Page 12 of 33 FirstFirst ... 2891011121314151622 ... LastLast
Results 1,101 to 1,200 of 3219
  1. #1101
    Reputation: darkslide18's Avatar
    Out for a great late spring ride. I really like this bike. Rock Drop. Sandy Ridge, OR.
  2. #1102
    One question to remind guys
    The 28% sag in the rune... what is exactly in mm???
    May 2012
    Quote Originally Posted by AdrianoMTB View Post
    Born on the Shore - The Banshee Bikes Blog: KS link bike sag charts
  4. #1104
    great info!
    Thanks mate
  5. #1105
    Mar 2013
    Hi everybody.
    here's my new ride!
    ...and I've been testing it in our muddy French Alps
    It's just amazing!
    build details:
    Stem : Thompson Elite 4x 50mm
    Grips: OURY lock-on
    Handlebar : 19mm Renthal fatbar (cut to 760mm)
    Rear wheel: Hope Pro 2 EVO + ZTR Flow EX
    Front wheel: Nukeproof generator + Mavic XM819
    Rear tire: Schwalbe Nobby Nic 2,25 trailstar
    Front tire: Maxxis High Roller 2 EXO
    Saddle: Italia SLR Ti
    Fork : Custom Rockshox Lyrik 170mm with CrConception cartridge
    Dropper post: KS Lev 150mm
    Headset : Hope
    XT groupset (2x10)
    Weight 15.150kg
  6. #1106
    Mar 2013
    Here is my new one Rune V.2 medium, first ride
    Amazing bike! Weight 14.05 kg
  7. #1107
    Mar 2013
    Hi Keith/builttoride, I have a question for you:
    For the Rune frames with CCDB air shocks order through your distributors (in my case the French one): the air can that is provided is the regular one.
    Cane Creek (and Banshee) are advising that the XV can will work best on this frame. The XV can should be available in a few weeks as per CC information.
    Will Banshee and/or CC provide the XV air can for their customers? Is there anything planned?
  8. #1108
    The difference in performance is very minimal, some customer may slightly prefer the chacarteristics of an XV can with spacer, while some will preffer the more progressive feel of the regular can. Personally I prefer the regular can, but Jon who did testing with CC very slightly prefered the XV can with spacer when he did testing.
    There is no real need to go to the XV unless you are finding the regular can too progressive (not able to use last couple of mm of shock travel on big hits, like flat landings or casing jumps).
    If you decide that you need the XV can, then please contact cane creek directly and explain your situation and they may be willing to help you out when they become avaliable.
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
  9. #1109
    Mar 2013
    Thank you for your fast reply.
    As per my last couple of runs: I can't use the last cm of the shock, then I may contact CC to be able to check if the problem is solved with the XV can.
    One last thing: I noticed a little pedal bob using the base setting from Cane Creek. I'm currently riding with CC's base setting (I only added +2 clics in of LSC). I've seen that some other riders on the Spitfire thread are trying to eliminate this pedal bob tweaking the rebound.
    What do you think about that?
    What were/are your settings?
    Thanks in advance
  10. #1110
    Nov 2012
    Mines pretty much finished now aswell. I am looking for any recommendations on a chainguide to suit the 2x10 (26/39) drive train though.
    Anyone running one that they can recommend? I have been looking at the MRP 2X
  11. #1111
    Reputation: ryan_daugherty's Avatar
    Taking mine out for its first ride today and i'm racing it tomorrow. Pics will be posted this afternoon when i get out of my cubicle.
  12. #1112
    31.375lbs
    Fox 36 Talas
    CCDBa
    XX1
    Xo Trail
    I9
    KS lev
    HT Pedals
    Nobby Nic
    Chromag Ranger and Moon DT ti
    SDG ODI grips
    SIXC Bars
  13. #1113
    Sweet ride, but I don't think the Nobby Nics will last long. Been riding them a season and had nothing but trouble - lots of flat tires!
    What is your experience so far?
    I'm riding Flat Alberts on my Rune, both front and rear.
  14. #1114
    Reputation: juanbeegas's Avatar
    Oct 2007
    These new builds are killing me... I put a deposit on a new frame in March and while my dealer was honest that I probably wouldn't see it until June, it doesn't make me not want my bike NOW, any less.
  15. #1115
    Quote Originally Posted by ryan_daugherty View Post
    31.375lbs
    Fox 36 Talas
    CCDBa
    XX1
    Xo Trail
    I9
    KS lev
    HT Pedals
    Nobby Nic
    SDG ODI grips
    SIXC Bars
    wow wow.. amazing build !
    how tall are you mate?? (in cm please) itīs a Large size isnīt??
    Quote Originally Posted by MindPatterns View Post
    With schwalbe Iīve very clear in my choice
    Hans dampf Super gravity 2.35 pace star in the rear.
    Muddy mary 2,35 sneaksin trailstar in the front
    Nobby nic itīs quite weak for an intended use for the Rune...
  16. #1116
    Yup its a large, I'm 182.88cm fits amazingly. Had my first ride on it yesterday, which was actually a race run. The bike is quick. Really enjoy riding it. Fork and shock are nearly dialed in. The shock settings banshee/cane creek give for the dbair are pretty good. I like a bit more low speed compression since i have some longer ups but otherwise i kept it at their settings. Didn't use all my travel in the fork or shock so I may pull a bit of air out.
    XX1 is awesome, i heard nothing but tires and hub buzz.
    I live in the PNW so nobby nics are fine, They killed it yesterday. If i was going to ride something rockier than I'd snag some Hans Damfs.
    I'll get some better detailed pics of the bike later just need to clean up the hoses and stuff later. Got its first battle wound though yesterday after hitting my hand on a tree.
  17. #1117
    Nice! what about the XO trail brakes? Iīve heard lot of good info about it but Iīm hesitating about switch my XT brakes for these ones!
    pd: 1,88cm and 88cm inseam???
  18. #1118
    81.28 inseam. I have a long torso. Factory bleed on XO trail brakes still but the felt awesome. Rebleeding today. I'd say stick with XTs though. Theyre equally rad. I just prefer SRAM.
  19. #1119
    Hard funkinī Kraut
    Reputation: NoStyle's Avatar
    May 2005
    Quote Originally Posted by juanbeegas View Post
    Me too. Very nice Build Ryan!
    juanbeegas, what is coming as your next Frame, and why?
  20. #1120
    Banshee Rune V2 Build Thread-photo-3.jpgFor those that are interested my full Rune bike check is here on vital
    Ryan's Banshee Rune v2 26 hoops - ryan_daugherty's Bike Check - Vital MTB
  21. #1121
    Oct 2007
    Quote Originally Posted by NoStyle View Post
    Got me a medium frame in raw with the DBAir shock. My dealer said something about that being the length it'll take for the factory to run out the next batch of frames, here in SE Asia?
  22. #1122
    Hard funkinī Kraut
    May 2005
    Ah ok. Something wrong with your current Frame?
  23. #1123
    Oct 2007
    Heh... No, nothing wrong at all! With the current update to the frame's geometry, I don't really need my other bikes. I've sold them and replacing them all with the new Rune.
    Maybe a little down the road, I might buy the updated Rampant too. For days at the skatepark.
  24. #1124
    Hard funkinī Kraut
    May 2005
    Haha, Iīm a One-Bike-for-All-Guy, too.
    As far as I know the next Batch (expect to arrive in August) are the 2014-Modells. Have you heard of an updated Geometry, for these? Or is it the Fact that the Rune is good enough to handle everything?
  25. #1125
    Oct 2007
    Nah, I'm talking about the current Rune V2. I'm really light(130lbs), so with the frame in its lowest and slackest setting, the bike is more than enough to handle DH days for me. And with it raised and steepened, it'll be good for the long days in the saddle. I change my cassette, wheelset and chain for the different days.
  26. #1126
    Hard funkinī Kraut
    May 2005
    Ah well, i get you!
    Hmm ... have initially planned to go with meaty 26er Wheelset for the DH/Park-Days and lightish 650B Wheelset for the All-Day-Rides. So far I feel so much comfortable on the 650Bs that I donīt change much. Oh, Iīm riding a Spitfire by the way, but can clearly see your Reasons to reduce your Stable of Bikes. The Spitfire offers so much mind-blowing Potential, the Rune must be a blast
  27. #1127
    MTB B'dos
    Reputation: LyNx's Avatar
    Thought you guys with the DB Airs might be interested in this The Lounge | Rider Forums | Malcolm Monday
    and maybe this The Lounge | Cane Creek Chatter | The Lounge Live: Banshee Bikes
  28. #1128
    Mar 2013
    no stress man, i waiting from october 2012 and i still don't have date of delivery
  29. #1129
    Reputation: Stabone33's Avatar
    Aug 2005
    Quote Originally Posted by sfofan View Post
    Damn...where did you order from?
    Ordered mine in March, got it a couple weeks ago from rbikes.com -- great service. Even if you're in Europe or points East, I think I'd rather pay the international shipping cost (or use a re-shipper) than wait six-plus months for delivery....
  30. #1130
    Quote Originally Posted by PSimpson7 View Post
    This is the first Rune I see with 180mm on the front. How does this feel? Are 180mm on the front to much for the Rune? I run the Rune with a 160 mm Van and I like it. I just think about to buy a second fork with 180mm.
    Hey. I have an MRP G2 on mine and can't get it to rotate far enough counterclockwise to allow the chain to clear the dropped chainstay on this frame. I ended up removing the jockey wheel and running my bionicon guide too. I have heard E13 is a better choice for the V2 as it can rotate further. That's what I'll be getting.
  32. #1132
    Reputation: JansonJanson's Avatar
    Oct 2012
    hey folks,
    here is a nearly final version of my rune v2
    Parts as followed:
    Frame black anodized Size XL 3153,6
    Banshee Rearend 249,82
    Banshee Steckachse 41,46
    CCDBAir 550,25
    Crossmax HR inkl. 12x142mm Adap. 1011,6
    Crossmax VR 838,99
    Schwalbe Hans Dampf 2,35 TSC 751,27
    Schwalbe NobbyNic 2,25 PSC 602,13
    XTR Race Set 450,93
    Bremsadapter Hope IS-PM 183 41,85
    Bremsadapter Hope PM-PM 203 33,34
    12x Bremsscheibeschraube 25,34
    Hope 203mm 167,94
    Hope 183mm 148,33
    26prerunner Ti 331,12
    CaneCreek Headset High TopCap 95,93
    RS Lyrik RC2DH Air 2139,56
    Carbon Gabelschaft Spacer 15,93
    SRAM PG 1091 238,9
    SRAM XX 11-36 214,61
    Hope 32t 33,9
    Zee SW 11-36 270,19
    XTR Trigger + Schaltzug 123,49
    Syntace Megaforce 2 105,56
    Enve DH Bar 238,1
    ESI Grips 60,79
    KS LEV 150mm 30,9mm 608,5
    Selle Italia SLR XP 180
    Tune Würger 10,37
    MRP 1.X 59,63
    XTR Innenlager 88,67
    XTR Kurbelsatz / Cranks 180mm 565
    Fett, Öl, etc. 100
    Summe: 13547,1g / 29,80lbs
    The scale says 13,61kg / 29,94lbs, even with that i can gladly life
    THX Keith and the Guys @banshee for such a great bike!
    4 days at SanRemo shutteling and Enduro ridin - best fun ever!
    2 days with the 12x150mm rear End DH, 2 days with the 12x142mm rear end
    I am wondering if i need my DH anymore , ok for the really hard stuff, i have been thrilled really well, but ok.
    The Rest of the time, just F****** awesome, jumping - playing around all the time. Lift of, at every little lip, root or stone i found.
    The Suspension worked flawless, the CCDBAir is perfekt for aggressive ridin in the big mountains!
    The slackest setting + 170mm fork pretty perfect for DH Ridin
    After this pretty hard 4 days, no screws or bolts got loose.
    greets
    Jan
    freedom is the ability to go where you want, when u want
  33. #1133
    Dec 2011
    Looks great Jan and the build/weight is sensational.
    Three quick questions, how tall are you (lots of pole showing)? did you try a L before buying an XL and body weight/pressure in the CCDBA?
    thank you.
  34. #1134
    Oct 2007
    Quote Originally Posted by JansonJanson View Post
    greets
    Jan
    Wow... That weight's not too bad. My projected build's almost 15kg, but I may be off with my weights.
  35. #1135
    Met ryan_daugherty and stunzeed on Saturday out at Sandy Ridge. Had to get a group shot. 3 V2's and a V1.
  36. #1136
    Super rad meeting you. We'll have to go ride sometime.
  37. #1137
    Ill be out there next saturday.
  38. #1138
    Cool - I"ll see if i can make it. I might have to work sat morn or evening.
  39. #1139
    Damn, I think I spent a whole day in the bikepark with a lose headset. Anything I should inspect very closely? Headtube, steerer tube? What would be a good indicator that the steerer tube (fork steerer) was stressed too much?
  40. #1140
    Nov 2012
    Quote Originally Posted by ruckse View Post
    Sorry for the delay in replying.
    To be totally honest thanks to work, I have only managed to ride 20km on it in the last 2 weeks and all of them have been on the road pretty much.
    When I get a bit more time on it (hopefully will take it out tomorrow afternoon for the first go offroad, which has a ***** of a climb) I will post up a bit more about how it feels.
    It is a lot lot slacker than my last Full Sus bike so it feels very different.
  41. #1141
    Nov 2012
    Quote Originally Posted by murrayf View Post
    Cheers. appreciate the feedback. I may just go for the Bionicon v.02 guide and cable tie it to the chain stay.
  42. #1142
    Reputation: bullit43's Avatar
    Dec 2010
    See if the star nut is giving up.
  43. #1143
    Na, that's all fine. Simply worried that I stressed the steerer tube too much and my lyrik says good bye on one of those days...
  44. #1144
    In my experience, forks nearly always creak before they give up. (this from having snapped 5 pairs of forks)
    If headset was loose, the most likely things to happen on damage front are ovalised head tube (would be apparent once headset has been tightened by allowing moevment forwards and backwards), and steerer/crown interface.
    Banshee Blog
  45. #1145
    Well... already checked the head tube, and I hope one day of park riding with a loose headset is not enough to ovalize it. I was just not aware of it as I thought the Lyrik developed some play. General advice? Replace fork?
  46. #1146
    Hard funkinī Kraut
    May 2005
    The Question is: What could be damaged first with a loosen Headset? Was it only slightly loosen? Iīm not sure if something happened to a Steerer or the Headtube getting much ovalized when the Cups are still in there. I could imagine that the Bearings and the Konus-Rings get the very first Damage ...
  47. #1147
    Oct 2012
    Quote Originally Posted by Uphill=sad View Post
    thank you.
    Hei there,
    i went directly for the XL Frame, i compared the measures to my old Large Spicy and after that, the decission was made.
    i am 1.88m tall, but got an inseam nearly 95cm. really long legs, shot upper body, und long arms
    i will have a look at the pressure - next time
    greets
    Jan
  48. #1148
    Feb 2013
    Quote Originally Posted by builttoride View Post
    Oh wow. Anyway, I rallied my rune/float 36 a couple weekends ago with the headset a little loose and after getting it tightened up it seems no worse for the wear... I hope. I was a noob and built it with like 1mm less spacer than I needed once everything settled in.
  49. #1149
    Good Guy Keith.
    Doing the testing himself instead of letting the user suffer
  50. #1150
    Quote Originally Posted by ironxcross View Post
    I have to admit that the headset is the one part at the bike which always seems like kind of an end boss for me. I find myself constantly checking it to make sure it's not to loose. When I'm sure it's not too loose I'm worried it's too tight and that the bearings are wearing down too fast... oh well...
  51. #1151
    Haha unfortunately the 5 forks were all before my days at Banshee when I rode much harder... plus at east 2 of them were from bad cases (nose case one, and rear case another) so my fault. I also snapped 12 frames before my banshee days. Not snapped any since!
    Banshee Blog
  52. #1152
    Oct 2011
    Hi everybody I plan on ordering a new Rune. I'm 6'3'' (190.5cm) what size should i get? I plan on using a 50mm stem and 800mm bars. I'm currently riding a bandit xl with a 24.5'' top tube and the seattube is 21'', the seat tube feels to long on my bandit and the toptube with a 50mm stem feels just right. I prefer a smaller bike.
    will the large be to small? Will the 25'' toptube be to long on the XL ? I've heard the bike feels pretty long for its size. Any info would be awesome!
  53. #1153
    I'm no expert size-wise but that definitely looks like you should get the XL.
  54. #1154
    MTB B'dos
    Personally since you kind of split the difference in the ETT between the L and XL and then say you prefer a smaller bike, I'd have to tend to say go for the L and if you need it go to a 60mm stem to make up the reach difference. Me personally at 6'2.25" with long arms and inseam prefer the fit of the XL where I use a 65mm stem and 785mm bar, but then I suffer the longer wheelbase which is more of a hassle in the tight stuff, but more stable on the fast stuff, have wondered what a L with 80-90mm stem would be like - FYI I'm on a XL Prime with 25.4" ETT.
    Quote Originally Posted by nate350sxf View Post
  55. #1155
    Dec 2011
    I'm at 188cm riding a large, also prefer a slightly smaller frame, just in the process of deciding if I prefer a 50mm or 65mm stem.
    With the low stack height / short head tube it feels longish for a 24inch top tube.
  56. #1156
    Oct 2007
    180cm and I ordered a medium. Comparing the reach between the M Rune and my SM Demo 8, the Rune came out slightly longer and I'm hoping it doesn't feel too long for me. To be fair, I like my bikes really small. I was on a M Wildcard before, but never felt as comfortable on it as I did on a friend's SM Wildcard. I guess what I'm saying is, if you want a play bike, get something smaller and if you want something for all day rides, get the bigger bike.
  57. #1157
    Reputation: highrustler's Avatar
    anyone know of a large rune available, seems they are sold out everywhere.
  58. #1158
    Nov 2012
    Hola Juan,
    From my experience I'd recommend you the L size.
    I'm 182cm and I ordered an M, when I got it, the bike was really small for me. I traded for an L size and now is perfect.
  59. #1159
    Oct 2007
    It's all good, Jalafer. I'm used to tiny bikes and I prefer them. Reach numbers say it's actually a tiny bit longer than the small Demo 8 I'm coming from.
  60. #1160
    Oct 2011
    I just placed my order for a large. I hope i made the right choice. I had a large tracer 275 for a while and that bike felt alright, so we'll see what happens. Thanks everybody for the info!
  61. #1161
    Had lots of fun with my Rune in the park. Tested the slack setting and like it a lot, only thing that annoys me is that I'm still riding without a chain guide.
  62. #1162
    Dec 2011
    what is the rise of this handlebar afterall? 15mm or 30mm?? by the way the bike looks fantastic? how d you like the tires?
  63. #1163
    Dec 2011
    sorry for the double post
    Quote Originally Posted by darkslide18 View Post
    Spent this morning building her up. This is one mean and purposeful looking rig. Cant wait to ride it. Haven't weighed it yet but I'm guessing around 32 lbs.
  64. #1164
    Reputation: mindmap3's Avatar
    May 2013
    New to this site, but I demo'd a Rune at the weeknd and decided that it was the bike for me to replace my well use and slightly battered SX Trail. Should hopefully pick it up at the weekend.
    Have gone for a large black one with a Cane Creek DB Air because I didn't like the Fox CTD shock.
    Will be built up with the parts from my SX - 36 Van RC2's, Thomon stem, Answer 780 DH bars, XT 783 brakes, Sram X9 1x10 drivetrain, RF Atlas cranks, Easton wheels and a Reverb.
  65. #1165
    Welcome to the family
  66. #1166
    Oct 2007
    Suspension still needs setting up, hoses and cables need to be lengthened and tidied up , the chain needs to be shortened and I'm not too sure about the chain guide. Talk about tight clearance on the guide, I think I might need a different guide.
    Brakes: Shimano XT M785 203F/180R
    Cassette: Shimano DuraAce 12-23t
    Chain: KMC X9SL
    Chainguide: E13 SRS+ 32t Special (I might need a regular SRS+)
    Chainring: E13 Guide Ring
    Cranks: Truvativ Descendent
    Fork: X-Fusion Vengeance HLR
    Gears: SRAM X9
    Grips: ODI X-Trainer
    Handlebar: Deity CZ38 Special
    Headset: Hope
    Pedals: HT EVO AE01
    Saddle: Charge Spoon
    Shock: Cane Creek DBAir
    Stem: Straitline SSC
    Tyres: Continental Baron BC 26X2.3 / Schwalbe Hans Dampf 26X2.35
    Wheels: Octane One 31 w Sapim Race Spokes w Hope Pro II Hubs
    Misc: Mixture of Alloy and Ti bolts throughout.
    Attached Thumbnails Attached Thumbnails Banshee Rune V2 Build Thread-photo-1-.jpg
  67. #1167
    beater
    Reputation: evasive's Avatar
    Feb 2005
    Saw a black one on the trail yesterday. It really is a mean-looking bike. It just looks fast, more so than the other bikes in its class.
  68. #1168
    Nov 2012
    I have been riding the Rune V2 with a Fox Talas 180 and it rides perfect, I have it for 6 month now and wonīt change a thing on this bike, is the perfect bike, I only lower the fork to 140 when the climb is really hard, if not I go up in 180
    Cheers
  69. #1169
    Mar 2013
  70. #1170
    Mar 2013
    Could anyone advise if Blakspire Stinger ISGS05 chainguide compatible with Banshee Rune V.2?
  71. #1171
    Hard funkinī Kraut
    May 2005
    Yes, a Stinger does fit on the V2-Bikes, but is maybe a non-optimized Solution as Chain-Device. You have to be aware that the Pulley is very low/exposed between the CS-Yoke and Chainring.
    @ juanbeegas and alattack:
    Very nice Runes! Enjoy!
  72. #1172
    Anyone knows if a e13 TRS (that's for a dual setup) will fit the Rune?
  73. #1173
    Reputation: el_guillyt's Avatar
    Mar 2013
    Re: Banshee Rune V2 Build Thread
    Yes, ir fit, but you have to trim the top fin because interferes with the low direct mount of the front drilleaur, I don't know if there is any TRS dual without that fin on top, but mine got it, but no big deal to make it to fit
  74. #1174
    Thanks for the reply. Are you using the RS or the TRS+? How much of the top fin do you have to take away? Could you post a picture of your setup? That would be great! (Specially interested in the position of the plley and the fin!)
  75. #1175
    Mar 2013
    it's the TRS+, let me take some pictures this afternoon and I will post them, so you'll have a better idea
  76. #1176
    You're the man, thanks in advance!
  77. #1177
    Mar 2013
    Agreed that it is a non-optimized. I have install it and found that Stinger would not work properly with Rune V.2, suggest same situation with Pryme and Spitfire.
  78. #1178
    Mar 2013
    There you go
    If you need more please tell me
  79. #1179
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    Chainguide woes
    FOod for thought, if you go w/ a clutch rear derailleur, ideally mid cage, there really is no need for a lower chainguide.
    Also 10-spd shimano rear derailuers work great with 9spd SRAM shifters.
    My chainguides are all coming off!
  80. #1180
    Hard funkinī Kraut
    May 2005
    Great FM - somehow my same Thought after debating which Chain-Device would work properly for Months now ...
    Iīm in Need to Upgrade my old XT 2x9 to 2x10 and will go the same Root: Shadow+ and a simple small Piece of rubber Water-hose zip-tied close to the Big Frontring. Not as a true Device, but just a little more Tension to avoid Chainrubb at the lower Yoke when in the Small-Ring.
  81. #1181
    FM
    FM is offline
    Apr 2003
    I don't think you'll even need that. For rough terrain the upper guide or front derailuer, lower taco or bash guard, and a mid cage clutch is perfect.
    Enjoy- I know I am! So nice to never hear the sound of chainslap.
  82. #1182
    here's mine, or at least what i have till nooow
    imagen jpg
  83. #1183
    @el_guillyt Thanks for the pictures... can you say how much you did take off from the fin... in mm? Hard to tell from the pictures but that looks like you had to do some work...
    Quote Originally Posted by FM View Post
    So your advice would be to skip the chainguide and simply get a shadow+ rd which would remove _all_ the hassle related to chain slap and the chain coming of from the front chain rings?
  84. #1184
    Mar 2013
    @MindPatterns you'r wellcome, hard to say how much, we didn't mesured, just put it on place and mark, worked for me and my friend.
    I'm also running shadow+ don't mind about to much in terms of chain retention, it is the quietest bike I ever rode
  85. #1185
    Hard funkinī Kraut
    May 2005
    Hey Mate - I get what you are saying.
    Well, I donīt know if this "Issue" appears on the Prime or Rune. but on the Spitfire the Chain will rubb the lower Yoke when you are in the 22er Front and 11, 13 and 15er Cassette-Gearing (Mid-Cage-Derailleur). More so when the Flip-Chips are in the slack Setting. Iīm in the neutral, so it affects only the 11 and 13er Cassette-Rings. Therefor this rubber Water-hose avoid it and is more Kind of Protection plus Device. Ok, I could taper it, but this Rubber is very strong and shows no Sign of Wear after one Month of use. Replacing it is easy, cheap and quickly done.
    Iīm running this, without any other Chain-Device, Tacco, Bash or other Stuff, successfully on my 2x9 Gearing and I will do the same with 2x10 and Clutch-Derailleur.
    Apart from that Iīm with you. Get a Clutch and rid of the lower Device - you donīt really need it, regardless of 1x10 0r 2x10.
  86. #1186
    AW: Banshee Rune V2 Build Thread
    Running rubber hoses since years on all of my bikes. Going to build up a spitfire soon. @NoStyle: can you post a pic of your setup?
  87. #1187
    Reputation: Hikers Only's Avatar
    Oct 2010
    I used to have the Straitline Silent guide on my V2, but even with that guide I would still get bad chain slap. It was very annoying, so I sold that and now have the MRP AMg chain guide a 32t ring and a Shimano Zee rear derailleur, but still got chain slap as the chain sits so close to the underside of the chain stay. So I made my own version of the C Guide and it has eliminated pretty much all of the under side chain slap
  88. #1188
    Hard funkinī Kraut
    May 2005
    Quote Originally Posted by kijan View Post
    Yes, Iīm going to post it tomorrow-mornig.
  89. #1189
    FM
    FM is offline
    Apr 2003
    Ah I hadn't considered that part- and it is a tight fit running a chainguide up against that lower yoke.
    Mainly I really dislike the current chainguide standards that wreck your chainline and require crank removal for any adjustments. So I really don't want to run a chainguide anymore.
    But after today's ride I am putting my lower chainguide back on. The bike doesn't really need it, but runs quieter with it.
  90. #1190
    Hard funkinī Kraut
    May 2005
    You can find my complete Build (apart from Chain-Device ) here, here and here.
    Mainly I really dislike the current chainguide standards that wreck your chainline and require crank removal for any adjustments. So I really don't want to run a chainguide anymore ...
    Yes, thatīs why I have filed down the ISCG-Tabs a bit - just to fit Chain-Device and Dual-Rings without "irregular" Spacing. Now the only worthy Thing to have is a small Anti-Chain-Suck-Plate and Tacco, just for the Case ...
    My Take of a simple and efficient C-Guide. Itīs not sexy looking, but works:
    Attached Thumbnails Attached Thumbnails Banshee Rune V2 Build Thread-foto.jpg
  91. #1191
    You can find my complete Build (apart from Chain-Device ).
    I was just interested in your Chaindevice, the rest I have seen already.
  92. #1192
    Hard funkinī Kraut
    May 2005
    Ahh ok. As you can see - no other Guiding except that Hose, and some Bolts in the upper two ISCG-Tabs to prevent Chainsuck. But this is going to get a better Solution as soon as I have the Possibility ...
  93. #1193
    Reputation: theraggyone's Avatar
    Jun 2013
    I dont know if its the same on the rune but I have an e thirteen trs duel guide not the trs + and it fits my spitfire v2 without any issues . I think the differance is that it doesnt have the extended shark fin only a much shorter version the low direct mount mech fits with it fine
  94. #1194
    Man, all this talk about chin guides. Glad I went 1x10. X9 crank, removed the spider, slapped on a 28T Bling Ring and I have all the climbing grunt I need. Running an 11-36 paired with an X9 clutch derailleur. Works great. Im using an MRP 1X upper guide and I am thinking of going to this Universal Cycles -- MRP Micro Chain Guide to quiet down the chain slap on the yoke.
  95. #1195
    Dec 2011
    That's exactly what I am running, with a single ring and a direct mount E13 XCX guide. Perfect setup, simple, lightweight and no chain drops. I currently not even running anything on the chain stay as there is very little noise.
  96. #1196
    Oct 2007
    I'm getting some noise and clunking on the frame, even with a guide on and a chainstay protector... What's everyone doing to quieten the bike?
  97. #1197
    What rear derailleur are you using? Some SRAM Type 2's start to clunk when the T55 gets too tight. I thought my frame was getting a clunk and it turned out its the derailleur.
  98. #1198
    Oct 2007
    Still on a short cage 9spd X9. Was thinking of getting one of them bike specific wraps and just covering the entire length of the chainstay.
  99. #1199
    it's the ride....
    Hi Keith I just got my Rune last week. I was wanting a CCDB-A but the last stock at the distributor in my country was one with Fox CTD. I decided to take it as I didn't want to wait for couple of months for next shipment thinking to get a CCDB-A separately.
    My question is do I need different mounting kit for CCDB shock ? Or can I use one installed for Fox? Thanks.
    Ulating blencong sejatine tataraning lelaku...
  100. #1200
    I still wait for my frame, but I need to replace reverb hose.
    Can someone tell me length of seatpost hose/cable (with mount under saddle) to fit large frame.
Members who have read this thread: 133
