Page 21 of 32 FirstFirst ... 1117181920212223242531 ... LastLast
Results 2,001 to 2,100 of 3198
  1. #2001
    Feb 2012
    Quote Originally Posted by erlkönig View Post
    not sure but maybe intense micro knobby?
    thx...yes its = intense..
  2. #2002
    Reputation: bikeboardorblade's Avatar
    Correct.
  3. #2003
    Quote Originally Posted by izi1 View Post
    Im using maxle... nice
    Quote Originally Posted by ryan_daugherty View Post
    I'm using a maxle. DT one works well too.
    krj
    krj is offline
    Reputation: krj's Avatar
    Aug 2005
    Shock : Sag vs. Feeling
    Dear Runer',
    After some months of riding I'm struggling, having he Fox Float CTD , with the choice between the correct SAG ( between 25%- 28%) and the feeling / shock usage.
    If I set the correct SAG than I 'll never be able to use all the shock extension and the bike "seems" nervous in some condition ( fast descending on small medium rough rocks )
    If I forget the SAG and set the shock pressure to maximize the shock extension usage I'll have a smoother feeling.
    With that said where is my mistake ? what is going wrong ?
    Do you have any suggestion on this topic ?
  5. #2005
    Tmh
    Tmh is offline
    You are not doing anything wrong. Fox is. Get it Push'ed or use something similar tuning expert and after that it's so much better. Or get better shock like CCDBa.
  6. #2006
    Edgar
    Or a Bos Kirk... I've never had the chance to have a feeling like this. Really like the kirk, it's sensitive is overwhelming
  7. #2007
    esr
    esr is offline
    Sep 2013
    Quote Originally Posted by stunzeed View Post
    Question: anyone have 2 setups for their rune ? Something like a DH mode ( wheels, tires, Eric) and trail like wheels,etc?
    I have something like that
    -DH setting, 26 Magic Mary SG, 11-36 x 38t, tubless
    -AM setting 27.5(lb 35 mm carbon rim), High roller 2.35, 32t x 11-42, tubeless
    Fork: Fox Float 36 180mm(set at 170mm), enougth tire clearance with 27.5Banshee Rune V2 Build Thread-img_0002.jpg
  8. #2008
    krj
    krj is offline
    Aug 2005
    Quote Originally Posted by Tmh View Post
    Thanks !
  9. #2009
    krj
    krj is offline
    Aug 2005
    Quote Originally Posted by EdgarB View Post
    I love it but i cost a lot of bucks !
    Let me try pushing the float.
  10. #2010
    Mar 2013
    Quote Originally Posted by krj View Post
    Dear Runer',
    I have the fox float x and it does exactly the same thing.. i think my sag is 35% and i still have to hit a good drop or case a decent jump to use the travel. I'm 190lbs too..
    Would the ccdb air or the x fusion vector air hlr be worth it?
  11. #2011
    Reputation: dirtrider76's Avatar
    Sep 2012
    Curious did you try pulling the volume spacer in the shock? IIRC mine had 1 thin spacer in it when I cracked it open. For me I went to a bigger spacer cause I was using all the travel pretty easily since I'm 250lbs. Adding a larger spacer let me run lower pressure but not bottom so easily, removing the spacer may help you use all the travel. I have the stock Fox Float CTD.
    I like to fart when I'm in front of you on a climb
  12. #2012
    Reputation: qbert2000's Avatar
    i'd look at avalanche racing and their mod for the float. craig is awesome to deal with and the mod has excellent reviews
    Float CTD and RP23 SSD Modifications
  13. #2013
    So I just picked up a large banshee rune frame with 26" dropouts, is there any consensus on which wheel size is best? I'll be buying new wheels and forks, and was initially just going to stay with 26, is 27.5 a noticeable difference?
  14. #2014
    Mar 2013
    Quote Originally Posted by nick1122 View Post
    noticeably different, Yes.
    Better?? You'd have to be the one to decide that.
  15. #2015
    Mar 2013
    Quote Originally Posted by qbert2000 View Post
    I keep looking at the webiste.. Hmming and hawing.. Id really like the Cartridge for my Marzocchi 888 cr model as well as send them my Fox Float X. Not cheap though..
  16. #2016
    Quote Originally Posted by Dirk77 View Post
    no, not cheap but the general consensus is a drastic improvement. i've had stuff pushed and i had a vanilla rc get the avalanche treatment and there is no cpmarison between the two imho. avalanche is head and shoulders above push
  17. #2017
    Reputation: uzurpator's Avatar
    Dec 2005
    My Rune after some serious "upgrading", which I consider a buzz word for switchin stuff around
  18. #2018
    Apr 2014
    Almost in it's final form...
    Still waiting for,
    - Carbon Cranks
    - Carbon Bars
    - Dropper Post
  19. #2019
    krj
    krj is offline
    Aug 2005
    No one is thinking about running the dbinline on the Rune ?
  20. #2020
    Sep 2012
    Curious what's your Rune weigh in at?
  21. #2021
    Apr 2014
    Quote Originally Posted by dirtrider76 View Post
    I will weigh it this weekend
  22. #2022
    Jan 2011
    Updated my rune... and went 650b
    - e13 TRS+ Wheels
    - Schwalbe Tires - Magic Mary/Hans Dampf
    - Saint Brakes
    - Crank Brother Mallet DH
    - OneUp42 Cog
    - Race Face Narrow Wide Ring
    - RockShox Pike
    Attached Thumbnails Attached Thumbnails Banshee Rune V2 Build Thread-rune.jpg
  23. #2023
    krj
    krj is offline
    Aug 2005
    Quote Originally Posted by photocycler View Post
    It looks awesome.
    How do e13 wheels RUN ?
  24. #2024
    Jan 2011
    It looks awesome.
    Thx Man! Love the wheels so far, engagement is quick and wheels just plow over everything between the size and stiffness
  25. #2025
    nice!
    I wish I could have ridden it with 26, curious to see the differences
  26. #2026
    Jan 2011
    Quote Originally Posted by cicot View Post
    nice!
    For me, its pretty noticeable - the grip is better, rolls over stuff easier and keeps crazy momentum..also rides a little higher. I'm sold
  27. #2027
    Apr 2014
    Just barely over 31 lbs
  28. #2028
    mine finally.
    subefotos
  29. #2029
    I fix choppers
    Reputation: HELLBELLY's Avatar
    Black Death...
    I finally got this beast built over the weekend. The frame, a medium Rune with 650b dropouts ominously arrived on Friday the 13th after waiting for months. The "Black Death" paint job looks great and I have only taken on a brief lap of my neighborhood trail, but...
    ...holy crap!!! This thing smokes. I have been terribly sick with a horrific cold (pneumonia, I just told people I had the plague) for the last two weeks. I only got out to ride once (I generally ride 3-5 days a week) in the last two weeks and this was for the Pisgah Enduro. I did this on a borrowed bike and combined with my affliction it nearly killed me. Nonetheless, without even trying I increased my average speed by nearly 2 mph. I was concerned that in the slack setting it would be a handful punching up the climbs, but it was not a problem in the least. It motored along without any problem without requiring me to do any heroic out of the saddle efforts.
    On the downhills, well duh...it kills. The Rune is incredibly balanced and stable. I was never thrown off line and it has traction to spare. The biggest thing I took it off of was only a few feet, but it was again incredibly composed. I have a few future additions including either DB Air Inline or DB Air CS (I won one, actually!) and I may jump into some I-9 wheels eventually as they are the wheels du jour here in the South. As built it is just shy of 32 lbs. I am looking to many fun rides ahead and glad to be part of the gang.
    Banshee Rune V2 Build Thread-36c40483-bd7a-4885-b56b-9ff052f41096_zpspted0ck5.jpg
    "Everything popular is wrong." -Oscar Wilde
  30. #2030
    ^^ two very nice builds!
  31. #2031
    krj
    krj is offline
    Aug 2005
    Wow nice new entries !
    Welcome in the crew.
    Look forward to hear about your dbinline optional up grade.
  32. #2032
    I fix choppers
    I will have it on shortly. I will share a couple of things though. I was able to build this bike very quickly. It went together with no fuss at all and the frame is rock solid. This has not always been the case as my pal and I have been building bikes in his garage for the last 15 years. He had the same experience with his Banshee and it's nice to see great attention to detail from a small company.
    I have my old DB Air on the bike now and just set it at the base tune. So far so good. The Inline will be even more dialed and weighs about 1/4-1/3 of a lb less. I will report back after riding in Pisgah this weekend
  33. #2033
    I fix choppers
    First mountain ride...
    ...this weekend. I ended up going to ride in Elijay, GA instead of NC. The group included two of my friends, both on Banshee Primes and several other guys. The funniest quote came from my one pal who said: "It's sad how well these bikes climb...". That sums it up quite well. You have no excuses because the Rune and it's Prime brethren climb like no bikes that have the head angle of a DH rig should. My drive train is a 10 speed with a 30t Wolf Tooth front chain ring driving a 10-42t (OneUp). I had no trouble whatsoever and in fact it climbed fast compared to any of my previous rigs. I did not spin out on anything despite the trail being wet and littered with roots, rocks and stream crossings. The pedaling and traction are phenomenal.
    Upon heading back down I rode this bike faster than anything I have ridden before. This was unnerving at times as I could take corners and sloppy sections way faster than I am used to. I am coming off of riding Santa Cruz bikes for years (since '99) having owned two Hecklers, a Bullit, a Nomad and a Butcher. While none of them were slouches, none of them pedaled or handled like the Rune. It blasts thru rock gardens like they are nothing and is amazing in flight. I have now four rides on it so far and my average ride speeds are up 1.5-2mph faster on any of the loops/rides that I normally do. I can't wait to get into even more big rides. Really any rides.
    Last, but not least it is a head-turner. Tons of people ask me what it is and question me about it as you cannot see the graphics with its Black Death color way. Dark and evil. It is the little devil on my shoulder yelling in my ear: "Go faster; Do it now; Obey me, you schmuck!!!" Two wheels; One dark lord indeed. Perfect.
  34. #2034
    Nov 2013
    my nasty Rune
    Banshee Rune V2 Build Thread-photo.jpgevery time i ride my rune i love it even more soo smooth
  35. #2035
    I fix choppers
    Quote Originally Posted by MAFIA View Post
ID:	903094every time i ride my rune i love it even more soo smooth
    That's nearly a dead ringer for mine, but I went with some orange accoutrements and Race Face cranks. Oh, and my two-tone Geax pimp shoe tires. BTW, Geax should have named them "Pimp Shoes" instead of "Gomas". They'd sell a ton on name alone. .
  36. #2036
    Mar 2013
    There is my updated RuneV.2 actual weight is 13,7 kg
    I have changed Lyrik by Mattoc and present performance with CCDB CS is awesome
  37. #2037
    May 2014
    my blue rune v2 2013
    Banshee Rune V2 Build Thread-img_20140624_210624107-640x360-.jpgBanshee Rune V2 Build Thread-img_20140625_080312317-640x360-.jpg
    last upgrades
    sram x0 carbon cranks
    hope e4 brakes
    schwalbe magic mary wheels front and rear
    Attached Thumbnails Attached Thumbnails Banshee Rune V2 Build Thread-img_20140624_210659436-640x360-.jpg
  38. #2038
    Reputation: ChvleSS956c's Avatar
    Updated photos and build
    Large 2014 Banshee Rune V2
    Cane Creek DBAir CS
    Fox 36 Float 160 RC2 with Avalanche Cartridge
    Straightline 35mm stem
    Raceface SixC carbon handlebar cut to 77cm
    Ergon GE1 grips
    Avid XO Trail brakes with Goodrich stainless lines
    Shimano RT86 rotors 8" and 7" f/r
    Easton Havoc UST wheels 142r w/ xd driver
    Raceface SixC 175 cranks
    Chris king headset and bottom bracket
    Deity Skyscraper 2 pedals
    Wolftooth components 32 chainring
    MRP AMG guide
    XX1 cassette and chain
    XO1 derailleur and shifter
    Schwalbe Muddy Mary Super gravity front tire 2.35
    Maxxis High Roller 2.3 3C/Exo/tr rear tire
    Tubeless
    Currently in neutral setting
    Attached Thumbnails Attached Thumbnails Banshee Rune V2 Build Thread-imageuploadedbytapatalkhd1404020895.489540.jpg
  39. #2039
    Finally, it is done!
    ...although a crankset update should be coming soon...
    ...and the change to 650b wheel size.
  40. #2040
    Nov 2013
    how many of you have put bottomless token and how many on your pike fork?
  41. #2041
    I fix choppers
    I have one in mine. It does improve bottom-out resistance. I put mine in before I ever rode the fork so I may sample it without at some point. However, I am enjoying riding the bike so much (six rides so far) that it has not been an issue.
  42. #2042
    May 2012
    Should I go 27.5 with it??
    Congrats on the Rune. Just picked one up myself last month (upgrade from my 2006 Giant AC-1)
    Anyways, don't bin your 26er fork just yet. As it happens, my back-up bike (Giant) has an '09 Fox Talas 150mm with skinny 32mm stanchions. But ya know what?
    It takes my 27.5 front wheel, no problem.
    Plenty of clearance (but make no promises if you like your tires fatter than 2.35... guess it depends).
    It should hold you over until the $ comes in for a Pike 27.5 (My choice) or other "real" fork.
    Check it out.
    ---Looking to put the CC DBair CS shock on it.
    As well you should! F what Fox is selling for the thing.
    --- Should I go 27.5 with it?? is it worth the cost to change? or save the money and stick with 26"
    Totally depends on your budget. I'd not sell my soul to keep on my 27.5 wheels but I sure do like 'em. It was a priority for me but I had that luxury (rode a 27.5 Carbine for 3-4 months and I LIKED it).
    --- But I could also get a lighter fork as well.. Xfusion sweep or a Pike.. ----but are those too light??
    TOO LIGHT? The hell you say!
    ---a lot of my riding with this bike will be local trails, one imparticular -----(beacon hill) where I ride up a 1.5 mile climb and then descend on --------what is basically a few small DH courses,
    Man, cool beans. That's serious fun stuff there. If ya got a pair
  43. #2043
    Mar 2014
    You guys make me think about my next upgrades.
    I was set on getting a new wheel set (26er). Keeping my RC2DH Lyrik and upgrading to X01.
    Now I'm thinking about changing to 650B aswell. New Fork would be a Mattoc or Pike. I'm torn. Can't decide. What do you guys think? No Money for X01 + Fork + Wheelset :P
  44. #2044
    I fix choppers
    Quote Originally Posted by Andreas.blub View Post
    27.5 works awesome on the Rune. You can find plenty of deals on wheelsets to get you rolling (pun-intended). I scored a set of WTB i23/SRAM Santa Cruz built that were a take-off from a Bronson for $220 on eBay.
    The Pike is tough to beat. Simple and bombproof; it works great right out of the box. Again, look for deals.
    Finally, XO1 is swell and all, but for around $200 you can convert an existing 10 speed with hop-ups from Wolf Tooth, OneUp, etc. or wait until August for the 1X stuff that you can get into for $600. I have the former and it works great.
  45. #2045
    Nov 2013
    one thing for sure i am not going back to 2x10 i like too much my X01
  46. #2046
    Mar 2014
    Hard choice.
    I would like to have a wheelset build to my preferences. It would cost me ~600€.
    Hmm lets talk about weight savings. I guess going for X01 saves more than converting a Lyrik to a Pike/Mattoc. (I'm running 2x10 X9 atm)
  47. #2047
    Nov 2013
    naaa actually i dont care to much about weight saving in the rune is just if i and riding a hard trail fast is more easy for me if i am on a XO1 but this is personal preference lol i have previously a 2x10 X0 on my rune and now put the X01 and i dont know for feel more nice so i put the 2x10 and XC rig and i dont even know why i have better climbing strava time on my banshee with X01 than my XC 21 pound bike with 2x10 setup is just crazy loool
  48. #2048
    Mr. Knowitall
    Reputation: hssp's Avatar
    I woukd go for the Pike, as the performance is awesome and regular lubrication service is easy. We also do not know how the Mattoc work in the long run
  49. #2049
    Reputation: Znarf's Avatar
    I´d keep the Lyrik and get a X01/selfmade 11spd and keep the 26" wheels.
    The 1x11 really is nice and simple. If your Lyrik is in good condition, keep it.
    Also maybe Rock Shox will come out with a Drop In Charger Upgrade for the Lyrik, like they did for the Boxxer?
  50. #2050
    Out for a spin today, first ride, kind of a "shake down" really.
    The suspension performance is awesome.
    Really is superior to the FSR of my previous '10 Enduro.
    I'm able to run much lower pressure on the same shock (Monarch+): better small bump sensibility and still able to resist bottom out.
    The Pike is very good, but still is not superior to the Lyrik RC2DH that I had on the Enduro.
    I'm using a 1x10 set up, with 42 Oneup cog (with accessory 16t sprocket) and a Hope Wide Narrow 32 chainring. Really enjoying the set up. The 16t is not as smoth as the standard SRAM sprockets, but manageable... but the range is wide enough for the riding I do, including some technical and hard climbs. Maybe a faster top gear would be nice...
    Bottom line: awesome frame, good fork, good transmission.
    For those trying to decide between upgrading fork or transmission:
    If you already have a good fork (like the Lyrik), I definitely would go for transmission upgrade. I find it is much more noticeable the transmission upgrade thant the fork upgrade.
    That said, I'm still on 26 wheels (although the Pike is a 27,5) but as soon as my budget allows it, I'll make the change to 27,5.
    After all, that was the main reason for me to change from the Enduro to the Rune.
    Cheers
  51. #2051
    pit
    pit is offline
    Hi there,
    I'll receive my orange, L rune in a week, can't wait to see it !!!
    Does anyone have put a Xfusion metric HLR in the 160 mm travel mode in the front ?
    What do you think about the Metric/Rune V2 combo ? I live in France, and there aren't a lot of Metric here so i wonder which fork could i put in the front of my future Banshee (heheheeee, future proud owner ;-) ?
    I weigh 93 kgs without clothes and i live just near the Alps, in Nice......
    Thanks !
    Steve, from France
  52. #2052
    Jun 2014
    Quote Originally Posted by uzurpator View Post
    Nice. Coil shock really makes this bike come alive.
  53. #2053
    Feb 2006
    Hey Keith,
    what is it with the different Tune Charts on the CaneCreek and on the Banshee website?
    Both for 2014 Rune... both for the CCDB Air CS XV, but verry different...
    Edit: The tune chart on the CaneCreek page is without XV can. But can this make such a difference?
  54. #2054
    Hi Steve.
    Congrats on the new bike, hope you'll enjoy it (at least) as much as I'm enjoying mine .
    Plus, since you live near the Alps, I'm sure you have some sweet trails, worthy of the rune.
    Regarding the fork, can't tell you about the metric, I haven't even seen one yet, but I can tell you the pike is a very sweet (smooth) match.
    Cheers.
  55. #2055
    Nov 2013
    yes have been change on the cane creek page but also picture of the ccdair cs have been chage for a coil
  56. #2056
    I've contacted cane creek, this will be sorted shortly. Please use the base tunes found on the Banshee website as a starting point.
    Thanks for bringing this to my attention!
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
  57. #2057
    do you know what was the color options?
    what was the color options for the 2015 rune frames?
    Quote Originally Posted by pit View Post
    Hi there,
    Thanks !
    Steve, from France
  58. #2058
    Guys,
    I'm 6'5 with a 39" inseam and i got my eyes set on the rune. Got ahold of a guy here in Sweden that rides a L spitty with a 60mm stem, who is the same lenght as me but has a 36.5" inseam.
    So without actually riding one and just going by the geo chart i should be able to fit on a XL rune. Are there any guys here who are my length and have ridden or ownes a rune and can tell me if this is doable? Also, if you have any ride pics or pics with you on the bike (riding or just sitting on it) that would be absolutley perfect!
    Also: to the banshee guys, ever thought of doing a XXL size or at least making the headtube longer on the XL size??
  59. #2059
    Jun 2014
    I know a guy who is 6'7 who rode an XL rune with I think an 80mm or 90mm stem? He also noticed the short headtube on the bike. Ran a ton of spacers under the stem to get the height appropriate.
    I'm 6'0 an have a long back and rode an XL with a 50mm stem. It worked well, but I would not have been able to go with ANY more stem length on that frame.
  60. #2060
    At 5.8 i felt cramped on the medium rune, and good on the large (50mm stems)
    I think at 6.5" you will struggle on the XL
  61. #2061
    Sep 2012
    I'm 6'4" and ride a large Rune with a 70mm stem. I could ride a XL with a shorter stem and be happy but my large fits me ok.
  62. #2062
    Aggressive bike like a rune... With a long stem makes baby Jesus cry
  63. #2063
    Feb 2006
    I´m 6.1 (186cm) and ride a large Rune V2 with 40mm stem. Sometimes I think that I should have chosen an XL.
    With 6.5 I see no chance to fit on a large one!
    The headtube is indeed a bit short for tall guys. I use a 38mm bar, a headset with tall cover and a lot of spacers underneath the stem (wich has 6° angle). Dosen´t look good, but works fine...
  64. #2064
    Mantra: you must have misunderstood me, I'm looking to build a XL rune not a L.
    Plan B is to see if the LBS can get ahold of a turner burner in XXL or similar behemoth-sized frames..
  65. #2065
    Feb 2006
    Quote Originally Posted by Edlund View Post
    Not really, but I was worried about you mentioning this guy for Sweden who rides a L Spitfire at 6.5.
    When people mentioning things like that, they often tinker about doing similar things in the back of their heads...
    So it was a pure precaution
    Btw.: Forget Plan B! The Rune rocks!!!
  66. #2066
    Thanks for the precautionary warning mantra
    Ya, I really *really* want it to work. Banshees geometry is in between turners XL and XXL for most parts so i think/hope/want it to work and hopefully i wont have to have a stem, or a saddle post, that's the size of a submarine periscope on a XL frame..
  67. #2067
    Get an XL spitfire, its longer
  68. #2068
    Reputation: darkslide18's Avatar
    Converted to 650B
    Converted my Rune to 650B over the weekend. Took it out for the first ride yesterday. Previously I was running a Coil Lyrik RC2DH and the Fox CTD that came stock with the Frame. Went with a 2014 RS Pike 160 Solo Air RCT3 and a CC DB Air with the XV can. Threw on a set of 650 drops and laced up a set of WTB Frequency Team I25's to my set of Hope Pro 2's. Finished it off with a pair of Specialized Butcher Control 2.3's.
    Thoughts? I dropped a pound by going with the Pike over the Lyrik. The bike now weighs 30lbs even. That being said I am very impressed with the fork right out of the gate. The fork is very plush right out of the box, it rides high in the travel and feels very controlled. I didn't notice any difference in stiffness compared to the Lyrik and that is including the 15mm Thru axle. Plus it looks great as well.
    As for the DB air? AWESOME! I hated the CTD shock and the DB Air is a revelation. What a shock. The rear feels far more planted and controlled. The CTD blew through its travel as the DB air does not. Plenty of mid stroke support with a nice ramp up at the end. Basically the bike feels lively in the rear compared to the mushy flat tire feeling it had before. Great upgrade. I went with the base settings off of the the Banshee site and then tweaked them to reflect the settings used in the Pinkbike DB air review (which was tested on a Rune). I may or may not tweak them a little more but as it stands the set up I have at the moment rocks and don't really see the need to change it.
    And now the 650B. Honestly It is not a huge difference. I do not notice any difference in the way the bike handles (which is a good thing). It does ride a little taller but that feeling disappeared on the trail. Feels plenty playful and handles almost like the 26. What I do notice is that I was able to carry momentum a little better and that the cornering felt a little faster. Felt like it rolled over chunk a little better as well. A worthy upgrade? Put it this way: If you are going for a new fork and wheel set? Why not?
    I am very stoked with my Rune in its new clothing.
  69. #2069
    I fix choppers
    Quote Originally Posted by darkslide18 View Post
    My Rune is set up almost the same as yours. IMHO, that extra speed, roll-over ability and momentum retention is worth it. I cannot think of anytime that I had wished I was on 26" wheels since building it.
  70. #2070
    Oct 2013
    No bike will ever be so good that it compensates a poor fit. Get something thats fits your tall ass!
  71. #2071
    pit
    pit is offline
    Don't know what will be the colour option for 2015, mine came in......Orange !!!
    Very nice i think
  72. #2072
    pit
    pit is offline
    My orange Rune
  73. #2073
    pit
    pit is offline
    Banshee Rune V2 Build Thread-img_2616-compress-e.jpgBanshee Rune V2 Build Thread-img_2614-compress-e.jpgBanshee Rune V2 Build Thread-img_2615-compress-e.jpg
  74. #2074
    I fix choppers
    I almost went with Orange, but went all black, jack. Looks sweet, but you'll put it in the low setting almost immediately.
  75. #2075
    Nov 2013
    i wish the darkside have orange and black i dont like the blue with orange very sweet rube i also went to black black with the rune
  76. #2076
    pit
    pit is offline
    Quote Originally Posted by HELLBELLY View Post
    That's what i'll probably do once i'll ride it in the Alps
    @ tugamik : Pike seem to be a little bit flexy for my weight, first i should try one to see.....The new Fox 36 or the Bos deville in 27.5" might be a good choice for this frame
  77. #2077
    Mar 2014
    sad thing you can nearly buy 2 Pikes for one Fox 36.
    Id really like to have one but i guess ill go with the Mattoc or Pike.
  78. #2078
    pit
    pit is offline
    I know it..... Mattoc seems to be a good fork too indeed.....
  79. #2079
    Mar 2014
    Ill be waiting till christmas to have some long term reviews of both. Will be interesting to see if ppl are still as hyped as they are right now.
  80. #2080
    Fox CTD
    Quote Originally Posted by BobRocket View Post
    Donkey Balls nails it (trail/descend). In climb it is pretty good.
    Attachment 891127
    Hi BobRocket,
    I was just reading your post re your ctd shock.
    I felt exactly the same way on my new spitfire, the Trail mode was pathetic, descend no support and climb mode was ok.
    I added a small volume spacer and it transformed shock. I ran about the same sag (was actually about 10psi less) the shock then accelerated and skipped over the rough whilst still having good small bump compliance.
    The climb mode was still good even for bombing down, but the trail setting completely useless/pointless.
    I still have my old isx6 from my v1 rune. I have not been able to get that to perform quite as good as the fox ctd to be honest. I have to run too much sag to get it to feel right(to improve small bump compliance), and the downside of this is it doesnt climb as well.
    There is another problem with the ctd i have found it does not handle a prolonged rugged descent. The damping goes out the window, the rebound ends up like a pogo stick till it cools down again.
    I would love to try a CCDB or the Xfusion HLR Air tuned for the spitfire
    Thats my 2cents i guess what im saying is get the volume reducers and give it a go.
  81. #2081
    Mar 2013
    Do anybody using 27.5" Maxxis Ardent 2.25 tire with 26" Rune dropouts? Is it fit or not?
  82. #2082
    Hi.
    just my 2 cents...
    @pit: I'm a pretty heavy guy (90kg+gear) and ride aggressively (sometimes). Don't feel that the Pike is flexy. Previously had a Lyrik and stifness is pretty close. That said, never tried an Fox 36 nor a Bos to really be able to compare.
    @tokrot: ever considered a Monarch plus? That is what I have on my Rune. Only can say good things about it. Good small bump compliance, good support, consistent damping on large descents. And you can find a Monarch for half the price of a CCDB.
    I'm running 185psi on a Mid-comp Mid-rebound tune. But I've read some threads that suggested that lighter riders would benefit from a Light-comp tune.
    Cheers.
  83. #2083
    Dec 2013
    Quote Originally Posted by alexey_shmat View Post
    Depends what position you have the dropouts. I can just squeeze a maxis ardent race 2.2 into the neutral position.
    If i go slack I can fit a 2.3 HRII or 2.3 Minion.
    So to have enough clearance you will probably have to be in the slackest setting.
  84. #2084
    Mar 2012
    Hi, is it possible to remove the decals from the green Rune V2 or are they under the clear coat?
  85. #2085
    pit
    pit is offline
    Quote Originally Posted by tugamik View Post
    Hi.
    just my 2 cents...
    Cheers.
    Ok, Thanks for the info
    I'll try one to see...for sure it´s cheaper than Fox or Bos.
  86. #2086
    Nov 2013
    why do you want to remove the decals? maybe you can use a sand paper or get the frame to a local auto paint shop and paint the bike like you want
  87. #2087
    Apr 2014
    not to throw another into the mix, but i just picked up a Marzocchi 350 CR...it is monstrously stiff compared to the XFusion Sweep that it is replacing. pretty stunning fork and i'm looking forward to some real ride time.
    2014 Banshee Spitfire 650b
    2011-ish Chromag Samurai
  88. #2088
    Nov 2013
    Banshee Rune V2 Build Thread-image.jpg for what is this that came with my dropouts
  89. #2089
    They are spacers for the is brake mounts, some of the dropouts (142 only I think) had the brake mounts done incorrectly and for some brakes u need the spacers installed to properly center the calipers, I believe they fixed this on newr dropouts
  90. #2090
    Nov 2013
    ok cause i have 142 but i dont used with my formula r0 brakes
  91. #2091
    pit
    pit is offline
    Quote Originally Posted by babyz View Post
    Let me know what you really think about that fork please.
    I liked my Z150 a lot in the past.....the return of Marzocchi in the enduro arena in 27'5 ? Moreover the price is interesting...I don't know what will be the difference with the NCR
  92. #2092
    Second that, some thoughts about the fork would be much appreciated.
    And maybe some pics
  93. #2093
    Apr 2014
    Quote Originally Posted by livanh View Post
    And maybe some pics
    Here's a pic of the bike with the new fork, no close ups of the fork on my phone but I can snag some later.
    Yesterday was my first ride on the fork and it has a bit of stickiness in the first bit of the travel, but I am assuming it will improve over time. Smoothness was already much better than my 4 month old XFusion Sweep.
    I don't have the air pressure quite right yet but it is close, and the fork rides very high in its travel. I'm running LSC in the middle of the spectrum, rebound nearly in the middle as well with a slight bias toward faster, and the fork absolutely blew me away when the going got rough. The massive arch gives the fork unreal torsional rigidity, and there was no sense of deflection even in chunky off camber corners.
    Responding to an earlier question, I decided not to wait for the NCR because a) this fork's damping system sounds extremely similar less the ability to tweak HSR via shim stack adjustments and the lock out switch, and b) I scored it for less than $600 on Jenson.
    I also just sold my CCDB Air CS in favor of the Avalanche-tuned Fox CTD shown in the picture. Not only is the Avalanche shock feeling far better than the CCDB on this bike, but I also came away with some money when the swap was all said and done. My only concern is that the CTD will heat up on some longer, rougher downhills, but I blasted it pretty hard yesterday down a 5 minute downhill trail without any issue.
    Part of this could be an overly strong initial reaction, but this may be the best suspension setup that I have had yet on a bike.
  94. #2094
    Nov 2013
    good to hear about you like your setup want to ask how much the avalanche fox cost you and what is that saddle? i guess is q trail master
  95. #2095
    Apr 2014
    Avy doesn't sell the shocks themselves, you'll have to buy a Float CTD and send the shock in. I managed to find a barely used CTD for $200, plus another $200 for the tune and new internals. The saddle is a Chromag Trailmaster LTD.
  96. #2096
    pit
    pit is offline
    Hehehe, i see.....
    If this fork is as stiff as you said, moreover not very expensive (compared to fox etc...), it might be a good deal.
    Thanks for your comment.
  97. #2097
    Aug 2014
    Hi guys...
    Im new here... im a future banshee owner.. actually, because of this thread, i became one of banshee fans...hehehe
    I just got 1 question that keep wandering in my mind and i cant get it out or let it pass..
    Question :Why this frame got variation on the bar near seatpost clamp? (I dont know what its called)
    P/s: excuse my poor english..
  98. #2098
    Reputation: zoorlen's Avatar
    Quote Originally Posted by yoebanshee View Post
    It changes with the frame size: bigger frame => longer seat tube => longer seat tube brace.
  99. #2099
    Aug 2014
    Good job!
    Quote Originally Posted by zoorlen View Post
    now i get it...
    thanx a lot zoorlen
  100. #2100
    Oct 2012
    Hi!
    I need your help to figure the math.
    My banshee has like 64,5 or 64 HA headtube angle with Deville fork 170mm. Its length from axle to crown is 558mm (Im running 26" wheels").
    I need to know the exact measure of HA on medium setting so I figure out what angle cup (from Works components) I'm going to have 66.5 HA in medium setting.
    Let's say if my frame is 64.5HA then I would order 2.0 degree angle cups.
    thanks in advance
Members who have read this thread: 139
