Results 1 to 3 of 3
    Front derailleur for Wildcard?
    I have a 2009 Wildcard and was wondering if anyone knew what type of front derailleur to run for a 2x10 setup? A high or low clamp front derailleur?
    I've looked on the forums and Banshee website and haven't found any specifics.
    Thanks to anyone who can fill me in.
    Reputation: amrayo's Avatar
    High clamp, top pull
    But why have a front derailleur at all?
    try going 1-10. if you have SRAM crank, you can fit 30T chainring and with 11-36 cassette you should be fine
    I do have the option of 1x10 w/31 tooth (custom Homebrewed chainring) on a shimano XT crank, but at 35 lbs of bike I'm better off with as high a gear as I can get for some of the climbs around here.
    SRAM xx1 would solve my problem, but the set up is way too exoensive. I'm trying to make do with the parts I currently have rather than buy new equipment at today's prices. Which are outrageous nowadays!
    Thanks amrayo. I assumed it was the high clamp and wanted to be sure.
  1. Replies: 1
    Last Post: 07-11-2013, 06:16 PM
  2. 3x9 front derailleur on a 3x8 setup (to solve rockhopper 29 front shift issues)
    By samandkimberly in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-15-2013, 04:37 AM
  3. will 2x10 shimano m980 xtr front shifter work with sram xx front derailleur?
    By gideon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-01-2012, 06:28 AM
  4. what front derailleur do i have?
    By t_roy in forum Specialized
    Last Post: 05-08-2012, 06:24 PM
  5. Wildcard with 180 in front, need help
    By endlessrider in forum Banshee Bikes
    Last Post: 10-31-2011, 04:42 AM
