Results 1 to 6 of 6
    Manitou Nixon Elite 160mm on a rune
    Is anyone else running this and if so can you post your weight and what PSI you are running please.
    Thank you.
    Hi have this setup and with a Fox DHX Air 5.0. I run the Nixon at 70psi and the rear Fox shox at 140psi or so with 200+ in the boost valve. I weight 182lbs, probably 190lbs with gear.
    I like the Nixon mostly, nice and plush, good low weight and its pretty stiff. Though I would prefer a fork with travel adjust as I find it a tall fork for low speed tight technical turns.
    Cheers,
    G
    Graham Seaman
    Vice President
    Toronto Off-Road Bicycle Association
    Reputation: GearTech's Avatar
    Quote Originally Posted by cracker77 View Post
    Cheers,
    G
    Not to derail the thread but those shock pressures sound way off. I'm only a little heavier than you and I run ~200 in the main chamber and 150-160 in the piggyback. I'd be running about 60% sag at 140 in the main chamber...
    I'm not sure what to say here. Those are my pressures, they give about 20% sag since I ride trail mostly and it feels lively and eats the big hits.
    Are you running the same shock? Mine has ProPedal too...
    Perhaps its personal preference.
    Graham Seaman
    Vice President
    Honestly, just looks like the numbers are backwards...transposed or terminology off?
    Quote Originally Posted by CharacterZero View Post
    That's what I was thinking too. I run 210 in the main and 150-165 in the pig depending on the trail and I weigh 210.
  1. Manitou '08 Nixon 160mm
    By TNC in forum Shocks and Suspension
    Last Post: 07-19-2011, 07:25 PM
  2. Swap springs Nixon Elite TPC+ 130-160mm
    By Monglo in forum Shocks and Suspension
    Last Post: 04-23-2009, 03:25 PM
  3. manitou nixon elite??
    By GhisalloWheels in forum Shocks and Suspension
    Last Post: 12-01-2007, 03:47 PM
  4. 07 Nixon Elite 160mm anyone?
    By scrublover in forum Shocks and Suspension
    Last Post: 09-06-2007, 06:22 AM
  5. Manitou Nixon Elite
    By Uumske in forum Shocks and Suspension
    Last Post: 08-25-2005, 11:45 AM
