Results 1 to 11 of 11
Thread: 650B Rune
    Reputation: darkslide18's Avatar
    650B Rune
    Doable? Worth it? This whole 650B thing has peaked my interest.
    Paste eater
    Reputation: Jwind's Avatar
    Mar 2006
    Think it would be tight in the back. Certainly couldn't run a big tire.
    I am intrigued!
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    Based on the Prime, I would think that would be pretty cool if you can get it to work!
    One of the things I like about bigger wheels, is that you're less prone to pinch-flat or burp tubeless tires, due to the shallower angle of attack. So if you had to go from a 2.35 down to like 2.2,I don't think it would be so bad. I've not ridden a 650b so no idea how this applies compared to 29".
    BB height could be an issue. Maybe pick up a cheap 7.5x2.0" shock- that would drop your BB down nearly an inch, and give you 130mm of rear travel, by my calculations... would also slack the bike out a degree or so.
    OTOH.... price of the wheels, tires and shock could go towards a prime frame
    with the short shock, the rear triangle starts bottoming out on the seattube... so i dont think it will work (thought about offset bushes for my damper, but same problem there...)
    FM
    FM is offline
    Apr 2003
    Ah, makes sense. I suppose on a coil shock, you could limit the stroke with some rubber washers around the shock shaft. Just to mcguyver it a little further....
    yeah... but why would you ruin a great trailbike just for being "hip" with a 650b full susser?
    take a prime, or stick with 26", thats my opinion...
    The Mountain Bike Life
    Reputation: mudpuppy's Avatar
    Wonder if it would work with my XL frame...would be fun to try. I just need someone local who has one I could try.
    FM
    FM is offline
    Apr 2003
    [QUOTE=MalcolmX;9091890
    take a prime, or stick with 26", thats my opinion...[/QUOTE]
    I agree actually. 650b is maybe like tofurky?
    Quote Originally Posted by FM View Post
    I would like to try a 650B and see if that is the case.
    As far as converting my Rune to 650B I was thinking out loud. Though I do think 6" bikes with slack "AM" geo and bigger wheels does have some merit.
    Paste eater
    Mar 2006
    Quote Originally Posted by darkslide18 View Post
    I totally agree. The biggest problem with 650b is the availability of gear and options.
