Page 32 of 32 FirstFirst ... 222829303132
Results 3,101 to 3,199 of 3199
  1. #3101
    Finished my 4th Rune last week. Clocking in at 14.3 kg. Looking forward to changing cranksets and the casette for saving weight. Current goal: sub 14kg. Wheels are rather heavy and the reverb with its 170mm, too.
  2. #3102
    Reputation: ryanmj's Avatar
    Aug 2014
    Can somebody with a 2016 rune check to see which side of the lower pivot the RS marking is supposed to be on. I don't think it matters which side of the upper pivot the R is on but check that as well.
  3. #3103
    Aug 2014
    Quote Originally Posted by rock-rod View Post
    I just finished my build:
    2017 X-large frame w/ natural finish
    Pike 150mm boost (for now, will change to 160mm once the parts show up)
    DHX2 with 500lb coil
    650b stans arch wheel set
    Minion DHF 2.5 and DHR2 2.4
    1x11 w/ RF cinch crank and 30t chain ring and 11/46 sun race cassette
    Zee brakes and 203mm rotors
    KS dropper
    I am 6'2" and the frame feels perfect.
    I'm 6'2" as well but on a large, I've always wondered if an xl would suit me better
  4. #3104
    Reputation: Junersun's Avatar
    Jun 2014
    Quote Originally Posted by ryanmj View Post
    Non drive side
    Current Bikes
    2018 Santa Cruz Chameleon 27+
    2016 YT Tues AL
    2016 Banshee Rune
  5. #3105
    Jun 2016
    Quote Originally Posted by saintberry View Post
    So I ended up going with an elevensix. I got a good deal on it and they do a tune for the Rune. It also has a climb switch so I'm happy.
    Thanks for the advice. I hope it rips!
    Just curious, what qualifies as a good deal on an elevensix?
  6. #3106
    Jun 2016
    KS dropper
    Nice build. Reason for Arch over Flow?
  7. #3107
    flailer
    Sep 2012
    I went with what i knew would fit the rear. I would love to run the wider Flows with some 2.8 tires but not entirely certain they will fit the rear.
  8. #3108
    Feb 2014
    I'm building a 17 rune up with 2.6 inch specialized tires, they fit the chain stays with no issues, the linkage is pretty tight but I'll wrap it with something. I put a maxxis 2.5 dhf wt in just for comparison and they aren't quite as tall so 2.8's may work. Honestly though the new 2.6 specialized tires in the grid casing are amazing, and cheaper than the rest. Insane grip and no noticeable bounce like some of the bigger tires out there.
  9. #3109
    Feb 2014
    Forgot to mention my wheels are 31mm id, tires are pretty huge, I'll put some pics up when the build is done.
  10. #3110
    Reputation: dirtrider76's Avatar
    Sep 2012
    I ran 2.7 Minion f/ 2.7 HR rear on 30mm rims with no issue on my V2 years ago
    I like to fart when I'm in front of you on a climb
  11. #3111
    flailer
    Sep 2012
    ^^good to know. I came from a 650b plus bike with 3.0 wide tires which was pretty cool. I would love to build another wider wheel set with wider tires to switch back and forth.
  12. #3112
    Can someone help me out? Still waiting for the 20mm bushing from Cane Creek, so I used a bushing from Rock Show which fits nice. I'm still having spacers from Cane Creek which I'd like to use, however, I'm not sure which one to apply to the bushing. Can someone measure them for me if anyone is riding this setup?
  13. #3113
    Reputation: Creg's Avatar
    Nov 2014
    What is the fox shock hardware needed for the rune? I can't see any 40x8 or 20x8 sizes, they all seem to be imperial widths Fox Shox Polymer Du Bushing Reducer Kit > Components > Forks & Suspension > Service Kits & Parts | Jenson USA
  14. #3114
    Jun 2016
    Quote Originally Posted by Creg View Post
    Are you building a 2017? 39.88 will be fine for the triangle end.
  15. #3115
    Nov 2014
    Quote Originally Posted by Boom King View Post
    Yeah a 17, thinking of fitting an x2
  16. #3116
    Jun 2016
    Message Banshee on FB. See if 19.05mm will work on the front?
  17. #3117
    flailer
    Sep 2012
  18. #3118
    19.05mm will work on the front... although would be better if Fox would offer metric sizing more readily to be honest.
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
  19. #3119
    May 2017
    $1050 AUD - had to buy with the frame to get that price. They retail for about $1700 AUD in Australia.
  20. #3120
    Jun 2016
    That's a good deal.
  21. #3121
    Nov 2014
    Quote Originally Posted by builttoride View Post
    Can/should I just use the rockshox hardware? Squeezing the front mount by 1mm sounds a bit ghetto, I'd rather stick two 0.5mm washers in. Or maybe I should consider another shock?
  22. #3122
    flailer
    Sep 2012
    I picked up some 8mm ID shims from eBay. These shims are used for shimming the differentials for rc cars.
    https://www.ebay.com/p/Kyosho-96644-...-10/1322628012
  23. #3123
    Braaap
    Reputation: DirtMerchantBicycles's Avatar
    May 2014
    My advice would be to use the 20mm length axle that comes with the RS shocks and replace the 2 outer spacers with Cane Creek spacers. They are 2.5mm or 3mm wide, many Cane Creek hardware kits will stack these spacers in order to get the final width needed. Unlike the included RS spacers, the ID is properly sized and will not rattle around the axle.
    If you're starting from scratch and did not purchase a shock with the frame, you can:
    1. Have Cane Creek cut hardware to 20mm.
    2. Use Manitou's m8x20mm 2-piece hardware (Manitou part #:85-6256, available through BTI)
    3. Use 19mm hardware
    Dirt Merchant Bicycles
    Providing unrivaled support and unbeatable pricing on all cycling goods to riders near and far.
  24. #3124
    Nov 2014
    ^^^ Thanks!
  25. #3125
    Jun 2016
    These guys do made to order hardware, great pricing too.
    http://www.proshox.com
  26. #3126
    I am not sure how geometry works that much but if I went from my 170mm RC3 55 fork to a 150mm or even a 160mm 27.5" fork but kept my 26" wheels with my V2 Rune, would the bottom bracket lower that much? I am in need of a new fork but it seems most of the forks out there these days are for 27.5" wheels and I do not want to have to buy a new wheel set.
  27. #3127
    Jun 2014
    Quote Originally Posted by Mishtar View Post
    I would research what the A-C distance is between forks. If you keep that the same then your geometry won't change.
    Current Bikes
    2016 YT Tues AL
    2016 Banshee Rune
  28. #3128
    Nvm
  29. #3129
    Mar 2014
    had my rune for a few weeks now, its great...Kinda struggling with cornering with it though compared to my spitfire. I guess theh 65 HA means I really gotta get over the front and lean it over...
  30. #3130
    Reputation: Andrew8404's Avatar
    Dumb question but I'm sure I'm just looking too hard for it and it's probably staring at me right in face. But how the heck do you change the geo setting on a 16 Rune?? My old Megatrail had one bolt to change out near the shock to make it slacker. I don't see anything that's changeable on the bike. And I don't see any information regarding how to do it.
  31. #3131
    Reputation: RS VR6's Avatar
    Quote Originally Posted by Andrew8404 View Post
    Check the rear dropouts. There are two bolts on each side. Remove them and flip the chips around.
  32. #3132
    Sep 2012
    Quote Originally Posted by RS VR6 View Post
    Unless its got the middle chip in it...
  33. #3133
    Quote Originally Posted by dirtrider76 View Post
    Lol...good point. I was thinking of my bike with the high/low chips. Be kinda hard to flip a chip with the hole in the middle.
  34. #3134
    Awesome thanks guys so I'm guessing you need another chipset for the neutral setting?? I only have the chip that goes high or low. Excited to get some time on her. The brakes barely work but thankfully there sending me a brand new set.
  35. #3135
    Reputation: Phsx2's Avatar
    Dec 2014
    The 2017 frames only have a high or low setting. They're actually just the neutral and low setting from the 2016 frame.
  36. #3136
    Braaap
    May 2014
    That's a 2016 frame with v1 dropouts, not a current 2017 with v2 dropouts. Send us an email, we might be able to scrounge some neutral chips up.
  37. #3137
    Jun 2014
    If dirt can't find any, hit me up. I'm sure I have some lying around. Low is the only setting you need anywaz ;-)
    Current Bikes
    2016 YT Tues AL
    2016 Banshee Rune
  38. #3138
    Dec 2014
    Quote Originally Posted by Junersun View Post
    Personally I run neutral, but I'm also still rolling round on 26".
  39. #3139
    Jun 2014
    Quote Originally Posted by Phsx2 View Post
    I was kidding, to each their own. 26" def helps keep that bb height at a reasonable level. I bet it's a blast
    Current Bikes
    2016 YT Tues AL
    2016 Banshee Rune
  40. #3140
    Dec 2014
    Damn you sarcasm and your not translating through text! But yea, it's fun as a 26". Still think my next bike will be a long travel 29er mind.
  41. #3141
    Banshee Rune V2 Build Thread
    Hey guys thanks for the replies! Finally got the bike dialed and set her into the low setting. I was pretty impressed the bike felt good even with it being slacked out that much. Though, the Pike 160 doesn't match the DB Air CS at all and will need to be changed out for a Lyrik 180/150. Though, I'm tempted to try out the Suntour Durolux 180 since they have a free demo program to try it out for three weeks. Anybody have any experience on one??? Also, I'm running Nobby Nic's 2.6 and really like them so far. Feels like I'm riding a monster truck!
  42. #3142
    May 2014
    I have a Durolux r2c2 180 on mine. The fork is stiff and does not deflect at all. It was the hardest fork I have ever experienced to get dialed due to the lack of instructions online. However, I copied some settings that a reviewer wrote down on NSMB, I believe, and now the fork works like a champ.
  43. #3143
    Quote Originally Posted by retswen View Post
    Awesome, thanks!
  44. #3144
    May 2014
    My build
    Banshee rune 2016 gray and yellow
    Shox cane creek db air Cs
    Fork. Dvo diamond boost 170mm
    Brakes shimano saints m820
    Wheels. Stans arch With dt swiss 350
    Second par of wheels. Spank ozzy 395+ with hope
    Pro 4
    Chromag scarab pedals
    Mrp adaptor boost
    Sram gx rear d
    Sram x0 crank
    Chromag bza. Handlebar and stem
    Red monkey grips
    And
    Attached Thumbnails Attached Thumbnails Banshee Rune V2 Build Thread-img_3952.jpg
  45. #3145
    Jun 2014
    Looks good. Welcome to the rune fam!
    Current Bikes
    2016 YT Tues AL
    2016 Banshee Rune
  46. #3146
    Nov 2015
    I have a 2013 Rune V2, no drink bottle cage mounts. The newer ones have mounts under the frame. Anyone know if I can just drill and tap a couple of holes in my downtube and mount a cage, or would this be a dumb idea? Any alternative suggestions?
  47. #3147
    Jun 2014
    They have water bottle mount straps you could use.
    Current Bikes
    2016 YT Tues AL
    2016 Banshee Rune
  48. #3148
    Rippin da fAt
    Quote Originally Posted by samty View Post
    LBS should be able to install rivnuts for ya. Can't simply drill/tap cause there isn't enough meat in the frame tube to hold a bottle.
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
  49. #3149
    Nov 2015
    Awesome, i'd never even heard of rivnuts - I could see that working though.
  50. #3150
    Rippin da fAt
    Rivet on one end and nut on the other. Most bikes either have em or have a braze on of sorts out of the factory.
  51. #3151
    What? There's more?
    Reputation: tyrebyter's Avatar
    Bought a 2016 New in February 17 for an absurd price. Nerds love numbers: like head and seat tube angles, 7000 series aluminum, loooooong top tube, axle path, spring curve. But more importantly, it's a hoot to ride. CCDBIL is poop. Reverb is poop. Race Face wheels are poop. Pike RC3 is OK.. Those can, and will be replaced. But, what a wonderful bike.
  52. #3152
    Jun 2014
    Quote Originally Posted by tyrebyter View Post
    I never got along with the cane creek stuff. I would just blow through the travel. Agree with you on reverb. Currently on Easton arc30 (same as race face), it's still holding on.
    Pike is poop but I do have it on my hard tail with a corps ring luftkappe and that's made it barable...
    Current Bikes
    2016 YT Tues AL
    2016 Banshee Rune
  53. #3153
    Feb 2012
    Anyone here riding an extra large rune? If so how tall are you? Currently on 2014 large and upgrading to the current model. I want an extra large as the seat tube on current large is 20mm shorter than mine and i have too much exposed dropper post on my current rig. It is at minimum insertion (125mm dropper). The extra large has a 20mm longer seat tube and i figure if i get a 150mm dropper i can run it slammed to the collar.
  54. #3154
    What? There's more?
    I'm 6'0" (35" inseam) and ride an XL 2016. It's got gobs of stand-over clearance and a loooong reach. I like it that way; very roomy.
  55. #3155
    Oct 2017
    Hello all ! Finally after reading all comments here im sure to try a rune !
    I got a decent deal on an used rune from 2013. From what i can see compared to the newer ones the differences are a sligth headangle diff, bb height, and a bit of reach.
    I was thinking about putting an angleset in to get the frame closer to the 2016 geo, (im gonna run a dvo diamond with a-c = 555mm so i guess the angle set will drop the bb a little down towards the "standard" height with 545 a-c. (Im affraid the 10mm longer fork compared to the geo chart will get the bb a little to high ?) I ride in plain forrest with very little stuff to bash the bb. Mostly plain jumps and drops, very few rocks, so i guess a low bb is not going to hurt me?
    Does this sound ok or just pointless .?
    The build will be:
    -Rune v2 2013 medium (currently yellow/green scheme, maybe a respray to matt black.
    -Dvo diamond fork
    -Rs monarch+ (for now, will get a dvo jade before next summer)
    -Gx 1x11 gear
    -Hope tech 3 e4 brakes
    -Hope4 hubs with funworks trackmac rim
    -Dropper, hmm havent deceided yet
    -Wtb buddy newman limited edition saddle.
    Will post pic when the build is rideable
  56. #3156
    Feb 2012
    So i am building up a new xl rune after a number of years on a 2014 rune. I am a fan of wide rubber, i have been running a 2.5wt dhf on the front and a 2.4 ardent on 35 mm internal rims. I am hoping to run a 2.6 dhf wt tyres front and rear on the new frame. Anyone here running a 2.6 minion in their rune? What is clearance like? I think that 2.5 is the maximum recommended due to mud clearance. Just after some real world experience with this tyre size. Cheers
  57. #3157
    Nov 2015
    Quote Originally Posted by Kaptain Lurpak View Post
    The build will be:
    -Dvo diamond fork
    -Gx 1x11 gear
    @Kaptain Lurpak - I have a 2013 Rune also (26") and run a 170mm Marzocchi 55 Ti EVO fork with no angleset, and in slack setting. Fork also has a 555mm a-c length. It kicks ass like that and I certainly don't feel the need to lower the BB or slacken the head angle any further. A little more reach would be nice (large frame, I'm 183cm tall), but an angle set won't help with that. Maybe try without the angleset first in the slack setting and see if you like it.
  58. #3158
    Mar 2015
    thedrizzle I'm running a 2.6 dhf front and back on my 2013 Rune with no clearance issues. Those are on Easton ARC30 rims.
  59. #3159
    Feb 2012
    Quote Originally Posted by seankdebree View Post
    Thanks mate!
    I know it will fit the fork as it is boost (cane creek helm). You got a photo of the clearance in the rear? And overall with the fat rubber?
  60. #3160
    Oct 2017
    Okay sounds nice, im gonna run 27.5"
    But thanks ill try with normal headset and then see what it feels like before any changes
  61. #3161
    Mar 2015
    Quote Originally Posted by thedrizzle View Post
    Thanks mate!
    Unfortunately I don't have a clearance shot but here's an overall.
    Attached Thumbnails Attached Thumbnails Banshee Rune V2 Build Thread-picture1.jpg
  62. #3162
    Oct 2017
    Does someone know where to get a set of new flip chips ? i can only find them with purchase of a new rear dropout and it seems a little overkill just to get the chips.
  63. #3163
    mjw
    mjw is offline
    Feb 2007
    I have a set. PM me.
    • 2015 Kona Explosif Ti
    • 2015 Kona Process 111
    • 2016 Banshee Rune
    • 2017 Canfield Riot
  64. #3164
    Oct 2017
    Quote Originally Posted by mjw View Post
    Have you gotten my message ?
  65. #3165
    mjw
    mjw is offline
    Feb 2007
    Oddly, no! I will pm you
    • 2016 Banshee Rune
  66. #3166
    Feb 2012
    Stoked on the new rig!
  67. #3167
    Oct 2017
    F*** me sideways its sweet !!!!!
    What my is it ?
    And please report on how the jade is working for you, want to buy one during this winther.
  68. #3168
    Jun 2014
    Nice! I'm also rocking a jade! Congrats!
    Current Bikes
    2016 YT Tues AL
    2016 Banshee Rune
  69. #3169
    Jun 2014
    If you want coil, get the jade! The bladder system creates a smooth transition from compression to rebound. It takes big hits very well; I'm 230 lbs geared and a 8-10 foot drop is no problem.
    I can only attest to the stock low setting and it's leverage rate. I'm currently playing with some modifications... so far so good... time will tell.
    What my is it ?
    Current Bikes
    2016 YT Tues AL
    2016 Banshee Rune
  70. #3170
    Oct 2017
    Exactly because of the bladder system i wanted to go jade! ( I also have a diamond and love it and their filosofi around service etc)
    And i was curious about bigger drops, i had a tendency on my old bike to bottom out hard even though a high pressure (bos vipr)
    But it sound like the jade is tuneable to get a perfect fit.
    Also where i ride we have rather plain ground but when we have downhill parts they are rough and fun.
  71. #3171
    Jun 2014
    For bottoming out with the rune, I think air works better unless you get a bottom out assist like xfusion vector coil. But with the jade you get midstroke support that aids in getting support throughout the travel not just a big ramp up at the end.
    Current Bikes
    2016 YT Tues AL
    2016 Banshee Rune
  72. #3172
    For bottoming out with the rune, I think air works better unless you get a bottom out assist like xfusion vector coil....
    I had similar experiences with my DB Coil Inline on my Spitty. After 70-80% travel, she just kept sinking. Moved back to air.
    Somewhat related I noticed Push offers the 11-6 for these bikes. Kind of surprised I haven't seen a bunch of chatter about this since lots of Banshee riders toy with coils. May just be too $$?
    Sent from my XT1254 using Tapatalk
  73. #3173
    Sep 2015
    Quote Originally Posted by Lithified View Post
    the thing I have concluded is that for racing enduro, if you set your coil spring rate properly for good traction, you dont need support for bottom out on big jumps.. there are not many big jumps normally....whereas for DH racing or at your DH/trail loop with lots of jumps and hucks you start complaining about lack of bottom out control... with coil you just get tons of traction and compromise with spring rate for not-so-progressive leverage rate curves..
  74. #3174
    Jun 2014
    I've never had luck on DB products. They always blew through the travel and had that on off feel. I originally had the db coil but switched out of that almost immediately regretting my purchase.
    I think push products are great. If it wasn't for my recent 36 mod I prob would have purchased the coil conversion but I've been able to play with three different shocks for the price of the 11-6. All with how I intended the rune to act. The 11-6 is just too much money for someone like me who like to tinker with things.
    Current Bikes
    2016 YT Tues AL
    2016 Banshee Rune
  75. #3175
    Oct 2017
    Quote Originally Posted by luisgutierod View Post
    Hmmm. Hard choise then,
    Alot of our fun trails in denmark have small parts with drops in the height of 1-1.5m, but not many, most of the trail is roots, small jumps and drops.
    Our "dh" parks are smooth landings and so.
    Guess a coil would be ok then ?
    And when i go south for shuttle runs i could just swap to my monarch+ if i bottom out alot on a jade ?
  76. #3176
    Jun 2014
    Although being discussed in another thread, I thought I'd share my latest journey to being even more back pack less.
    Current Bikes
    2016 YT Tues AL
    2016 Banshee Rune
  77. #3177
    Sep 2015
    COmpromises man.. When i bottom out on a canecreek air, that just hurts... bottoming out on a coil dvo jade, not harsh... as I said I know some "pros" running CC db coil on Runes and it seems to work for them... it is expensive to try out things sometimes until you find what suits you. I have a Darkside that came with CC DB air and it amazing for big jumps, and hucks, but that bike with a DVO Jade its just butter..
  78. #3178
    Jun 2014
    Agreed with Luis here. Add on the ability to self maintain and modify the jades shim stack(not that it's needed) is an added plus!
    Current Bikes
    2016 YT Tues AL
    2016 Banshee Rune
  79. #3179
    Oct 2017
    Thats also exactly a part i love about dvo... The user is in mind when they made the product ! The service on my diamond is so easy, and they support is wow...
    Btw i love you mention butter luisgutierod, "Lurpak" is danish prime butter, im a fan of it,
    So you just sold it for me. Jade it is.
    Have to try it.
    Just got my diamond all tuned in with some extra oil in the air chamber and its out of this world now. Of the jade is the same im sleeping with the bike from then on.
  80. #3180
    Reputation: drapeado's Avatar
    Impossible to do on a medium size frame. The other day I vÍ seen some interesting stuff, a cage with 2 side supports, bottle on the right, tools on the left. Sadly, price was steep, and I can't remember the brand.
    Never tried coil on my rune, but after 4 diferent rear shocks and set up experiences I am happy with a bos kirk.
  81. #3181
    Hi!
    I have Banshee Rune 15'. I want to change (make custom) my frame decals. Have some1 decals in pdf/ai/eps?
    Thx for help guys!
  82. #3182
    Sep 2015
    I use this on my MY16 medium Spitfire. It's an old IS-PM mount, with an extra M5 hole tapped, M5 bolts loctited in place and a Fabric bottle. Whole lot zip-tied to the frame with Gorilla tape underneath.
  83. #3183
    Nov 2016
    Quote Originally Posted by teethgrinder View Post
Name:	banshee bottle.jpg
    Not bad for L frame but honestly it looks weird.
  84. #3184
    Nov 2016
    I upgraded a new water bottle. It's called fidlock and really works well on under downtube mount with no issues so far even at rock garden and way better than Fabric bottle.
    Bottle Twist - Bottle Set - Fidlock
  85. #3185
    flailer
    Sep 2012
    I am looking to replace my 150mm pike with something longer. What's the consensus on ideal fork length for bombing down rough trails? 170mm? Or more? What's the limit for a Rune V2 (2017) frame? Mines an XL (ie super long).
    '16 Banshee Rune
    '91 Specialized Allez Epic Carbon()
  86. #3186
    mjw
    mjw is offline
    Feb 2007
    I personally would not bother with longer than 160mm. The geometry wasn't designed for much longer, and I think you'll find many will say that. You might be able to squeek in 170, but personally I wouldn't.
    • 2016 Banshee Rune
  87. #3187
    Oct 2012
    Keep Pike and send it to Avalanche
  88. #3188
    mjw
    mjw is offline
    Feb 2007
    Quote Originally Posted by tomasis View Post
    Or just buy a 160mm air spring shaft.
    The OP wasn't really complaining about suspension quality....just amount of travel, so why recommend the Avy cart? And why send it in? The self install option is pretty stupid simple.
    • 2016 Banshee Rune
  89. #3189
    flailer
    Sep 2012
    funny you say this - switching to custom tuned open bath would be pretty awesome. Would a 10mm gain in travel be worth the admission price?
    And I can service my own fork. Compared to my old marz 888 the pike is stupid easy to work on.
    '16 Banshee Rune
  90. #3190
    Sep 2015
    or keep pike , and throw in Push ACS conversion
    18 Banshee ?
    16 Canfield Balance
    15 Banshee Darkside
  91. #3191
    flailer
    Sep 2012
    looks like i would lose 10mm of travel with the ACS conversion. The pike with the Vorsprung kit is a completely different fork. Seems like doing the avalanche kit would make it even better. hmm....
    '16 Banshee Rune
  92. #3192
    Jun 2014
    At 150 on the pike you have a steeper head angle but a lower bb.
    I'm played with my rune with all sorts of geometries. In the end a low bb was what I was after seeing how many other bikes I've tested came in much lower than the rune.
    I did enjoy 170 head angle though so now I'm rock a 160 with a offset bushing and that's hit the sweet spot for me!
    If you like the geo on the 150 then a quality damper would go a long ways. I never found the pike to suit well for my riding style.
    Current Bikes
    2016 YT Tues AL
    2016 Banshee Rune
  93. #3193
    Feb 2012
    I run the latest xl rune with a helm set at 170mm. It is super rad. I don't notice much more wandering in the front end than when i had a 160mm fork on a large rune
  94. #3194
    flailer
    Sep 2012
    The 150 has been working for me and I do like where the geometry sits. I have it set to the slack setting with the flip chips. Tough call on this one - I think I am leaning towards the avy cart.
    '16 Banshee Rune
  95. #3195
    Jun 2014
    Could also look at a luftkappe too. When I played with it on a HT I added more air pressure with the same sensitivity due to the increase in negative air chamber.
    Current Bikes
    2016 YT Tues AL
    2016 Banshee Rune
  96. #3196
    flailer
    Sep 2012
    I do already have the luftkappe installed and highly recommend it.
    '16 Banshee Rune
  97. #3197
    mjw
    mjw is offline
    Feb 2007
    Then charger is no slouch. The biggest benefit of the Avy is that it is more maintenance free. It's not like...a huge leap in performance, over a well tuned charger damper otherwise. If you want to avoid regular bleeding of a charger damper however, it's nice.
    • 2016 Banshee Rune
  98. #3198
    Jun 2014
    I agree also. although an oil change on a charger damper isnt too bad. it's when you want to break it down to a seal change, it becomes a game of patience.
    You can also send the charger damper to tuners like DSD (US tuner)....
    Current Bikes
    2016 YT Tues AL
    2016 Banshee Rune
  99. #3199
    Feb 2012
    A few updates to my ride.
    Hope cranks w/ direct mount hope ring
    Hope bottom bracket
    Hope pedals
    Nextie 38mm carbon rims on i9 torch hubs
    '18 fox 36 with push acs3 coil kit
    Cane creek double barrel coil cs w/ valt spring
    Black / decals for the forks are in the mail
    Can't see any more upgrades in the foreseeable future
