Results 1 to 10 of 10
    Feb 2012
    Banshee rune v2 question
    Are any of you that have the banshee rune v2 using a dual position fork? I'm planning on getting the new pike but don't know if i want to get the dpa or not.
    I am using a 160mm Fox Van and never felt the need to adjust the travel.
    ptd
    ptd is offline
    Oct 2012
    I am using x-fusion vengeance set at 150 (to get 545 axle to crown) and never felt the need to adjust the travel.
    Get at close to 545 as possible and don't bother with travel adjust.
    Mar 2013
    I am using Lyryk DPA 160-130mm and want fork without adjusted travel, no need on this bike. Climbing even with 160mm is very good.
    Feb 2012
    Re: Banshee rune v2 question
    The rs pike 27.5 a to c is 552 I think so only 7mm off. Thanks for your help
    ptd
    ptd is offline
    Oct 2012
    Get zero stack upper and lower headset cups too..
    Upper: ZS 44/28.6
    Lower: ZS 56/40
    I do use the low 120 mm setting on my Talas but only on really steep and technical uphills. Other then that, the bike climbs well and the front wheel stays planted. I'd say do get a travel adjust only if you enjoy climbing what most might deem impossible.
    Reputation: Stabone33's Avatar
    Aug 2005
    160mm Float CTD (27.5") -- no TA. Haven't had a problem climbing most of the stuff I used to climb with my 120mm XC rig. Riding position is different, and once I took out some spacers under my cockpit and "learned" how to climb my Rune, I don't miss the travel adjust.
    170MM RS Lyric Coil here in slack mode all the time and the thing climbs like a beast. Save your money!
    HOLLA!!!
    Reputation: jgusta's Avatar
    Ran my Lyrik DH in 160 mode for most of the year and just put DP air (160-130) in and makes the long, tedius climbs much more doable/comfortable, thus conserving a bit more energy for blasting the downs. Once on trail, pretty much stays in 160.
    Ride On!
  1. V.2 Banshee Spitfire and Rune riders in AZ
    By flyinmike in forum Arizona
    Last Post: 02-06-2013, 08:25 AM
  2. Banshee Rune V1 fork choice
    By freeriderB in forum Banshee Bikes
    Last Post: 01-13-2013, 09:11 AM
  3. Banshee Rune 2013
    By rideit in forum 27.5
    Last Post: 10-27-2012, 11:03 AM
  4. Banshee Rune and Fox 40
    By Hydesg in forum Banshee Bikes
    Last Post: 08-04-2012, 08:36 PM
  5. 2012 Banshee Rune...When
    By Birdman-X in forum Banshee Bikes
    Last Post: 05-05-2012, 02:58 AM
