• 03-15-2013
    Birdman-X
    Learn me…what headset for Rune V.2 and a 170mm tapered fork?
    I’m old and confused. I’ve been using the same Cane Creek XX 1.5 Straight for about 10 years and 3 different bikes. Things have changed.
    So many options and price range is huge. This zero stack vs ? angle set vs, tapered headset vs non tapered vs straight steerer vs…. has be confused.
    I read through the build pages but didn’t see much / anything about headset.
    Any suggestions on which to use without breaking the bank?
    Does anyone have a maker/model number or something that they’d suggest?
  • 03-18-2013
    ironxcross
    It uses 44mm top and 56mm bottom zero stack headset. I'm going for the cane creek 40 for mine which seems to be a solid budget headset.
  • 03-18-2013
    Birdman-X
    Thanks.
    All the zero stack / angleset was confusing.
    I take it the one your are getting is a normal headset and not an angleset.
    I think I had narrowed mine down to what you have.
  • 03-18-2013
    ironxcross
    Correct no angle set, pretty confident I'll be happy with the geometry options as they are.
