Results 1 to 3 of 3
    Old School Freerider
    Reputation: Mammutmann's Avatar
    Banshee Wraith Greasing ?!
    Hi Guys and Gals,
    I've got a Banshee Wraith that I have completely rebuilt (more of a light Freeride / 4X Rig now).
    But I have a question that you may be able to answer for me.
    Do I need to Regrease the Pivots or the back Suspension?
    I am also having Problems with my Fox Van Coil Shock.....when it get wet and muddy it starts to make a squetching nose....I don't think the performance is any different but it drives me nuts. But I have noticed that it is quite hard and not so "bouncy".
    Can you help ?
    Cheers !
    I would send the shock in for a service by the sounds of it.
    as for the pivots. the Wraith uses sealled cartridge bearings like the wildcard and scythe, so there should be no need to regrease them. If they feel notchy I would suggest replacing them, but if not, then they should be good to carry on.
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
    Thanx alot. I have sprayed the shock with brunox shock cleaner and care. And it seems to be okay now. I also noticed that the rebound was right up > must have happend while traveling in the bag,
    Thanx alot again.
    Ride on !
