Results 1 to 6 of 6
    unrooted
    Reputation: unrooted's Avatar
    Hose Shortening Req'd for XL Prime???
    I'm getting my XL prime frame in the mail today!!!
    I am currently riding an xl Transition Transam29 w/avid elixer cr brakes, a friend of mine said he's never been able to use the same hose on a hardtail as a FS frame.
    I just ordered a set of XT brakes, how much do you think I"ll have to shorten the hoses? Can it be done without the bleed kit?
    Is a bleed kit even required? I watched the Pinkbike video and they didn't use any of the items in the kit, except mineral oil.
    195 lbs-6'4" Banshee Prime XL
    Ride Mammoth, Tahoe & Vegas
    PLEASE GIVE ME NEGATIVE REP!
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    Quote Originally Posted by unrooted View Post
    You can often get away with not bleeding, if you are VERY careful to not squeeze the levers or move the pads while cutting the hose and re-inserting the barb & olive.
    On an XL I'd be surprised if you had to cut them.... (what would I know, riding a medium!)
    CP
    Reputation: C.P.'s Avatar
    I had to shorten the hoses with new in box XT brakes when I built up my XL Prime.
    This link helped even though the brakes are newer than the ones shown in the pdf.http://www.shimano.com/publish/conte...20Trimming.pdf
    MTB B'dos
    Reputation: LyNx's Avatar
    Where did you get the XTs from and did they list the hose lengths? I got mine from CRC and they came at the max length I've seen for XTs, 1000mm front and 1700 rear and I had to shorten mine about 3" on the front and 2-2.5" for the rear on my XL Prime. I didn't bleed mine after shortening the hose and they've worked fine, but I do use Hopes method when reinserting the hose and gently squeeze the lever until I see fluid start to appear/coming out the reservoir and then push the hose in, think it helps not get any air back in the system.
    unrooted
    Lynx,
    What width handlebar do you have? I'll probably just run extra long hoses until I get my new handlebar, stem and bleed kit.
    MTB B'dos
    785mm on a now 60mm stem, was running a 70mm stem when I set them up. If you're going to be running a wider/narrower bar and/or shorter/longer stem, then it's best to wait and set the length with the new parts. You should be fine with them stock length if like mine they're the full length hoses, just be a bit "baggy", if they're shorter you may not even need to cut them. Measured them for you, Front=830mm/ Rear=1480mm. Pic attached.
    Lynx,
    Attached Thumbnails Attached Thumbnails Hose Shortening Req'd for XL Prime???-dsc_4751.jpg
  1. Shortening hose on Shimano XT BR-M785
    By countgrover in forum Brake Time
    Last Post: 12-02-2014, 03:31 AM
  2. Loan me a Shimano hose shortening block?
    By head in forum Brake Time
    Last Post: 06-05-2013, 09:28 AM
  3. Mineral oil hose shortening w/o bleeding ?
    By keen in forum Brake Time
    Last Post: 06-20-2012, 04:26 AM
  4. Bleeding Elixir 3s and shortening hose.
    By JonathanGennick in forum Brake Time
    Last Post: 08-19-2011, 05:55 PM
  5. 2012 slx hose shortening problem
    By xpander in forum Brake Time
    Last Post: 08-08-2011, 04:55 AM
