monarch Plus tune for HD?
    By MK_ in forum Ibis
    Last Post: 04-24-2012, 05:49 PM
  3. What Monarch Plus Tune for WFO?
    By SinglePivot in forum Niner Bikes
    Last Post: 01-16-2012, 10:38 PM
  4. RS Monarch, Monarch Plus, Vivid tune diagram
    By Breal604 in forum Shocks and Suspension
    Last Post: 11-05-2011, 05:15 PM
  5. Monarch RT3 - High Tune vs H3 Tune?
    By madtrix in forum Shocks and Suspension
    Last Post: 07-26-2011, 06:42 PM
