Page 58 of 58 FirstFirst ... 8485455565758
Results 2,851 to 2,874 of 2874
  1. #2851
    Reputation: Junersun's Avatar
    Jun 2014
    Sorry another question... If the chainstay difference between the 26 and 27.5 drop out is 10 cm... I can technically move my wheel in 10 cm to see if it fits in the 26 drop out? Am I missing something with this?
    '16 Banshee Rune
    '15 Large NS Essentric ALU
    '15 Large Ibis Mojo HD3
    '14 Large Knolly Endorphin
    '08 Jamis Dakar Expert
  2. #2852
    Jun 2016
    Quote Originally Posted by Junersun View Post
    10mm and you could but it will be difficult to get the exact position right. I ran a 27.5 x 2.4 Hans Dampf in my 26" dropouts. Could only use the slack position though, couldn't get clearance in neutral or steep.
  3. #2853
    Reputation: freyrida's Avatar
    Aug 2016
    New banshees out at Eurobike. Apparently they shaved off 1 lbs. with the use of hydroforming...
    Gesendet von iPhone mit Tapatalk
  4. #2854
    Jun 2014
    Thanks for the feedback guys. I got the 26 drop out and I am currently running 2.25 Hans dampf but I think this is all I can fit due to my rim being a little wide to begin with (arc 30). Feels awesome with that shorter chainstay though!
    Another question. I'm currently running 170 mm fork and according to my phone app, I'm rocking a 63 degree HA! Holy DH... I wonder if 160 would do me better... a little more balanced, a little lower BB... thoughts? Or will it make minimal difference and I should just run it chopper style...
    '16 Banshee Rune
  5. #2855
    Sep 2016
    Listen!
    Getting ready to go from 26 to 27.5 on my spitty.
    Are there any issues with running my 2x9 on the newer hubs?
    I don't want any surprises.
    Just realized its not the spitfire thread.
    Will I have any issues with my 9 speed cassette on any "new" hub?
  6. #2856
    Jun 2014
    Just make sure it not the xd driver and you'll be fine
    '16 Banshee Rune
  7. #2857
    Aug 2015
    ignore this I forgot to quote him
  8. #2858
    Aug 2015
    Quote Originally Posted by graypaw View Post
    And here is mine, still with 26 wheels and low setup. 14,7 Kg / 32 lb 6.5 oz
    Frame Banshee Bikes Rune v2 Stealth
    Rear Shock Cane Creek DBair CS XV
    Fork Rock Shox Lyrik Coil X-Firm Fast Compressor
    Headset Cane Creek 10 Series
    Handlebar Chromag BZA 35mm
    Stem Sixpack 35 mm
    Grips ODI Rogue Lock-On
    Brakes Hope Tech 3 V4 Braided Hose
    Brake Levers Hope Tech 3 V4 Braided Hose
    Shifters SRAM XO 10 speed
    Rear Derailleur SRAM x9 type 2
    Chainguide Superstar Components
    Cranks SRAM GX 1400 32t oneUP Oval
    Bottom Bracket SRAM GXP Ceramic
    Chain KMC X10SL DLC 10 Speed Chain
    Cassette SRAM PG-1070 11-42 OneUP 42t
    Pedals Superstar Nano-X ti
    Wheels Hope Pro II Evo + Mavic EN 821
    Front Tire Maxxis Highroller II 3C MaxxTerra
    Rear Tire Maxxis TomaHawk 3C MaxxTerra
    Saddle Bontrager Kovee
    Seatpost RockShox reverb 125mm
    Seatpost Clamp Chromag
    Banshee rune v2 NightHawk - graypaw's Bike Check - Vital MTB
    Attachment 1071240
    How are you liking the ONE UP Oval?
  9. #2859
    Jun 2014
    I have the wolf tooth oval and they have been awesome! You can really feel the difference when your off the saddle smashing.
    '16 Banshee Rune
  10. #2860
    Aug 2015
    Junersun you have cost me more money than anyone else on this forum!! lol I guess I will have to get one now. Do you run a 32t or 34t? I will go with the one up as I have all there stuff already.
    OH OH I got my Amp built too! its on Banshee's and Dirt Merchants Bicycles Facebook pages
  11. #2861
    Jun 2014
    I'm on 30t for where I ride. I climb so I can ride down ;-)
    When I get my next cassette I may opt to go 32t.
    Haha I only answer your questions. Enjoying the rune? My recent project has my 26 inch drop outs with 27.5 wheels. Game changer!
    '16 Banshee Rune
  12. #2862
    Aug 2015
    Yes I enjoy it!
    https://www.facebook.com/BansheeBikes/
    https://www.facebook.com/dirtmerchantbicycles/
    See what you think?
  13. #2863
    Jun 2014
    It only takes me to the home page. Is yours the blue decal with the 36?
    '16 Banshee Rune
  14. #2864
    Aug 2015
    Yes!
  15. #2865
    Jun 2014
    That's pretty dialed bike! If I dirt jumped I would build exactly that. Congrats!
    '16 Banshee Rune
  16. #2866
    Jun 2014
    Can you guys go and measure your BB height for me. With 27.5 wheels, DHF/Hans dampf tires I get 13.75... almost 350 mm! Seems a bit high. Not sure how you get to 13.3 as advertised
    '16 Banshee Rune
  17. #2867
    Jun 2016
    Where are you measuring to?
  18. #2868
    Jun 2014
    Center of BB to the ground.
    '16 Banshee Rune
  19. #2869
    Reputation: dirtrider76's Avatar
    Sep 2012
    My 2013 is 14" center of BB to the ground. 27.5 in slack mode and 160mm 26" Fox 36 also has a Magic Mary SG in front and a Aggressor DD in back.
    I like to fart when I'm in front of you on a climb
  20. #2870
    Aug 2016
    I think this is the only disadvantage converting a Rune from 26" to 650b - the BB is rising!
    I have a quick question: i have a SHIMANO XTR SM-BB93 bottom bracket installed, running a 1x10 setup. As we have a 73mm BB here, do i run ONE spacer on the drivetrain side? I only researched info for running one when using a 2x setup in front... thanx!
  21. #2871
    Feb 2006
    Yes... always one spacer for 73mm.
  22. #2872
    Aug 2016
    Thanks. As i disassembled the Cranks today i found i did put that spacer there, it was too dirty to See
  23. #2873
    Aug 2015
    Quote Originally Posted by Vadim0791 View Post
    Contact this guy:
    http://forums.mtbr.com/member.php?u=771190
    or at the Pinkbike
    dirtmerchantbicycles on Pinkbike
    His name is Ethan, owner of Dirt Merchant Bicycles bike shop . Official for Banshee and Knolly.
    I been working in Malaysia from 2013 up to May this year and I got from him Banshee Phantom frame with monarch XX and MRP fork, Knolly Warden frame with CCDB inline and Pike fork. Recently,already been in Russia, got from him MRP Raze shock for my wife's CB Riot.
    Even with custom fees banshee frame from Ethan came cheaper,then Fakawi Tribe, official distributor banshee for Malaysia offered me.
    Highly recommend.
    I Approve this message I bought my AMP from Ethan!! I already had my Rune before I found him.
    2016 Banshee AMP
    2014 Banshee Rune V2
  24. #2874
    Quote Originally Posted by Lock_down View Post
    +1 for Ethan/Dirt Merchant, bought my Spit frame from him 1.5yrs ago and already in contact with him regarding a '17 frame this year. A standup dude!
