Results 1 to 2 of 2
    dft is offline
    Reputation: dft's Avatar
    does Elka Ti coil fit on RCX shock
    whoops, mistype in the title, i meant DHX fox shock.
    my friend has an elka shock, he will sell my the Ti spring from it, will that fit on the DHX (its on my rune)? Thanks
    Gloworm Lights
    Reputation: Gloworm Manufacture's Avatar
    The dimensions of the Elka and Fox shox are nominally the same. Meaning that if a spring was used successfully on an Elka it should work on the DHX. The Ti spring that you are looking at is likely either a RCS or DSP spring (sold by Elka as compatible). Dimensions of these products can be checked on their site. I recommend you check the Internal and External Diameter of the spring and make sure it is compatible with the Fox before diving in.
    Gloworm Performance Products
    ELKA Agent in New Zealand
    Gloworm Lights - 'Create Your Escape'
    High End LED Light Designer - New Zealand
  1. Manitou coil for Elka?
    By darkslide18 in forum Banshee Bikes
    Last Post: 08-26-2011, 09:52 PM
  2. Elka Coil Compatability
    By TylerDCA in forum Shocks and Suspension
    Last Post: 04-07-2011, 07:07 AM
  3. El Jefe Ti coil on a Elka, will it fit?
    By nightnerd in forum Shocks and Suspension
    Last Post: 03-03-2011, 11:31 AM
  4. Push my DHX 5 coil or upgrade to Elka Stage 5?
    By aaron81fire in forum Shocks and Suspension
    Last Post: 03-13-2010, 08:54 PM
  5. Elka shock for 951 ?
    By Freeride777 in forum Intense
    Last Post: 01-06-2010, 11:30 AM
