Page 67 of 112 FirstFirst ... 17 57 63 64 65 66 67 68 69 70 71 77 ... LastLast
Results 1,651 to 1,675 of 2793
  1. #1651
    Jan 2014
    Got an orange rune with ccdba coming next weekend can't wait to get it built
    New xtr trail brakes, easton havoc wheels, x fusion vengeance coil all to go on.
    Hopefully will post some pics in a week or 2.
  2. #1652
    Jan 2014
    Re: Banshee Rune V2 Build Thread
    So far.....
  3. #1653
    Nov 2013
    Banshee Rune V2 Build Thread-image.jpgthis is mine
  4. #1654
    Nov 2013
    2014 Banshee Rune Black/Black
ID:	861025this is mine Formula R0/Easton Heaven 27.5/Reverb stealth seatpost/Chromag pedal and stem/Easton Heaven handlebar/Raceface Affect saddle/Rock shox Pike 160mm/x01 Sram/Chris King ceramic BB/Chris King Headset
  5. #1655
    Quote Originally Posted by MAFIA View Post
    Mafia style man! I wanted a black pike as well if it has dual position air
  6. #1656
    Nov 2013
    no it is solo air and the pike i must says is a really nice fork i was undecided for solo or dual but i really dont like spending time setting up i just unlock or lock and depends on the ride i mess up a little with the rebound and shit
  7. #1657
    Hard funkin´ Kraut
    Reputation: NoStyle's Avatar
    May 2005
    Quote Originally Posted by MindPatterns View Post
    Regarding 2013 and stealth cable routing:
    2013 Spitfire and Reverb stealth
    looks like a good solution to me.
    I think this is the Solution without drilling and loosing Warranty:
    Downside of the Seattube there´s a Hole. Get the Stealth-Cable through it and run it on the Cable-Guides of the Front-Derailleur.
  8. #1658
    Oct 2012
    Hi guys!just got my rune..wonder what's the size of headset can be fitted?looking at chris king headset
  9. #1659
    44/56 if I am not wrong. I bought one before frame arrived then had to get another one as I couldn't remember where I stashed it..........
  10. #1660
    Reputation: MartinS's Avatar
    Quote Originally Posted by kenko View Post
    Inset 2 is the CK headset required.
  11. #1661
    Jan 2014
    What sort of stack height under your stem is everyone running? I only have room for 10mm, but with the 35mm havoc stem, this means my shifters hit the to tube when the bars spin. Not a major issue, but I don't want to trash the top tube if (/when) I crash!!!!
  12. #1662
    2cm spacers and 1" 720mm riser bars on L frame gives about 30mm between top tube and shifters.
  13. #1663
    Jan 2014
    Hmm, reckon another 5mm would clear it, but I've concerns with the steerer tube/stem interface as the steerer tube is about 3mm below the stem top already.
    I've put extra tape on the impact area and slackened the bits on the shifters slightly, hopefully if it happens the shifters will rotate out of the way and soften hit!
  14. #1664
    Nov 2013
    wow a 35mm stem on the rune i tought 45 mm was the limit if you want to climb fine currently i left a 50mm with zero rise stem with 18mm spacer on bottom and 6 mm on top and i think if i remember my bar is 1/2 in rise i really dont know is this i a good geo loooool how people calculate this things ?
  15. #1665
    Jan 2014
    The rune has a 40mm longer TT than my old bike, that had 65mm stem, hence the 35mm stem. Height was determined by the existing fork steerer length. Feels good, just hope I don't bin it!
  16. #1666
    Nov 2013
    loool yeah have to feel great on DH but what about up hill is good too? my question is how is determine perfect this stem,bar,spacers,angle on a bike loool i ask cause this is my firts build and i one to know if i do right? or is depends on rider preference or something like that
  17. #1667
    Jan 2014
    Don't know about uphill yet, first proper ride on Sunday so will report back. As long as it gets up the hill, in not overly bothered his it does it.
  18. #1668
    Jan 2014
    It's all down to rider preference really.
  19. #1669
    Feb 2010
    updated pic
    Added some upgrades. SIXC 170M cranks, ENVE's with project 321 hubs, removed the MRP G3 chain guide and replaced it with a wolf tooth 34T. Also have been running in slack mode the past few rides. The Rune rocks! Here is an updated pic from today's ride at Bootleg Canyon, NV.
    Attached Thumbnails Attached Thumbnails Banshee Rune V2 Build Thread-banshee-bootleg.jpg
  20. #1670
    Jan 2014
    Maiden voyage today
    All I can say is wow!
    Ended up going 1x10 and still waiting for the reverb to arrive.
  21. #1671
    Nov 2013
    with how many thooth on front
  22. #1672
    Jan 2014
    34t. Just about coped, did 20 miles and 3000feet of up and down
  23. #1673
    Mar 2011
    Quote Originally Posted by Antshee View Post
    As far as I read. You use the Rune L with 35 stem? What is your height? Is it comfortable to climb ?
  24. #1674
    Jan 2014
    Quote Originally Posted by q232 View Post
    Correct. I'm 5'11" but more body than leg if you get me? Climbs absolutely fine, even 1x10.
  25. #1675
    Mar 2011
    Thank you for answer,
    what weight of your bike?
