Page 6 of 32 FirstFirst ... 234567891016 ... LastLast
Results 501 to 600 of 3198
  1. #501
    Reputation: bikeman_2's Avatar
    Although, I'm a little disappointed about the bushing play with the DBair.
    I have the same!!
    I buy now this one:
    Huber Bushings - High Precision Shock Bushings
  2. #502
    Quote Originally Posted by uzurpator View Post
    builttoride:
    Another question from the series "I want to break my frame, is that ok?"
    I noticed that Rune has the ISCG tabs on the same plane as the BB shell face. Experience taught me that this often causes interference with the granny when using a Stinger-like chain guides.
    Since I will be running a double in front, this is an issue for me. I will be using Race Face Atlas cranks - so I only have about 2mm of chainline adjustment due to the retarded way RF cranks set the bearing pre-load.
    Is there a concete reason for such placement of the ISCG tabs? AFAIR the standard does not specify that and many frames which are sold with 2x10 have the tabs recessed some to avoid the problem above. My ex Spesh enduro had the tabs recessed by 2.5mm from the bb shell face.
    As for my question - shaving 1mm or so of material from the tabs is a no-go warranty wise - right?
    Shaving material of the ISCG will not void warranty unless any warranty claim is related to ISCG location, as it shouldn't have any affect on the rest of the frame. We are reasonable here at Banshee. Although you may have slight delay if you did ever file a warranty while the distributor checked things with us.
    The reasons I mounted the ISCG flush with the BB are that this setup does not require spacers for most chainguide setups our customers use, and as 2x10 and 1x10, and even 1x11 become more popular this is beneficial to most customers. It also is what is required if running hammerschmidt. Plus it makes for better tolerance of facing. I rarely want yet more standards in the bike industry, but for that location I do wish that all crank and chainguide manufacturers followed the same standard to offer inter compatibility.
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
  3. #503
    I have a stinger on my 2X10 setup. The pulley overlaps the bash guard by a couple of mm, but it works just fine. I used a BB mounted stinger rather than an ISCG version. It looks to me like an ISCG bracket would work the same, though.
  4. #504
    ptd
    ptd is offline
    Oct 2012
    Frame has landed! Must buy parts immediately!
  5. #505
    Reputation: Hikers Only's Avatar
    Oct 2010
    Quote Originally Posted by ptd View Post
    Dude the black looks sick!!!!
    Mine should arrive Monday all I'm waiting on is my CC 110 headset.
  6. #506
    Oct 2010
  7. #507
    Oh no you di'int
    Can I get some clarification on the recommended spacers for the Cane Creek Double Barrel Air? I bought the shock separately and from Keith's post it appears like they recommend installing the largest supplied volume spacer. ptd, it looks like you got the shock with the frame? Was the spacer pre-installed? It looks like the spacer pack is untouched.
    What is the point of the spacer anyway?
    Thanks,
    Andrew
  8. #508
    Quote Originally Posted by knumbskull View Post
    Thanks,
    Andrew
    +1 I bought mine after market as well.
  9. #509
    Quote Originally Posted by rednova75 View Post
    Black does look sick......mine is tracking to arrive some time next week. I went with the Fox but will also be getting my Elka Stage 5 rebuilt for the new geometry.
    would like to see some sort of comparison on this bike of air vs coil!
    Absolutely pumped with all of these picture popping up!!
    HOLLA!!
  10. #510
    Thanks,
    Andrew
    The base settings that we liked best for the rune V2 were:
    Xvol can, 1 large vol spacer, LSR:14, LSC:10, HSC:2, HSR:2
    But everyone is different, (different weight, riding style, terrain and preferances) so we included a bunch of extra volume spacers to allow our customers to fine tune the shock exactly to their liking.
    Adding a volume spacer makes the shock more progressive. So if you find yu are bottoming out too easily, try adding another spacer, if you feel you are not getting full use of ravel, remove a volume spacer. The volume spacers obviously only work in step intervals, but the shock is so tunable that if you spend time dialing it in you can get the exact feel you want.
    Banshee Blog
  11. #511
    Oh no you di'int
    Thanks Keith, that helps.
  12. #512
    Anyone coming from a V1 with an Elka to the V2 with the CTD? Any impressions? Or if anyone going from V1 with Elka to V2 with Elka. How much is rebuilding the Elka for the new geometry costing? I am pretty torn on upgrading, I havent had the bushing issues, and replaced them once in the year I've owned it due to normal wear.
  13. #513
    powered by bacon
    Reputation: helidave's Avatar
    It was around $180 for the rebuild, new bushings, and return shipping. The Elka feels better on the v2 than the v1 so far. No bobbing, great traction, plush but not mushy.
  14. #514
    Economy build... Will take it off road for the first time tomorrow. I have a seriously screwed up knee, so probably won't get to do more than a little XC, and some aggressive limping. Still waiting on the 650b dropouts. I have a 160mm Lyrik I'm thinking of using for the 650b build. I don't think the Totem with the extra 3/4" height from the wheel would work very well.
    On the size, this large feels shorter than the large Spitfire it's replacing - a lot shorter. I'm just under 6' and feel like I could go to an XL and still be happy. I'm going to need a longer stem as it is.
    Attached Thumbnails Attached Thumbnails Banshee Rune V2 Build Thread-dsc00432s.jpg
  15. #515
    Reputation: uzurpator's Avatar
    Dec 2005
    Now that is my kind of bike
    Altho you worry me when you say that at 6' it feels short. I have an XL on order and with me at 6'5" it might prove too short with 45mm stem :/
  16. #516
    The stem that's on it is the 30mm stem that came off the large Spitfire. I think a 50mm stem will be about perfect. I do tend to prefer larger bikes than what is recommended for my height.
  17. #517
    FD --- Info
    the FD SRAM X0 2 x10 for 22-36 works not corecct wit a 36 pinion
    I use a Crank with 22-36 and the chain roams at the high gears on the FD.
    Now go back to the 22-32 an it is OK.
    In the next Time i buy a Shimano 2x10 or 3x10 FD with E-Typ.
  18. #518
    How come the times posted are all over the place on this thread. It would be sooooo much easier to look at if everything just went to the bottom on the last page.....new posts at the end of the thread......chronologically....what a thought!!
  19. #519
    Ahh nevermind I just figured out that I was viewing it in "hybrid mode" and not "linear mode"
  20. #520
    Reputation: Haus Boss's Avatar
    Jun 2010
    Just got back from my first ride on Das Runestein Zweit (my new Rune). I definitely need to spend some time tuning the DBair to my exact likings, but here's my quick stoke on the new Rune:
    I had sold my Rune V1 after it started to develop play and ended up on a Wildcard. The wildcard is a super playful bike that is perfect for jump lines, but not so well well suited for the 4-5 hour rides I like doing. I never felt comfortable on technical and steeper lines on the Wildcard, and my riding definitely suffered from my lack of confidence on the bike.
    On the new Rune I immediately felt comfortable. The suspension platform paired with the ultra stiff rear end translates into a bike that motors up fire roads as well as techier sections too. I liked the ultra-plushness of the wildcard when descending, but it definitely did quite a bit of wallowing when mashing on the pedals- especially when pushing, which can be quite annoying when you're riding lots of rocks! Going downhill the new rune is amazing (I have it set in neutral, but it's probably closer to 65 degrees since my bike has a 560mm A2C). If I had to sum up the new Rune in one word, it would be responsive. Compared to the V1 and Wildcard, I noticed the front wheel tracks a lot better. While the front tire stays firmly planted to your line, the rear wheel is super easy to whip around- I think my case of Aggie-itis just got worse (the act of whipping your rear wheel like Aggie). The new school geometry felt very natural and balanced.
    After taking a 15 year hiatus from mountain biking, around 3 years ago i started riding my XC hardtail several times a week. After being re-bitten by the mtb bug, I upgraded to my first full suspension bike, a Santa Cruz Butcher. I was blown away by the new lines I could ride and how fast I could ride them on a 6" bike. It was an eye opening experience that exponentially increased my love of riding. I ended up replacing my butcher with a 2011 Rune. I always felt cramped on the butcher and the rune v1 fit me so much better. The rune v1 was a lot of fun, but I didn't have that same level of exuberance I had when first riding the butcher. Maybe I was chasing that first high that I would never be able to reach again. Enter Das Runestein Z (Rune V2). Wow. I feel like I'm on a mini-DH bike compared to the Butcher and V1. It's just damn fun and confidence inspiring. All of the confidence I had lost while riding the Wildcard has been completely wiped away by one ride on the new Rune. I can't wait for my next ride Although, I'm a little annoyed it's winter as I think this bike is the perfect weapon of choice for an all day ride in the alpine!
  21. #521
    Quote Originally Posted by belljeffw View Post
    I'd be really interested in a Spitfire V1 / Rune V2 comparison. Not sure which way I should go right now... currently on a spitfire and cant decide whether I should get a new rune or new spitfire.
  22. #522
    FD --- Info
    Quote Originally Posted by bikeman_2 View Post
    I must revice my INFO for the SRAM FD. This morning I put a 2. Plastic-Ring on my Crank (Shimano HONE). And...ist works perfekt with the X0 SRAM 22-36 for 2x10 Speed. with a 36 Pinion.
  23. #523
    May 2005
    Quote Originally Posted by cressa View Post
    Wouldn't a Spitfire V2 / Rune V2 comparison make more sense if your possibly upgrading to one or the other? (or did you mean to say that?)
    2013 Banshee Spitfire V2 650b
  24. #524
    I think I will need a little more saddle time before I can make a reasonable comparison, and I need to get the stem and bar length setup more to my liking. The longer bars seemed like a minor change, but I had a hell of a time getting used to them. In any case, even with the short stem, I feel a lot more forward on the bike – the pedals feel further back than anything else I ride. THAT will take some time to adapt to. I will spend some time getting it setup better this week, and try to post something worth reading next weekend…
  25. #525
    Quote Originally Posted by skidad View Post
    No I meant what I wrote but a V2/V2 comparison would be equally interesting. I understand this sounds peculiar but the reason is simple. Upgrading my V1 spitfire to a V2 Spitfire is a no-brainer really. However I am considering a Rune instead. I'm attracted to the reported stiffness and overall downhill grunt of the Rune but would love to know how much climbing ability you loose compared to V1 Spitfire and whether its a bit boring for general trail riding.
  26. #526
    Look forward to anything you can report. Thanks!
  27. #527
    The Mountain Bike Life
    Reputation: mudpuppy's Avatar
    Saw this on Banshee's twitter feed...super sexy bike!
    https://pbs.twimg.com/media/A-V0F-UCMAERJPj.jpg:large
  28. #528
    Hard funkin´ Kraut
    Reputation: NoStyle's Avatar
    May 2005
    Wow, looks like it has the 26ers with 650B Dropouts, for longer Chainstays ...
  29. #529
    Oct 2012
    I wonder which color of frame suit me when I have lot of white parts like Bos stuffs, Lg1 chainguide, sadde etc.
    Im interested of raw and yellow . Black is too simple, I have already a black frame for 4x
    Id love to look at images of such configs (raw and yellow with white parts but black rims?)
    I know it is matter of taste, I have hard time to figure out an picture.
  30. #530
    Reputation: ryan_daugherty's Avatar
    Quote Originally Posted by kalkhoffpink View Post
    Is there a reason except weight that none of you guys opted for the CCDB Air shock????
    I have a CCDBa coming on mine.
  31. #531
    Quote Originally Posted by builttoride View Post
    Cane Creek make the large volume air cans and spacers.
    Hi Keith!
    Are these base settings the same for the CCDB Coil?¿?? (these settings are from the CCDB AIR)
    LSR - 14 clicks in
    LSC - 10 clicks in
    HSR - 2 turns in
    HSC - 2 turns in
    Nov 2012
    Quote Originally Posted by mudpuppy View Post
    Really nice bike, I wanted to see a black one builted
  33. #533
    Oct 2010
    My black ano 142x12 with the Fox CTD just arrived in the mail I can't even tell you how SICK this bike looks!! Should have it built by the weekend.
  34. #534
    Nov 2012
    Still waiting for mine
  35. #535
    Quote Originally Posted by AdrianoMTB View Post
    Hi Keith!
    LSR - 14 clicks in
    LSC - 10 clicks in
    HSR - 2 turns in
    HSC - 2 turns in
    The rough tune layout may be helpful for the DBcoil, but these are specific to the DBair. I'd suggest that you start around these settings and tune to your preferances from there.
    Banshee Blog
  36. #536
    What weight is it?
  37. #537
    Oct 2010
    Size large with dropouts, hanger, 12 mm thru axle and CTD weighed in at: 8lbs 5oz. This does not include the seat post or seat collar. In comparison a large V1.5 with a DHX Air 5.0 weighed 7lbs 10oz.
    Attached Thumbnails Attached Thumbnails Banshee Rune V2 Build Thread-photo-1.jpg
  38. #538
    Reputation: rokesoke's Avatar
    Oct 2012
    Quote Originally Posted by tene View Post
    What weight is it?
    +1 on mediun size with CCDB
  39. #539
    Oct 2012
    Size large with dropouts, hanger, 12 mm thru axle and CTD weighed in at: 8 lbs 5 oz. This does not include the seat post or seat collar.
    Black is cool
  40. #540
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    Thats awesome. Well over a pound lighter than the prime protos.
  41. #541
    Mine landed yesterday on my front doorstep. It is currently being built. I hope to have it by tomorrow with some ride time for this weekend and all next week during xmas break....if only it wasnt so damn cold!!
  42. #542
    Reputation: qbert2000's Avatar
    Quote Originally Posted by bmxking45 View Post
    chili and a rune v2? wow. i'd like to hear your thoughts on the two bikes and what you prefer.
  43. #543
    Reputation: jncarpenter's Avatar
    Quote Originally Posted by FM View Post
    My medium production Prime was 7.95#...built up w/ a reverb it weighs 31.8
  44. #544
    Quote Originally Posted by qbert2000 View Post
    I must have read your comment to my post 10x's and I must admit that I just can't make sense of it. What does chili have anything to do with it other than making me hungry?!
    HOLLA!!!
  45. #545
    HOLLA!!!
    Just guessing but I would guess he thinks you own a Knolly Chicoltin as well.
  46. #546
    HOLLA!!!
    duh! my mistake. OldschoolBMXer has a chili and i confused the two of you. just saw the "bmx" part and brain vapor locked. my bad
  47. #547
    Finally got all the parts after close to 4 weeks after getting my frame. About 2 pounds heavier then I hoped for at close to 35pds. Besides the fork I can not figure out where all the extra weight is compared to the other frame on here that I saw with the CCDB Air. That one came in at 33pds.
    Attached Thumbnails Attached Thumbnails Banshee Rune V2 Build Thread-image.jpg
  48. #548
    Full shot.
  49. #549
    Rune CCDB Air Option
    My warranty replacement is in queue, and after seeing some of the V2s built up, I can't wait.
    Quick question, when I was conversing with Trident, I was told the CCDB Air wasn't an option. I am more than willing to chip in a bit more for the upgrade.
    Anyone have the low down if Trident allows this upgrade option? If so, I would like to go that route. Any assistance with this is greatly appreciated.
  50. #550
    Quote Originally Posted by jason3559 View Post
    I am pretty sure if you go to the thread below Trident said it is a $200 upgrade with them once they are available. Post number 93.
    "We have Cane Creek Double Barrel Airs on order with Banshee for Legends, Primes, Runes and Spitfires. We are receiving our first shipment for Runes next week and will have the ones for the other models available by the beginning of February.
    They are only sold with a frame since we are not an authorized Distributor.
    The boys from Banshee have been really impressed with the performance and say that they are worth the $200 up charge over the Fox offering. I personally have minimal experience with the DB air, except for one ride on the first generation, so I'm looking forward to trying a properly tuned one in the future.
    __________________
    TRIDENT PERFORMANCE SPORTS
    Distributor of the following high performance products:
    Alpinestars Cycling www.alpinestars.com,Banshee Bikes Banshee Bikes, Born on the Shore, Canadian Mountain Bikes for downhill racing, freeride, all mountain, trail, 4x, dirt jumping, 29rs, Manitou & Answer Products Manitou Suspension Forks & Bicycle Components for Mountain Bikes, WTB WTB - Select Your Location, Funn Funn Mountain Bike Components, Formula Disc Brakes Formula, Gamut Chain Guides Gamut USA Store
    Contact us at:
    Phone: 604 929 4955
    Email: info@tridentsports.com
    Website: www.tridentsports.com "
    Banshee Rune V2.0 - Page 7 - North Shore Mountain Biking Forums
  51. #551
    Quote Originally Posted by Mishtar View Post
    Thanks for the heads up. Admittedly, a bit lazy with my research.
  52. #552
    what are the sag recommendations for the new Rune?
  53. #553
    ptd
    ptd is offline
    Oct 2012
    28% on the geometry tab towards the bottom...
    Rune | Banshee Bikes: DH Race, Freeride, All Mountain, Trail, Slopestyle, DJ/Street/4x, Aggressive Trail, Cross Country
  54. #554
    Reputation: darkslide18's Avatar
    Went out for a little urban assault.
    Attached Thumbnails Attached Thumbnails Banshee Rune V2 Build Thread-20121222-dsc00013.jpg
  55. #555
    OK, I swapped out the 45mm stem for an 85mm stem and shortened the bars to 700mm (amazing what 80mm of extra bars does to the feel of a bike). I also changed out the Vivid for a Pushed Monarch. For some reason I couldn’t get enough rebound damping on the Vivid. I’m waiting on a reducer headset lower for the Lyrik. At the moment I’m happy with the Totem, but it's really too much fork if you like long technical climbs.
    I don’t think you will lose the fun factor with the V2 Rune compared to the V1 Spitty. I can’t tell if it’s new-bike-effect, but this thing is a joy to ride. I have only been on XC trails so far, and taken a couple of low drops. I’ve also only played with the dropout tabs with the centered hole. It climbs very well, though as I mentioned I need to swap out the Totem. I’m also still struggling with an arthritic knee that doesn’t want me pedaling while out of the saddle, so my impressions on climbing are probably pretty skewed.
    Like someone else mentioned earlier in this thread I initially had trouble with manuals, but the problem went away by the second ride. My thinking is that being further forward means you have to start the manual sooner, but not pull any harder. If the V1 Spitty had any serious handling flaws it was the effort needed to pick the front end up.
  56. #556
    Quote Originally Posted by darkslide18 View Post
    looks very nice.
  57. #557
    Nov 2012
    Looks great! Thats the new trailmaster ltd saddle? looks nice!!
  58. #558
    So I got to take mine out today on a true all mountain climb/descend ride with plenty of big drops and hits to air it out. Initial impressions are stellar. This bike absolutely rips the DH. I am still getting used to my Fox CTD but it feels pretty good however I have a really hard time feeling the difference between the three modes because I descended in climb mode and climbed in descend mode and I never even noticed. I am coming off an Elka on my V1 Rune which I thoroughly enjoyed because it was set it and forget it. I am currently on a size Med in the Neutral setting on the flip chips. I can't wait however to try it in the slack mode but that is another day. The bike climbs surprisingly well as compared to my V1. I did however def notice the lower BB on the climbs (pedal strikes) but noticed it equally as much on the descends when i hit stuff in hyper speed. The bike jumped very well as well which if it was easier I would attach some pictures. Over all I think banshee did a wonderful job on the redesign and this thing is going to get a lot of use and see plenty of airtime!
    HOLLA!!!
  59. #559
    Aug 2010
    Dang, I was worried about this. I'm building a V2 for Downieville which mostly features super rocky descents. Pedal strike often equals ejection up there. I'd be curious to hear from V2 riders how the chip in the steep setting feels on the downhills. Does it kill the mini-downhill feel that a lot of guys are reporting?
  60. #560
    Quote Originally Posted by CALULO View Post
    Good eye. It is indead the new TrailMaster LTD in deep red. Hoping to test the bike and the new seat out on my next day off which is the 28th.
  61. #561
    powered by bacon
    Quote Originally Posted by mattioliD View Post
    Dang, I was worried about this. I'm building.. a V2 for Downieville which mostly features super rocky descents. Pedal strike often equals ejection up there. I'd be curious to hear from V2 riders how the chip in the steep setting feels on the downhills. Does it kill the mini-downhill feel that a lot of guys are reporting?
    It descends great in the steep setting. Still very planted and stable.
  62. #562
    does anyone know what "28%" translates to in mm so i can adjust accordingly on the Fox CTD.
    HOLLA!!!
  63. #563
    ptd
    ptd is offline
    Oct 2012
    Smile
    HOLLA!!!
    From the banshee's mouth
    You want about 16mm of sag at the shock (16.3mm if you want to be exact). 28% of wheel sag is not quite the same as 28% of shock sag due to leverage curve not being perfectly flat.
  64. #564
    Quote Originally Posted by helidave View Post
    The steep setting on this bike is still slack compared to most other bikes in its class. I run a Lyrik with an A2C of 555mm. In the slack setting I'm just a butt hair under 65 degrees. Thinking of moving to the neutral position.
  65. #565
    Oct 2010
    Finally Finished!
    Will going out on the maiden voyage in about an hour
    Update: Also just weighed it, and it came in at 31lbs 3oz. Not bad considering I have heavier tires!
    Attached Thumbnails Attached Thumbnails Banshee Rune V2 Build Thread-dsc_5600.jpg
  66. #566
    Looking good!
  67. #567
    This bike hauls. Out at The Syncline, WA for a Christmas Eve putt.
  68. #568
    Oct 2010
    [QUOTE=darkslide18;10004913]This bike hauls. Out at The Syncline, WA for a Christmas Eve putt.
    +1 pointed DH this bike opens up!! It just begs to go faster and faster
    BTW your bike looks sick!!
  69. #569
    powered by bacon
    Just measured mine; 65.5 degrees in the steep setting with a 170mm lyric.
  70. #570
    HOLLA!!!
    Banshee Blog
  71. #571
    There is also a phone app for the 2013 Fox shocks and forks that helps set up sag. Only works with the 2013 models though.
  72. #572
    Reputation: helimech's Avatar
    Mar 2006
    Quote Originally Posted by ryan_daugherty View Post
    And mine .
    SHITBIRD
  73. #573
    _va
    _va is offline
    Reputation: _va's Avatar
    Oct 2012
    Quote Originally Posted by helimech View Post
    And mine .
    +1
    My local spot: http://thespot.pro/
  74. #574
    _va
    _va is offline
    Oct 2012
    offtop - banshee v1 build - june 2012
    <iframe width="640" height="360" src="http://www.youtube.com/embed/M_ReBXbNceU" frameborder="0" allowfullscreen></iframe>
  75. #575
    Nov 2008
    Nice, reminds me of my old Rune.
  76. #576
    Which size of shock mounting hardware should be used?
  77. #577
    Reputation: jgusta's Avatar
    M8 x 40.0mm for shaft end of shock (rear end) and M8 x 25.4mm for reservoir end (front)
    Ride On!
  78. #578
    ptd
    ptd is offline
    Oct 2012
    I'm thinking of getting a Rune v2 and want to run it 650. So, I am curious, has anyone tried the XFusion Vengeance on a Rune V2 and how does it do?
    I have that frame/fork combo, won't have it build up up until end of Jan, I'll post experience then. Using Stans Flow 650b rims.
    I emailed XFusion USA with the same question, got a reply from the sales/service manager, he confirmed the forks are 650b out of the box, with no need to add a travel reducing spacer (got a quick reply thanks XFusion).
    According to this thread
    The 650b tire dimensions thread
    the Hans Dampf 650b has a diameter of 705mm.
    This would leave 42.5mm of crown clearance at bottom out (565-(705/2) -170). I'm also planning to use the High Roller II 650b, say that's 720mm diameter, leaves 35mm crown clearance (565-(720/2) -170).
    As for head angle, that's what I'm looking forward to! Depends on what you like I guess, for climbing/flat trail cornering I haven't found it to be a negative on other trail bikes, maybe some technique change is required...
  79. #579
    Quote Originally Posted by daves4mtb View Post
    However, I am considering an XFusion Vengeance fork, which has an axle to crown that is (at 565mm) 20mm longer than the ones it is specced for...I understand the geo is 65 to 66 degrees, adjustable, assuming a 545mm a to c fork. With 565, I am concerned this thing will be too slack for anything but downhill.
    If you are concerned about the slack angles, then you could either lower the fork internally to 150mm to get desired axle to crown height to help keep BB low too, or you could run an angle set to steepen things up, but this will result in a higher BB.
    Personally I would lower the vengeance to 150mm to get 545mm axle to crown height. The damping on the vengeance is good enough that you can run this setup without feeling you have too little travel.
    Banshee Blog
  80. #580
    Im running a Lyrik with an A2C of 555. In the slack setting I am shade under 65. Im also considering a vengeance and i would have no qualms whatsoever about mounting it up. Swap the flip chips for the steep ones and your going to get around a 65 degree HA. Which in my opinion is fine because this bike climbs just fine in the setting I have now.
  81. #581
    A second concern I have is with the Vengeance's clearance for the beefier 650 tires. I am going to want to be able to run at least 2.35s in there. I've heard there are some clearance issues but this is surprising since the fork is approved for 650b. (I had an Xfusion Velvet fork and had no such issues with 650b and it was a great fork with lots of clearance, even for Nevegal 2.35s so I am doubting the accuracy of this last bit).
    Just plug in the numbers:
    geometryCalc
  82. #582
    May 2005
    This fork has me really puzzled. It seems to have un-needed excessive amounts of clearance built into it (especially for 26" wheels). Your #'s and math are correct and 42.5mm of crown clearance seems crazy to me at bottom out with a 705mm 650B tire. It would clear a 29" tire for petes sake never mind the tallest 650B right now which is the NN 2.35" @ about 708mm. I also seriously doubt the new High Roller 650B will be anywhere near 720mm (28.35") which would make it just a gigantic 650B tire.
    Am I missing something here
  83. #583
    ptd
    ptd is offline
    Oct 2012
    Yeah I'm surprised by the clearance on paper (in a good way), will be interested to see when built up...
  84. #584
    Jun 2010
    I have a 2011 Vengeance which has 160mm of travel and an A2C of 560mm. I run my rune in the neutral position, and honestly it doesn't feel that slack when riding around XC trails. However, when you're pointed down, it definitely becomes noticeable how much better the V2 handles the steeps compared to the V1. I have avoided running it in the slack position due to the same concerns you've expressed. After riding the V2 for about 3 weeks, I'd probably be more concerned with more pedal strikes than the super slack HA.
  85. #585
    A quick little edit from yesterday. COLD!
    <iframe width="640" height="480" src="http://www.youtube.com/embed/c_crDR1Ft3s" frameborder="0" allowfullscreen></iframe>
  86. #586
    May 2005
    Yeah, sweet video. Love the transitions from snow to dry valley with the sun bursting through. Nice!
  87. #587
    Mar 2011
    Can't be that cold, still have running water on trails.
  88. #588
    Nice edit and cool to see HC in the snow, but man I got one word of ya.....Blackrock...as it was pretty prime all the way from the top (outside of Bonzai 5). Sorry I didn't call you yesterday due to leaving the phone at home and not realizing until well on the road. BR is probably the best rolling trail right now in the whole NW for that matter as it has been protected from low snow. Go get some and let me know how the V2 digs it as I am still waiting for mine of course.
    Ride On!
  89. #589
    Took the new Rune out for a ride around Taipei, handled almost 3,000ft of climbing without much trouble in the slackest setting. Hit up a nice wet and steep trail at a little DH spot we have in the city on my way home.
    <iframe width="640" height="360" src="https://www.youtube.com/embed/Sj0ORdHf0wA?feature=player_detailpage" frameborder="0" allowfullscreen></iframe>
  90. #590
    Looks like a fun little trail. Love the blue Rune.
  91. #591
    Not too bad, considering it's in a city of 3million people. I've been pleasantly surprised by the riding here in Taiwan thus far.
  92. #592
    Radical!!! Superchunk in the jungle on the V2, dig it and great solo edit/riding!
    Ride On!
  93. #593
    Quote Originally Posted by jgusta View Post
    I have the day off tomorrow so I'm heading out to BR while the gettin is still good. Partly cloudy and 41 degrees. Quite doable. Going hit Bonzai and Sickter. If youre off give me a call.
  94. #594
    ptd
    ptd is offline
    Oct 2012
    Quote Originally Posted by Haus Boss View Post
    Strange these 2012 Vengeance 170mm have A2C of 542mm ish... wipers go up to about 5mm from the crown bits at bottom out...
    Bike looks sad without it's bits on!
  95. #595
    That's a bas @ss machine you have there. Nicely done.
    Ride On!
  96. #596
    May 2005
    Jeez, can you please measure that A/C again and also confirm the 170mm of travel on the stanchion.
    Your talking a 20mm difference as to what X-Fusion states on their site and that's a BIG difference
  97. #597
    Jun 2010
    Prior to my vengeance I had a 170mm lyrik. At one point I had placed them side by side to see if I could notice a difference with the A2C, and the vengeance was slightly taller/longer. How many mm of stanchion is your fork showing right now?
  98. #598
    ptd
    ptd is offline
    Oct 2012
    My bad, I was measuring to the bottom of the crown, not the crown race.
    Axle to crown race is 565.
    There is 178mm exposed stanchion, 8mm left at bottom out.
    I did some tyre clearance calculations in an earlier post which are wrong.
    Based on 540mm axle to bottom of crown, a 705mm diameter hans dampf 650b will leave 17.5mm clearance 540-(705/2)-170. 720mm diameter leaves 10mm.
    Oops.... Correct now?
  99. #599
    May 2005
    Ah, it all makes more sense. Thanks for the corrections
    Still, allot of clearance built into this fork and quite possibly to much IMO. I don't think were gonna be seeing a 720mm 650B tire (28.3") yet there is more than enough clearance for one.
  100. #600
    Roll on Spring Time!
    Reputation: juan pablo's Avatar
    very nice trail to have available in the city.
    I just want to ride.
Members who have read this thread: 145
