Page 23 of 32 FirstFirst ... 13192021222324252627 ... LastLast
Results 2,201 to 2,300 of 3199
  1. #2201
    Feb 2006
    Rode the Rune at the Verbier trails yesterday. Everytime I bring it to serious terrain, I´m verry impressed what this bike can handle and how composed it feels at speed even in the gnar! I love this bike!
  2. #2202
    Oct 2011
    Need some help on my new shock. Just got the ccdb cs in the mail today and will be changing out my float x tomorrow. Two questions:
    1) are all ccdb air cs shocks XV?
    2) at 220lbs what if any volume spacers should I start with? I'm thinking the big one, but would like to hear from anyone else who is of similar weight.
    Thanks!!!
  3. #2203
    Nov 2013
    do you buy the ccdb air cs especific for the rune? cause i think the large volune spacer is already installed but if you dont like the feel you can start with 2 medium v spacer
  4. #2204
    Reputation: juanbeegas's Avatar
    Oct 2007
    Will the rear triangle of the Darkside fit the Rune? I only ask because it looks like the chainstays on the DS do not drop as low as the Rune's and I'm assuming that'd mean I'd be able to clock my chain guide a little better? Plus it just looks sleeker than the Rune's...
    Rune rear triangle
    Darkside rear triangle
  5. #2205
    Oct 2007
    Quote Originally Posted by SmittyPDX View Post
    Thanks!!!
    What does your can look like?
    Here's what the XV can looks like in comparison to the normal cans.
  6. #2206
    Nov 2013
    i have the xv
  7. #2207
    Nov 2013
    Quote Originally Posted by juanbeegas View Post
    Rune rear triangle
    the rune is 160mm the darkside is 180mm plus i think they are completely imcompatible you will change your geometry far making the bike unstable or something like that but i am a retard your best chance is to ask keith
  8. #2208
    Oct 2011
    Thank you for the photo, that helped!!
    I have the standard can. Went ahead and installed the large spacer and the shock tonight. Sounds like the rune is based around the xv can so I should probably buy the xv can?
  9. #2209
    Oct 2011
    This may be a dumb question, but I searched and found nothing about setting sag on the ccdb with or without adjustments. When setting sag should I keep the factory adjustments OR zero out all adjustments first?
  10. #2210
    Oct 2007
    Set sag with all adjustments backed out to zero.
    You might want to try riding the bike with the normal can first. No volume reducers installed and then see how it feels. If you're still not getting full travel, then maybe look into getting the XV can. Personally, I kinda liked how my bike felt when I had a normal can shock installed(it was a replacement while my XV can shock went in for servicing).
  11. #2211
    Mar 2011
    Had my first shake down ride today at Blackrock in Oregon and my suspension feels like crap. The Float x felt bottomless on my Covert, but now is rough and I'm blowing thru travel way to easily. I had to pump the shock up to 250 psi just to make the ride manageable. Sounds like I need to add a spacer to make it more progressive. I'm 220 with gear btw.
    For those of you with the float x, what are your impressions? How much do you weigh and let me know if you're running any spacers.
    Only had my Rune for 10 days, but ridden it plenty in that time. Its got the FloatX CTD.
    Heres my thoughts on the shock:
    I've never really used the on the go adjustments of shocks and forks, but I gave the CTX switch a play and am really impressed with it. The frame weighs 1.25lb more than my Heckler, so I'm glad it climbs well, and with the shock in Climb, real long fireroads are very manageable. Far better than my old Heckler (RP23 push tuned).
    Trail mode is used almost all the time for me. I am playing around with either setting 2 or 3. It doesnt move too much on shorter climbs and descents are composed with no bottoming out.
    Descend mode is lovely and plush, but I do blow through the travel too easy. I up'd the pressure to 180PSI (I weigh 165 with kit), still getting through the travel too easy.
    My RP23, did this on my Heckler too, so I made myself a shim/volume reducer to stick in the HV sleeve. This worked extremely well, so I have ordered myself the Volume tuning kit to decrease the air volume and ramp up the compression a little more.
    Hopefully that is all that is needed as I like the CTD switch and have always got on well with Fox shocks (not forks!).
  12. #2212
    Oct 2011
    Shuttled the Rune on Sunday on a downhill trail allowing me to attempt to fine tune the shock. It's getting better, but not quite where I want it yet. Want to get it dialed before next week's Whistler trip; I think my problem is with the air pressure. I've been able to get 17mm in sag on 125 psi thru 155psi...heck maybe even higher, but I haven't tried. The question I have is for those bigger riders out there...what PSI are you running on you CCDB Air?
    I'm 220 with the standard can running the large volume spacer.
  13. #2213
    I'm 190 loaded up and run 155 psi in my db
  14. #2214
    sounds from your float x
    Quote Originally Posted by superfli View Post
    hi
    just got my 2015 rune with a float x
    set the corect sag...even a little less to keep them hight on the travel but
    evrey time i ride on trail mode the shock make a "comprestion "sounds of air whistling a load sound
    i had a float x on on another bike and it was quite
    so i just wonder is it just my shock?
  15. #2215
    Quote Originally Posted by loolilon View Post
    hi
    I'd contact Fox and explain this noise to them. It doesn't sound right.
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
  16. #2216
    Mar 2011
    My Float X doesnt make any noise. Contact your dealer or Fox.
    Installed a larger volume reducer the other day (next size up from the one in there, almost twice the size). Not had a chance to ride it this week. Hopefully Sunday...
  17. #2217
    krj
    krj is offline
    Reputation: krj's Avatar
    Aug 2005
    Is anyone using monarch plus debonair able To use all The shock travel ?
  18. #2218
    Mar 2013
    Quote Originally Posted by krj View Post
    I can not use only last 3mm of shock travel with 35% of sag. But I think it is not big problem, Monarch Debon feels almost the same as CCDB with botomless, midstroke and small bump compliance.
  19. #2219
    Mar 2011
    My Rune:
    Spec:
    Fox Float X shock
    2011 Vengeance HLR air forks (lowers are 2012 or 13, just replaced them)
    Hope pro2 hubs on Arch EX 26" tubeless
    Fat Albert SS 2.4 front
    Conti Mountain King 2.4 rear
    XT 170mm crank 1x10 Raceface 32th NW
    KMC x10 chain
    Superstar nano pedals
    SLX medium clutch mech
    XT shifter
    Charge Spoon ti
    2009 Formula the ones
    Thomson 50mm stem
    Sunline V1 745mm bars
    Superstar Excel lockons
    RS Reverb
  20. #2220
    Nice build!
  21. #2221
    Oct 2014
    Here my interpretation of the Rune V2. I am absolutely in love with the Rune !
    Fork: Pike RCT3 Solo Air
    Shock: CCDB Air XV CS
    Brakes: Formula The One 203/180
    Handlebar: Dartmoor Nitro 780
    Stem: Spank Spoon 40 mm
    Grips: ODI Rogue
    Shifter: Shimano SLX 1x10
    Chainguide: 77designz
    Crankset: Shimano SLX
    Derailleur: Shimano SLX Trail
    Pedals: Spank Spike
    Wheels: Spank Oozy Trail on Bitex Hubs
    Tires: Minion DHF and Highroller II
    Seatpost: Rock Shox Reverb
    Saddle: Selle Italia XR
    Weight overall 14,3 kg
    Regards from Germany !
  22. #2222
    Reputation: johndeere's Avatar
    May 2010
    Both nice ones, congrats!
  23. #2223
    Banshee Rune V2 Build Thread
    Wanted to get the xtr m9000 for my rune v2. Not sure if mid cage will cut it after taking into account the chain extension when suspension is fully compressed. Will Keith be able to advice please?
  24. #2224
    krj
    krj is offline
    Aug 2005
    R: Banshee Rune V2 Build Thread
    Quote Originally Posted by mik8yu View Post
    XT mid Cage run smoth
  25. #2225
    krj
    krj is offline
    Aug 2005
    Quote Originally Posted by alexey_shmat View Post
    Mine With 30% sag leaves 15 mm of travel !
    Ps Even alter Big Hit sessions
  26. #2226
    Oct 2014
    SmittyPDX, I'm coming off a covert carbon and seriously considering the rune. Whats your impression after the swap? My main reason for leaving the covert is I always disliked how high the front end felt. I made the mistake of stepping on an enduro and just loved the way the cock pit felt so I'm going for something with a lower stack, which it looks like the banshee will suffice. The enduro was a possibility but I hate specialized and its ridiculously priced, I could get a complete rune for the price of the frame lol. So if anyone has any input feel free, Smitty is just coming off the same bike.
    Also, how'd you end up weight wise between the two, I never weighed my covert, or worried about it, but I don't exactly think its lightweight lol. The trails by my house are pretty light duty so I'm kind of thinking I might want to head for something a bit smaller. Then again, I'm worried when I hit rowdier trails a lighter bike might hold me back.
  27. #2227
    Mar 2013
    Suggest that you need just play with pressure and sag. For the time being I can not recognise big difference against CCDB CS air shock, but 170 gramm less weight :-)
  28. #2228
    krj
    krj is offline
    Aug 2005
    Great To listen !
    Can You so Kind To share Your figures (weigth , pressure , sag, rebound ) as reference for My play ?
    Thanks in advance
  29. #2229
    Mar 2013
    Great To listen !
    Thanks in advance
    I am 75-78 kg depending on equipment, run 170-175PSI and 5 clicks of rebound from fully open for AM use.
    First you need to set proper sag, should open rebound and LSC to fully open prior. I am using Banshee table from their web site to set sag correctly and take 17mm by shaft. But you also need to check how you will used this sag in your style of ride - if you have more dowhill you need to set pressure while you stay on pedals above rear wheel, if you have 50/50 up and down you need to set pressure while you seat in saddle. After that you need to set rebound according to your prefers, trail conditions etc., it should be only up to you
    Hopes this should be enough information to set up correct figures.
    Cheers
  30. #2230
    krj
    krj is offline
    Aug 2005
    Cheers
    Awesome I'll give a try following Your report
  31. #2231
    Mar 2013
    Okay, please revert with outcomes
  32. #2232
    GUIDANCE COUNSELOR
    Reputation: NoahColorado's Avatar
    Whoa black betty, bam a lam....
    NOAH SEARS
    MRP - Brand Manager
    Pivot Cycles - Team Rider
  33. #2233
    That us one bad a#@ bike!
    I want it!
  34. #2234
    Indeed eventought t9 won't help.
    Let us know about ifp adjustment result
    Finally had a chance to ride the Monarch after being reshimmed at the LBS.
    According to the tuner, the stack is now similar to the standard low compression tune.
    First impressions were good.
    The shock is now much more supple at the beginning of the stroke, even after increasing the pressure to get sag near 28% shaft travel.
    Once the weather gets better I'll have to properly test it downhill at speed...
    Cheers!
  35. #2235
    krj
    krj is offline
    Aug 2005
    Run Every day And get fun
    http://vimeo.com/m/108759194
  36. #2236
    krj
    krj is offline
    Aug 2005
    Quote Originally Posted by tugamik View Post
    Cheers!
    Is It a 'standard' reshimmed or Fit To Your bike, weigth, cycling Style, ... ?
  37. #2237
    Mar 2011
    Just added 650b wheels and dropouts to my Rune. I was worried about clearance on my 2011 Vengeance (although lowers are newer as I replaced them a few months ago - 2012/3?), even though they say they are 650b compatible. Anyway, I fitted a Magic Mary:
    Plenty of clearance even with a mudguard
    #Vengeance #XFusion650b
  38. #2238
    Not a standard reshiming, but more "kinda" based on feeling, considering my comments about base shimming...
    I guess I have to man up, get the proper tools and start to mess with the shims myself..
    Cheers!
  39. #2239
    Nov 2012
    My Rune.
    I love it!
    We went to the photographer's studio
    Attached Thumbnails Attached Thumbnails Banshee Rune V2 Build Thread-ldn_2109-copy.jpg
  40. #2240
    Mar 2013
    My one with updates. Monarch Plus Debon air instead of CCDB CS, PS Pike RCT3 instead of Mattoc Pro.
  41. #2241
    Oct 2011
    Quote Originally Posted by tp311 View Post
    Yeah the covert definitely has a higher stack then the Rune. Honestly I liked the taller stack, mainly because I'm 6'4 and it felt right. I have all my spacers under the stem now on my rune to get the controls up a bit. I loved my Covert on the descents...felt bottomless and poppy (float x). I've yet to dial in the CCDB to feel the same, each ride I'm getting closer tho as I play with the settings. Climbing wise the rune wins hands down!
    As for weight, my covert was 32 pounds even...mind you that's an aluminum XL. The Rune hasn't been weighed yet but I suspect it to be in the 33lbs range.
  42. #2242
    Why the change from mattoc and ccdb to rockshox? How do they compare?
  43. #2243
    Mar 2013
    Quote Originally Posted by 92SE-R View Post
    Mattoc and Pike is very similar, but I want to try RS and now I love it better. Regarding CCDB it gives to me not enough support on uphill even with CS, but with Monarch now bike become alive)) On trails and DH routes Monarch perfomed like CCDB with a little bit more resilient feeling.
  44. #2244
    Professional Troll
    Reputation: Gemini2k05's Avatar
    Apr 2005
    Agreed. The stack on the rune is TINY. They go with a super short headtube on the XL because it's the same one used on the L/M. It's just a cost saving measure and a really crummy one at that. The headtube is wayyyyyy to short on the XL rune. It should be at least 1.5 inches or more taller.
  45. #2245
    Oct 2011
    Quote Originally Posted by Gemini2k05 View Post
    I'm guessing the short stack has me too far forward that I'm putting so much pressure on my hands that they are so sore and almost bruised. I have some relief now that I've added a couple spacers to the stem, but agree...head tube should be taller.
  46. #2246
    Apr 2013
    Hey guys, first time on this thread, just got in my 2015 frame here in the uk, the ison site had implied that the bike shipped with 26" dropouts but looking through the box today the set that came with it were 650b ones. So the question is how badly will it affect the bike as i am going to be running it as a 26"? Looking at the geo numbers on the banshee site its like an extra .4" in chainstay length and like 10mm in bb height but as there is a difference of 25mm in erto sizes i assume there is also compenation for the wheel size as far as bb height goes in the dropout, if that makes sense. i.e. they off set a bit. Mainly just need someone to tell me what i think i already know, get the right dropouts even if it means not getting to ride the bike this weekend. Or am i crazy and the difference will be negligable? Builttoride? little help?
  47. #2247
    Hi Alasdair.
    When I test ride the Rune from the LBS, the bike had 27,5 dropouts and 26 wheels.
    I did notice the traction going uphill was very good and the front was hard to lift. Other than that, the bike rode amazing (to the point I actually got one for myself).
    My guess is that you will have no problem riding the bike in that configuration, other than a slightly long chainstay.
  48. #2248
    The 650b dropouts essentially just lengthen the chainstay... no other effect when compared to running 26" dropouts with same wheels.
    I'm sure if you speak to your dealer, or call up Ison they will be able to sort this for you quickly if you wish... maybe even before the weekend
    Banshee Blog
  49. #2249
    Couple questions for you guys:
    Anyone here come from a MK2 Nomad to a V2 Rune? I had a V1 Rune then got a Nomad after the bushing issues. V2 Rune is at the top of my list to replace the Nomad, and was curious if anyone had impressions between the two.
    How's a coil shock feel on it?
    Anyone have weight of Medium frame?
  50. #2250
    Mar 2011
    Weight of a medium with Fox FloatX is 8.5lb.
    Cant help with the Nomad though
  51. #2251
    Apr 2014
    Quote Originally Posted by xhailofgunfirex View Post
    I used to have a Nomad Carbon (mk2) and now ride a 650b Spitfire. The Spitfire is so much better than the Nomad in just about every situation. Climbs better, geometry is infinitely better than the very cramped Nomad, and the Banshee suspension layout just feels a heck of a lot more lively. My times have improved down even the most technical local trails that we have, and even the 140mm travel Spitfire feels more stable than the Nomad due to the longer TT and wheelbase. My Nomad had a damn good suspension setup with the Push linkage and a custom tuned RC4, but it still felt less controlled and efficient than the Spitfire does.
    2014 Banshee Spitfire 650b
    2011-ish Chromag Samurai
  52. #2252
    Apr 2013
    cheers guys ison sorted it out quick, should have em tommorrow. Awesome. been waiting months for the frame so really did not want to have to put off riding it any longer, went ahead and half built it tonight after work.
  53. #2253
    PM sent, thanks for posting up.
    Quote Originally Posted by babyz View Post
  54. #2254
    krj
    krj is offline
    Aug 2005
    My Run Every Where killer machine
  55. #2255
    Hi Guys. this is a great thread!
    just gotten by first Banshee and its a Rune!
    the following is a picture of my bike with my friends Legend.
  56. #2256
    Apr 2013
    Hey, picture of the build at the end prior to riding, saddle still a bit off level and maxle warning sticker was still on but its done. Rides really nice and is much better at it than i am for now. Everything want together no problem at all. Dream bike. Been trying to get it together for months and finally got the frame.
    Spec:
    Frame: 2015 Lg. Black Banshee Rune 26"
    Forks: Rockshox Pike RCT3 160mm 26"
    Rear Shock: Cane Creek Double Barrel Air CS
    Headset: Hope Integral Tapered
    Tyres: Schwalbe Hans Dampf Super Gravity
    Rims: Mavic EN821 Tubeless
    Spokes: DT Swiss Competition Black
    Hubs: DT Swiss 350
    Brakes: Shimano Saint M820
    Rotors: Shimano Saint/Icetech XT (203/180)
    Stem: Easton Haven 55mm
    Handlebar: Easton Haven Carbon 31.8
    Shifter: Shimano Saint M820 Ispec-b 10 Speed
    Rear Mech: Shimano Saint M820
    Cranks: Shimano Saint M810
    Chainring: Blackspire Narrow/Wide 34t
    Pedals: Shimano Saint M820
    Chain Device: MRP AMG
    Grips: Easton Lock On
    Chain: XTR
    Cassette: XT 11-36
    Seatpost: Rockshox Reverb Stealth
    Saddle: Specialized Henge
  57. #2257
    Nice build Alasdair! Have you put the bike on a scale and weigh it? Just curious.
  58. #2258
    Apr 2013
    oh yeah forgot that bit, 14.8 kilos or 32.6 pounds.
  59. #2259
    Mar 2011
    I now have 2 sets of wheels, 26" Flows for my DH days (135x10) and 650b Superstar Tactics (142x12) for Enduro racing and general riding. Currently I swap the dropouts to the QR 26 or 142 650b depending on wheel. I can get a 142x12 adapter for my 26" wheels to speed up changes, question is does anyone run 26" wheels in the 650b dropouts? I assume the BB will be lower and the wheelbase will be longer? Is it unwise to do this, would I be wasting my money on the adapter and should I just continue to swap my dropouts?
    After a couple of extremely muddy enduro's it would be useful to swap my wheels quickly to the 26" for the really muddy stages Thanks
    Enduro:
    DH:
  60. #2260
    I currently run my Rune w/ 26" wheels and 650b drop outs. The BB height is actually the exact same, just the chainstay length is longer.
    I was hoping the 650b dropouts would offer a lower BB height (to account for the added height of 650b wheels), but that's not the case if you look at the GEO numbers on the site. Comparing the 26" to 650b BB heights on the site, the 650b geo numbers are .4" higher across the board.
    Speaking of which, does anyone happen to have a set of the 26" x 142mm dropouts they'd be willing to part with for cheap?
  61. #2261
    Aug 2014
    26" or 27.5"? need input here....
    heyya rune riders..
    i've got my rune v2 frame recently and I'm in the middle of building up my bike. 1 thing that got me confuse here ... whether to build up 26" or 27.5" .... on papers , of course 27.5 got an advantage compare to 26" (atleast from my point of view) , but im doubt if it don't work out as well for me as im quite short. my height is between 5'3" or 5'4".
    i have no doubt in my frame size which is definitely S size, but the wheel size is killing my head now.
    i really need your input and an honest opinion here. it is good if i got an input from the riders whose height is same as me. i appreciate any of your comments dude.. thanx
  62. #2262
    Mar 2011
    Quote Originally Posted by daway View Post
    Nice one, thanks!
  63. #2263
    Oct 2012
    Anyone using rune 27.5 with 150mm fork?
  64. #2264
    ptd
    ptd is offline
    Oct 2012
    Quote Originally Posted by kenko View Post
    Yeah I'm using xfusion vengeance @ 150 to get 545 axle-crown so bb height is low and head angle isn't too slack. I don't notice 10mm less travel than the rear, but I'd rather have 160mm with lighter weight, more fork offset and still minimal axle-crown.
    Vengeance are heavy and creak so I'm looking to upgrade.
    New fox 36 @ 160mm has 549 axle-crown (650b)
    Pike @ 160mm has 552 axle-crown (650b) (542 axle-crown @ 150mm)
    Fox has more fork offset, better for slack head angle/650b in my opinion.
    Rune with 12mm lower bb height with 549 axle-crown forks would be ideal!
    Fox slightly heavier, more expensive.
    E-paper has fox for the win!
  65. #2265
    May 2013
    Ignore this. was in wrong thread.
  66. #2266
    my 2015 rune
    came up 13.7 kg
    fox 36
    fox float x at the rear
    ztr arch on mec mahoon king 120 hubs 1.8 kg wheel set
    doss seat post
    x01 crank
    xo shifting
    mec mahoon 780 carbon handelbar 40mm rental stem
    im happy!!!!
    Attached Thumbnails Attached Thumbnails Banshee Rune V2 Build Thread-unnamed-1-.jpg
  67. #2267
    Dec 2013
    I know this has probably been talked about but I cant find an answer.
    Have there been any changed to the dropouts or derailleur hangers for the 142/12 dropouts.
    No matter how well I set up the rear mech it always drops the chain to the gap in between the hub and frame. This is with a Zee, Saint and an X9.
    Also I had to put spacers on the brake bracket to center it over the disc.
    Anyone else with these problems? and what did you do??
  68. #2268
    Mar 2011
    Quote Originally Posted by cortolillo87 View Post
    Mine did that the other day. It's only happened once, so I ignored it, thought maybe just need to tweak the hi/lo adjuster.
  69. #2269
    Dec 2011
    Here's mine. Medium frame. Total weight(incl.200ml of Joe's no flats+ 40T cog in the rear) 14.4 kg.It could easily come under 14 kilos but who cares.The bike is awesome and it feels lighter when pedaling than most light bikes i rode.
    fork: Manitou Mattoc(stiff and a tad better than the Pike and way better than the Lyrik i previously had)
    Wheels: Spank Ozzy trail rims+Bitex hubs+Sapim race spokes(just incredible)
    Brakes: Formula the one 203 front 180 rear
    Stem-handleber:Spank spike bearclaw
    Shifter:Sram x7(10 speed)
    Rear derailleuer:Sram x7 TYPE 2
    Cassette: Shimano XT + 40t cog from Fouriers
    Tires: Geax goma 27.5 (now called Vittoria 2.25 TNT front and rear BUT they are HUGE for 2.25 believe me..also great tires)
    Pedals:VP componenets vp-007
    Crank: Shimano SLX
    Seat tube: Specialized command post
    Chain guide: Straitline Silent guide
    Saddle: Selle Italia XO
    Last photo is for tire clearance in full muddy conditonsBanshee Rune V2 Build Thread-10390040_809585659107536_2872155046076453735_n.jpgBanshee Rune V2 Build Thread-10553434_809585739107528_6791894395767715575_n.jpgBanshee Rune V2 Build Thread-10410169_10205216796444693_1705115937553693695_n.jpgBanshee Rune V2 Build Thread-10804_10205216787844478_7152714402264928536_n.jpg
  70. #2270
    came up 13.7 kg
    fox 36
    doss seat post
    x01 crank
    xo shifting
    im happy!!!!
    With the fox 36, the wheelbase look shorter than when I had Pike on. It felt somewhat stiffer with the fox 36 though
  71. #2271
    I've been riding a Rune v2 since thus past June and love it. My norco 26" range and turner 5spot have not been getting much use since I got it.
    Recently I purchased a pike fork and a set of ibis 741 carbon rims. All I can say is WOW! The pike is solid and even though its 10mm less travel than the 170 vengence it replaced it bombs trails and feels like it has more travel than it does(160)
    The ibis 741 wheels are the real highlight of this new combo. Super stiff, pretty dam light and at 41mm wide they have a large foot print that shines in steep muddy terrain like I ride in the pnw. I've suffered rim damage in the past with my flow rims when I went below 32 psi but with the 741's I'm goin below 20 psi with no burps or dings! Pretty unbelievable. The rune peddels noticably better uphill with a hr 2 in the rear and magic marry up front.
    I'm sold on wide rims and wanted to share my experience
    Chris
  72. #2272
    Aug 2013
    Banshee Rune V2 Build Thread-932188d1413654607-banshee-rune-v2-build-thread-ldn_2109-copy.jpg
    Quote Originally Posted by yancho View Post
    My Rune.
    I love it!
    Nice! Is that the xfusion rear? Can you explain the difference on how it's set up backwards or forwards?
  73. #2273
    Probably about to be in the market for a new frame, and the V2 rune is definitely on the short list. It seems to have lots of good reviews. Currently running 2006 SX with 180 float up front. It is my do it all bike for xc, am, and dh other than my dj. Looks like from many perspectives I would see noticeable improvements from my current ride. How does well does the rune do as a do it all bike? Also wanting to try my hand at a few enduro races in the 2015. Also been eyeing the GG megatrail, but sure like what I am seeing on the Rune and all the reviews.
  74. #2274
    If you don't mind the weight, it's a very good do it all Bike. I ride anything from downhill to technical decent to all mountain with it. No regrets
  75. #2275
    For those who came from a sc nomad, can u tell the difference between that and a rune? Thinking if to get one for downhill and some enduro riding. Eyeing a 2013 aluminum nomad. Can't tell if the vpp is gonnna give a different feel
  76. #2276
    Nah don't mind they weight, I see lots of posts of these around 31 lbs. My sx is 35 so I will gain, also the pedalling platform should be much more effective.
  77. #2277
    krj
    krj is offline
    Aug 2005
    Anyone with cc dbinline ? Which are the Pros / Cons of The shock mounted on a rune ?
  78. #2278
    I fix choppers
    Reputation: HELLBELLY's Avatar
    A Cane Creek rep stated to me when I questioned whether to run a DB Air CS vs an Inline, that if you are riding the bike hard and if you are bigger rider (I'm 200 lbs) then get the DB Air CS. The adjustments and feel are otherwise identical, but the DB Air CS will perform better in the aforementioned scenario.
    "Everything popular is wrong." -Oscar Wilde
  79. #2279
    krj
    krj is offline
    Aug 2005
    Quote Originally Posted by HELLBELLY View Post
    Great Thanks a Lot. Being a breith below 160lbs and riding aggressive But no jump non Big Drop It sounds suite to My rune and need
  80. #2280
    Jan 2015
    I've had my Rune for 6 months now and can't say a bad word about it. It has become my one bike to do everything on, so much so that I'm going to get rid of my Dh bike this year and just ride the rune. I guess it depends on the type of riding you do, prob wouldn't pick it to go xc riding on, that's not to say you can't go on all day rides, i did the Whistler EWS on it last year which was the longest day i think i've ever done, its just much better suited for steeper terrain.
    Have the cane creek DBcs which i love, not changed it too far from the suggested setup. Couldn't believe how fast it was when I first rode it, was going into sections way quicker that before and yet in more control. Very confidence inspiring. It really does rip the downhills and yet its a better climber than it should be, I find myself getting up things that I wouldn't have on other bikes. In summary, I love it....
    Happy to answer any questions about it.
    Hope that helps
    Wallace
  81. #2281
    Jan 2014
    My sentiments exactly, haven't ridden my dh bike since I got my Rune 12 months ago. Just no need for it on most UK tracks. The way the Rune climbs still surprises me, it has no right to do so with a 65° head angle.
  82. #2282
    Reputation: dirtrider76's Avatar
    Sep 2012
    I put mine in the highest position just to see what it would do the other day. Rode it last night and it rips up hill now. I was kinda surprised it made as much difference as it did. Tire clearance is tight with a 2.3 now but oh well.
    I like to fart when I'm in front of you on a climb
  83. #2283
    Jan 2014
    Did it feel much different on the downs?
  84. #2284
    Sep 2012
    Minimal that I noticed so far. I have 1 ride on it though on frozen tundra.
  85. #2285
    My 2014 Rune V2, XL:
    frame: Banshee Rune V2, Xlarge
    shock: Float X
    fork: BOS Deville, 170mm
    headset: Reset Flastack
    stem: RaceFace Atlas, 35mm
    spacers: Ultralight Carbon
    bar: Easton Havoc Carbon
    grips: ODI Lizard Skinz
    brakes: Avid Trail Worldcup
    discs: Formula The One, ti bolts
    wheelset: Roval Traversé SL 26", tubeless
    tires: Specialized Butcher / Purgatory Control
    crankset: XX1
    crankboots: RaceFace
    bottom bracket: GXP
    shifter: XX1
    derailleur: XX1
    chain: XX1
    cassette: XX1
    chainring: Absolute Black DM, 32t
    pedals: twenty6 Predator ti
    seatpost: Syntace Highflex
    seat: SLR TT custom
    seatclamp: Tune Würger
    12,92 kg
  86. #2286
    Aug 2013
    Nice! That BOS looks legit on there.
    I am building my 2014 stealth right now and might go with custom decals. Can anyone tell me if the existing decals can be removed for new ones? Thanks
    [QUOTE
    [/QUOTE]
  87. #2287
    Sep 2013
    I run maxxis highrollers 2's with a ibis 742 carbon rim and none of the rear dropout settings will work other than the slack one. No room for wheel in other settings. The axle is about an inch off from fitting with the steep chip in.oh well, slack it is:-)
  88. #2288
    Mar 2011
    Quote Originally Posted by cburden View Post
    Is that with the correct dropouts for the wheel size? ie are you using 27.5 wheels in 26 dropouts? I've got loads of room in any setting - ok my tyre isnt massive (Kenda Nevegal X Pro 2.35), but I'm suprised by yours?
  89. #2289
    Sep 2012
    I ran a 26x2.4 HR2 in back in the middle setting with tons of room. I did have cleaner issues with my TK2.4 though. I wouldn't clear the highest setting, it cleared but was snug going in and out in the middle and was fine slack.
    I currently have a clutch 2.35 in back in the highest setting with no issues.
  90. #2290
    Jan 2015
    2015 XL Frame
    2014 Rockshox Pike 160mm Solo Air
    760mm Easton Haven 35mm Bars
    40mm Easton Haven Stem
    Cane Creek 40 Headset
    Odi Rogue Grips
    125mm Reverb Stealth Dropper
    Stan Flow 650b rims on Stans 3.30HD Hubs
    Zee Cranks 170mm
    North Shore Billet 32n NW chainring
    11-36xt cassette w/40t Hope T-Rex Expander
    Deore XT rear derailleur
    XT brakes front and back
    Minnion DHF with a Schwalbe Rock Razor on the rear.
    Straitline Defacto Pedals
    Pretty stoked on it. Climbs almost as well as my previous main bike, a 2012 RIP9, and I can take it down descents i'd usually shuttle with my kona entourage that has a vivid air and 180mm in the front. Comes in at 33 pounds I believe.
    I was worried that it wouldn't climb well enough/be too heavy/not have enough gears, but i was wrong. Love the wheel size. I still have to shift my seatpost around to get the proper height on downs and ups, and i'm still getting used to the rock razor in the rear. May well end up having to buy a 150mm dropper, or put a quick release on the seatpost.
    I also wasn't very keen at all on the colour but could only get orange in the extra large. However it was love at first sight when it arrived on order, wouldn't change it for black at all, even though i've exclusively ridden black bikes in the past. it absolutely pops and it gets heaps of love, often from motorists who like that they can see it when i'm riding to the trailhead, it's pretty funny. that combined with the size makes it unmissable!
  91. #2291
    Mar 2013
    Nice Rune! I recently scored some gravity light 7050 cranks on ebay for cheap.. I need a new seat/rear derailleur/shifter. Love this bike!!
  92. #2292
    Jan 2015
    Thanks. As you can see i run it in the neutral setting, but i'm considering putting it into the highest as this is the bike I pedal. It's already very slack compared to my old trail bike.
  93. #2293
    Sep 2013
    I have both the 26 and 650b drop outs. I'm going to try some highroller 2 on my stans 650b flow rear wheel and see if that works....will report later.
  94. #2294
    Mar 2011
    Good evening, I'm thinking about buying a Banshee RUNE but do not know the posts to put forward four options is the X FUSION METRIC BOS IDYLLE SC fox 36 float 26 180 fit RC2 the fox 36 Talas 26 180 fit RC2
  95. #2295
    Feb 2015
    Hi all
    This is my first post on this forum,and I only joined for this thread.
    I've just pulled the trigger on a black on black frame (I was torn between black or orange)with CCDB AIR CS and fox 36 170mm forks.
    I'm building it up as a bike park and uplift bike as funds allow and I'm using this forum as inspiration.
    Has anyone had any experience with guide rs brakes ?
  96. #2296
    Feb 2015
    Sweet Ride san_andreas I was torn between black or orange but ordered black after seeing your pic.
    What size rotors are on the bike?
  97. #2297
    Aug 2013
    Quote Originally Posted by Milesos View Post
    I don't have any experience with them but a 4 piston brake on 180mm rotors seems like a must for a bike like the Rune. CRC has these plus the rotor for about $150 right now and I couldn't resist. I'll post my ride once I get them mounted.
  98. #2298
    Feb 2015
    Quote Originally Posted by MAGPIE!!! View Post
    [QUOTE
    [/QUOTE]
    Hi MAGPIE!!!
    There are no decals on the black on black frame.
    I think they use a masking system when shot blasting the frame then remove before anodising .
    This gives the rough blasted and smooth masked off contrast.
  99. #2299
    Aug 2013
    Gotcha, makes sense, Thanks!
  100. #2300
    650 vs 26
    I converted my intense tracer 2 from a 26er to a 275. I don't like how high the BB is. I like the geometry of the rune, but am concerned I'll run into similar issues if built with 275 wheels. Any thoughts other than build a 26er?
