    Learn me…what headset for Rune V.2 and a 170mm tapered fork?
    I’m old and confused. I’ve been using the same Cane Creek XX 1.5 Straight for about 10 years and 3 different bikes. Things have changed.
    So many options and price range is huge. This zero stack vs ? angle set vs, tapered headset vs non tapered vs straight steerer vs…. has be confused.
    I read through the build pages but didn’t see much / anything about headset.
    Any suggestions on which to use without breaking the bank?
    Does anyone have a maker/model number or something that they’d suggest?
    Feb 2013
    It uses 44mm top and 56mm bottom zero stack headset. I'm going for the cane creek 40 for mine which seems to be a solid budget headset.
    Thanks.
    All the zero stack / angleset was confusing.
    I take it the one your are getting is a normal headset and not an angleset.
    I think I had narrowed mine down to what you have.
    Feb 2013
    Correct no angle set, pretty confident I'll be happy with the geometry options as they are.
  1. 1.125 fork in a tapered headset
    By AustinF in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-05-2012, 12:00 PM
  2. 1.5 tapered fox fork which headset?
    By dealy663 in forum Turner
    Last Post: 06-30-2012, 09:23 AM
  3. Need a lower headset cup for a tapered fork
    By epoch2k in forum 29er Components
    Last Post: 04-15-2012, 06:55 PM
  4. Tapered fork in 1.5 headset
    By vcnzone in forum All Mountain
    Last Post: 03-01-2012, 11:31 AM
  5. tracer + tapered fork. What headset?
    By pitch08 in forum Intense
    Last Post: 03-15-2011, 07:19 PM
