Results 1 to 7 of 7
    Legend Mk2 bearing sizes?
    Simple Question, what are the sizes/types of the bearings of a Legend Mk2?
    Wanted to order some new ones, but my bike is out of reach at the moment - by a few hundred miles unfortunately.
    From Banshee manual:
    Look at the torques because they are quite small and you can simply overtorque pivots.
    Main pivot (by BB) 6202-2RS 10Nm
    All other pivots 6001-2RS 8Nm
    We recommend only using INA or *** grade bearings for best performance and longest life.
    Thx!
    Reputation: ryan_daugherty's Avatar
    15x35x11?
    15-ID, 35-OD, 11-width symbol 6202, there are two ones in main pivot
    12-ID, 28-OD, 8-width symbol 6001, there are six in other pivots
    Remember about torque spec mentioned above in my first reply.
    Hope that helps.
    Can someone share the Owners manual (pdf)?
    I want to know how to remove the linkage axles.
    Quote Originally Posted by warrens View Post
    Look at the exploded view on the Banshee Bikes page, Technology section.
    It's always axle from the left side secured by a bolt from the right (with the black bearing covers).
    Just undo the bolts and caps and tap the axles out to the other side.
  1. Replies: 5
    Last Post: 09-05-2012, 10:14 PM
  2. Need help with hub bearing sizes.
    By glouden in forum Wheels and Tires
    Last Post: 05-23-2012, 07:36 AM
  3. RZ 120 bearing sizes ?
    By butroid in forum Cannondale
    Last Post: 08-29-2011, 01:28 PM
  4. Bearing sizes
    By NTZeek in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-27-2011, 03:39 PM
  5. Ibis Mojo bearing sizes
    By MK_ in forum Ibis
    Last Post: 02-09-2011, 09:11 AM
