Page 79 of 113 FirstFirst ... 29 69 75 76 77 78 79 80 81 82 83 89 ... LastLast
Results 1,951 to 1,975 of 2824
  1. #1951
    Apr 2014
    Quote Originally Posted by MAFIA View Post
    i have a question that i think i know the answer but for be sure for what are the two screws on the bottom of the tube on the rune?
    They are for fitting a downtube mudguard or a downtube protector.
  2. #1952
    Calm like a Bomb
    Reputation: stunzeed's Avatar
    Banshee Rune V2 Build Thread
    Question: anyone have 2 setups for their rune ? Something like a DH mode ( wheels, tires, Eric) and trail like wheels,etc?
  3. #1953
    Nov 2013
    Quote Originally Posted by PhilBR View Post
    can you post a mudguard or downtube protector to fit there with does screws?
  4. #1954
    Apr 2014
    Like this
    CUBE Carbon Stone Guard, Frame/Downtube protection 3M sticker Foil Down tube NEW | eBay
    Or this
    THE Pro Shroud | Chain Reaction Cycles
  5. #1955
    Nov 2013
    yes but that is a sticker
  6. #1956
    Apr 2014
    Didn't notice that but the mudguard is correct, you can get the one below and just drill the holes. There are hundreds knocking around or are you saying the bolts aren't for that?
    Pro-Carbon Racing Carbon Fibre Downtube Protector
  7. #1957
    Quote Originally Posted by BansheeJon View Post
    Fresh Rune build for the '14 season...
    Attachment 892215
    Very cool bike!!!
    I really like the stealth look.
    I'm expecting that mine will have a similar look and set up (monarch plus included)
    Regarding the shock, that is a '12 model, right? What damping setup do you have there?
    My Monarch is an MM and the tech guy at the LBS suspects that at least compression will have to be changed.
    Cheers.
  8. #1958
    Regarding the screws question, isn't the location too low for a mud guard?
    But for a downtube guard, that makes more sense to me.
    If found this one:
    It seems cool.
    It is from RockguardZ, specific Rune model
    Banshee Rune - BANSHEE
    You may notice that in the picture there are no screws on the downtube, but then again, it is a 2013 Rune (white decals on black satin finish).
    Cheers!
  9. #1959
    Nov 2013
    this is the anwers from banshee bikes facebook "They are incase you want to have a bottle cage, or screw on light batteries."
  10. #1960
    Apr 2014
    Why would you put them on the downtube?
  11. #1961
    Reputation: Colin+M's Avatar
    To create controversy, obviously.
  12. #1962
    Nov 2013
    yeah that why i was like a bottle cage downtube with banshee you dont only ride the mud you have to tasted lool
  13. #1963
    Where else are you supposed to put one on Banshees then?
  14. #1964
    Nov 2013
    yes actually there no room but is good to have a bottle for quick runs i actually going tu put one there when a short street ride is the option cause i serious hate have to take my camelbak for short rides
  15. #1965
    Feb 2013
    Just converted to 650b...
  16. #1966
    Nov 2013
    do you like 650b?
  17. #1967
    Feb 2013
    Well... had only one ride so far. I does feels slightly different than 26. I did a small jump and it does feels a little "big" i think..maybe also because i was using blur trc before..anyway in terms of speed it is definitely faster, cornering still feels more or less the same although at first i did feel a little tall in cornering the bike. One thing for sure i did feel more confident in the steeper and rough section...but sometimes i do missed the feeling of suspense using a 26 inch and a shorter travel . Overall i think if i was already have the rune in 26 setup i wouldn't be bothered to change...but since when i bought the frame i plan it to set it up to be 650b. It is a good progression though..
  18. #1968
    Calm like a Bomb
    Anyone have a 650 fork and run 26" wheels? I want to be able to run 650 on trail and 26" on DH trails
  19. #1969
    Reputation: juanbeegas's Avatar
    Oct 2007
    Quote Originally Posted by stunzeed View Post
    The older X-Fusion Vengeance forks could be run with both wheel sizes and I have been running it with 26" wheels since I first got it in 2010.
  20. #1970
    krj
    krj is offline
    Reputation: krj's Avatar
    Aug 2005
    I run 26 wheels with a pike (650b) for a while no problem at all.
  21. #1971
    Feb 2013
    I ran a pike for 650b as well as using a 650b dropout on 26 inch before i converted to 650b. It was fine. Geometry wise, It is hard to tell the difference.
  22. #1972
    Feb 2010
    do you like 650b?
    I just converted to 650b after 12 months on 26. same model forks, tires and wheels.
    Simply put - the Rune is a better and faster bike with the larger wheels.
  23. #1973
    Mar 2013
    I've been running the rune with 27.5 wheels/dropouts. I just put on the 26" drop outs with the 27.5 wheel, the shorter chain stays are rad! I put it in the middle setting and it looked like the same bb height as the 27.5 drop out in the middle setting when i compared them, just way shorter chain stays. Noticeable difference in lifting the front end up and railing corners. I'm using a racing Ralph tire in the rear with 10mm or so of clearance. Makes me wish i wouldn't have spent 100 bucks on the 27.5 drop outs..
  24. #1974
    Farkin hell, PCJ ripping CwmCarn a new one on his rune!
    Just another enduro edit - Banshee Rune with PCJ Video - Pinkbike
  25. #1975
    Nov 2013
    i want to jump like that
