Results 1 to 14 of 14
    Banshee Rune and Fox 40
    Is this permitted?
    A Fox 40 on a Banshee Rune.
    Running a fox 40 on a rune will void the warranty. The rune is designed to take a max fock size of 180mm travel, and only single crowns. The rune is an all mountain frame that is not designed for the extreme demands of DH riding.
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
    it has the same a2c as the 180mm fox 36. would it snap the headtube? I'm only 150lbs.
    Tripple clamp forks put a lot more shock loading through frames because they are significantly stiffer. I cannot recommend running tripple clamp forks on the Rune, as it voids warranty.
    Banshee Blog
    Mar 2011
    I like it :P totem on mine for free ride
    If you are doing the kind of riding that necessitates a Dc vs a SC, then why not look into the Scythe
    Just another redneck with a bike
    Reputation: darkslide18's Avatar
    Ill bet it rides like poo.
    surprisingly it pedals really well.
    too many parts to change with the scythe.
    gonna hit the trails next week.
    Quote Originally Posted by Hydesg View Post
    Not really, only thing really is the rear wheel and headset.
    Quote Originally Posted by Scythe View Post
    think need to change the crank and rear wheel
    Just your wheel. Your existing BB will work just need to add or rearrange your spacers.
