    Towlie for prez
    Cane Creek DB Air/Prime help please....
    I recently purchased a Prime w/a DB Air shock and have been driving myself crazy trying to get it working well. I used the Rec settings on Cane Creeks site, been making tweaks, but it continues to feel harsh and not very responsive. It also bobs a lot when climbing, grrr!
    Does anyone have any suggestions? TIA!!
    No Clue Crew
    Apr 2005
    Is it the factory DB Air CS with the XV can? I don't like it much and swapped on a DVO Jade.
    On the CCDB, I found it to be a touch harsh, but mostly over compressed. No bobbing issues for me, but I like active suspension on a bike like this. I've been experimenting with dialing both the LSC and HSC back significantly. I've got LSC down to about a quarter-turn from full CCW. I'm 3 clicks back from the stock tune on HSC with plenty more to go. Maybe try running less sag (from the 15mm suggested) and really dial back the compression.
    Just like a raindrop, I was born to fall.
    Towlie for prez
    Thanks for the intel Blatent! l made your suggested changes and the shock is much improved, esp over fast chunky terrain and landings. Still a bit harsh on slow speed chunk, but I will adjust lsc a bit and see how that goes.
    live long and huck
    Reputation: Optimus's Avatar
    Using the HV can, recommended sag, 210-215 lbs geared, I run my HSC 1/4 turn from wide open, LSC maybe 1/2 turn ccw from middle way, bike is a marshmallow at low speed or high, gobbles up everything.
    Low and slack.
  1. M9 - Cane Creek or Fox RC4
    By sproglad in forum Intense
    Last Post: 10-19-2011, 10:56 PM
  2. SS2 Cane Creek help
    By kntr in forum Intense
    Last Post: 06-15-2011, 11:27 PM
  3. Roaring Creek is Prime, I tell you, Prime
    By bear in forum Pennsylvania
    Last Post: 06-12-2011, 01:02 PM
  4. Cane Creek AER
    By TheRedMantra in forum Weight Weenies
    Last Post: 05-28-2011, 07:00 PM
  5. Cane Creek DB
    By PeterWest in forum Downhill - Freeride
    Last Post: 02-21-2011, 11:09 AM
