Results 1 to 2 of 2
    Calm like a Bomb
    Reputation: stunzeed's Avatar
    Legend Fox RC4 Settings
    Just got a legend with an RC4, anyone have some good recommended stock settings? I generally like to run more on the softer side, about 185# with gear
    It came with a 300# spring, I generally have been running 350 on most of my VPP bikes. Thinking a 300 will be too soft.
    Any tips you guys have on spring selection would be helpful
    350# spring might be right, but if you like it on the softer side, the 300# spring might be just fine... probably, you will end up with a 325# spring.
    I use the 350# spring with 210# weight fully kitted... and I like it a lot this way... of course I have to run a liottle more progression and compression damping.
    But it is on the soft side for me, and I might go up to a 375# spring.
    Hope that helps.
  1. The Man / The Legend
    By DIRTJUNKIE in forum Off Camber (off topic)
    Last Post: 03-09-2016, 03:40 PM
  2. Legend + Angleset
    By norbar in forum Banshee Bikes
    Last Post: 07-24-2012, 07:40 AM
  3. Legend size
    By henry 8 in forum Banshee Bikes
    Last Post: 12-13-2011, 06:15 AM
  4. Bushings for Legend MK I
    By legendMKI in forum Banshee Bikes
    Last Post: 03-21-2011, 11:35 AM
  5. My Legend
    By PeterLucas in forum Banshee Bikes
    Last Post: 01-10-2011, 11:32 AM
