Page 1 of 7 12345 ... LastLast
Results 1 to 100 of 639
    Apr 2016
    2017 Banshee bikes: News, rumours, speculation etc
    I know it's only halfway through 2016, but I'm getting excited about what's next for Banshee. I've heard for 2017 that the bikes are trimming a bit of weight through some hydroforming of the front triangle, but that's all I know. Does anyone else out there have any info or sneak peeks to get us Banshee fans frothing?
    vko
    vko is online now
    May 2013
    No info yet?
    Quote Originally Posted by vko View Post
    No info yet?
    No info will be released before Eurobike, so you'll just have to be patient
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
    Reputation: mattyice's Avatar
    Dec 2015
    I have info for you:
    2017 Banshee's will continue to kick ass and make all other bikes feel like they have the technical capabilities of a Huffy Sledgehammer.
    Please don't put a bottle cage on the Spitfire. Or any of your bikes
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Banshee Bikes
    Slaphead Legion
    Wachusett Brewery
    Hard funkin´ Kraut
    Reputation: NoStyle's Avatar
    May 2005
    As long as Banshee keeps the great KS-Link, the interchangeable dropouts and the "long-low-slack" geometry I´m fine with everything!
    Hydroforming? If it makes the frames easier to construct (f.e. rear-triangle/tubing instead of gussets), same durable but lighter that would be nice.
    Carbon? Maybe carbon-made links or dropouts could be the entry for Banshee introducing this material through their line-up, without overly raising pricing for the frames ... ?!?
    Jul 2016
    Our local NZ mountain bike mag had some info about the 2017 spitfire at least - see pic...
    Attached Thumbnails Attached Thumbnails 2017 Banshee bikes: News, rumours, speculation etc-image.jpg
    "its bigger brother the Banshee Dune"
    Hard funkin´ Kraut
    May 2005
    Shorter seat-tube, steeper effective seat angle, slightly lighter - sounds all good for the MY17 Spitfire. I heavily think I´m in for a new frame next year!
    Looking forward to the new dropout-design. I think the "reduced" two-positions are contributed to the majority of riders using neutral or slack ... ?!?
    smartass
    Reputation: amish_matt's Avatar
    Yeah, sounds all good so far. I just hope they added a bit of length to the reach and TT as well, especially considering the steeper SA.
    Agreed on the two geometry positions, doesn't seem like many riders use the steep setting (I know I never have).
    I also hope "Boost compatible" dropouts mean they can be either Boost or non-Boost.
    Hard funkin´ Kraut
    May 2005
    I´m pretty much sure that Banshee will keep the philosophy of giving their customers options on how they want to build up their bikes. So, the boost-dropouts will be additional to the already existing ones, I bet ...
    Not sure if there will be a longer effective top tube - the reach and wheelbase will be slightly longer with a steeper seat tube and the current top tube. We will see ...
    Nucking Futs
    Reputation: Sneeck's Avatar
    What a nice feature would be is to go postmount on the dropout. Every other decent frame has allready a postmount support so why not do that.
    Also any tweaking of the linkage axles to prevent them from wearing stuff out? Set screws, stronger bolts for more tightness and better locktite would be my best guess of preventing this issue.
    Really interrested to see what the '17 Darkside will do, or if a new model is going to be released. Still shredding the first gen. Scythe but like my first gen. Spitfire the suspension stuff is getting old and out dated (blew the dhx in winterberg last sunday, doh!) If you can shave 200 grams on the spitty you could save 300? on the darkside, wouldn't be bad at all.
    Amplify Your ®ide!
    Spitfire Amp Scythe
    MTB B'dos
    Reputation: LyNx's Avatar
    Well, hoping they don't mess with the STA on the Phantom, it's already too steep for me, have to use a setback post to get the saddle where I like it. Shorter ST lengths (Paradox for sure) and maybe a tad more Reach on all and slacker HTA on the Paradox with Boost or 150 spacing/clearance to accommodate PLUS tyres. Have always said it, love the replaceable drop outs, makes Banshees very future proof without needing to spend a ton of cash.
    Reputation: dirtrider76's Avatar
    Sep 2012
    Agreed the ST on my Paradox is way longer than it needs to be!
    I like to fart when I'm in front of you on a climb
    As 2017 is near launch and 2018 designs are likely done and dusted, I suppose this comment would likely be for 2019...
    ...I will leave it to those who are much smarter than I on how to best actuate a change, but the handlebar drop from seat level on the Rune is significant. I could be on a size too small (6'2", 36" inseam, on a size Large V2). Even so, with L and XL in general, I think the very small headtube really makes for a significant drop. I currently have 1.5" below the stem to the bearing, a higher rise handlebar, and my seat is easily 5" above my bar.
    Although I really liked the slammed stem on headset look on bikes, when it comes to actually riding one, it doesn't work for me.
    Sep 2012
    Quote Originally Posted by jason3559 View Post
    I trail and park ride a L Rune and had 35mm of spacer under the stem with 20mm riser bars. Even on my other XL trail bike which is much longer I have a 30mm of spacers and 20mm bars. For taller guys I almost always see a stack above the headset even on long frames UNLESS they have a retarded long head tube which looks horrible and give you no option to lower the bars.
    I'm hoping mostly the new Rune is longer and isn't a press fit BB
    Yup, 6'2" here on a 2013 XL Spitfire, with an inch of spacers. I think they can grow the head tubes (on the XL for sure) a bit.
    Quote Originally Posted by NoStyle View Post
    I agree with everythin you said. 200 grams off the frame will basically kill the "Spitfire is heavy" argument you hear from all the alloy shredders out there.
    Shorter seat-tube would likely let me get away with a 150mm dropper instead of 125mm.
    Metric shock sizing I wonder?
    Long live Banshee bikes.
    I really hope they go metric shocks, just to make it more future proof, this is the only thing holding me back on pre order, lighter weight is bonus for me personally, just as long as they still keep it bomb proof, as i have no intention on moving up to the rune, really itching on getting a new banshee, hope they put out a little teaser as i figured they are probably done with the first batch of production, wink wink,
    ^^^^ That's a good point about metric. I guess if the shock guys are eventually going that route and that route only. For the foreseeable future I imagine a killer 7.875 shock will be made though. I guess I'm indifferent, probably wouldn't sway me one way or the other.
    Braaap
    Reputation: DirtMerchantBicycles's Avatar
    May 2014
    The only available metric shocks at the moment are from SRAM. I'll pass on metric for the time being.
    Dirt Merchant Bicycles
    Providing unrivaled support and unbeatable pricing on all cycling goods to riders near and far.
    i've always liked that Banshee bikes designer have always had the foresight on their design, which makes our bikes less likely to be obsolete to soon, designing towards metric shocks in my opinion is one of them.
    my dream spitfire would be metric shocks and 157x12 compatible rear, hehehe
    We are keeping a cose eye on Metric, but will not be switching this year, as there is still limited avaliability of shock options for customers, while non metric standards will still be around for years to come.
    Banshee Blog
    Reputation: schnee's Avatar
    I'm really looking forward to the 2017 models.
    The Prime is all gone all over Europe, and it's time to replace my Niner.
    Yamaguchi Cross • YT Jeffsy • Salsa Mukluk & Vaya • Canyon Commuter
    that new cane creek coil is going to be perfect for the lighter spitfire,
    i heard the new they lengthened all the new frames,
    i feel almost perfect on the small spitifire with 40mm stem and 780 bars,
    i hope it doesn'y get to long for small riders
    Sep 2014
    Yeah new Spitfire with the new DBCIL would be awesome...!
    some know me as mongo
    Lenghten the Prime? It already is long bike in every aspect! Though I love mine, I certainly wouldnt want it longer in toptube/reach/wheelbase.
    3000 mile goal for 2018
    3402.7 miles ridden in 2017
    3028.4 miles ridden in 2016
    So with one week away until Eurobike, what's everyone's prediction for MY17?
    Here's mine:
    - Banshee Rune will go Super Enduro, 170mm of travel both front and back.
    - Exchangeable dropouts remain, providing support for new Boost Standard and such
    - chainstay length shrinks ~10 mm
    - no front derailleur support anymore
    - finally raw color option again!
    Keep 'em coming
    Apr 2014
    If they bring back the Spitfire in the '14 blue I will make Keith breakfast in bed every Sunday for a year.
    Desperate to order a new bike/frame but waiting to see what Banshee have to offer next week.
    upload img
    i'll settle for this color scheme complete with badge,
    or get an anodized one because i'm crap at keeping it for getting way too may paint chips and scratches,
    MTB B'dos
    Yeah, I loved my Polished/Orange V1 Paradox, really would be sweet if they brought back the Dual/Split colourways
    Quote Originally Posted by zuman View Post
    2017 Banshee bikes: News, rumours, speculation etc-p1060538_fb.jpg
    Reputation: filbike's Avatar
    Chiming for Keith.
    I have to build new wheels for my prime and in order to keep'em up to date and compatible for future frames I'd like to know if v2 boost dropouts will ever be made, and in case, reasonably soon available ?
    MTB B'dos
    I heard they're in the works right now, but why not just go 150x12 instead, absolutely dishless, strong wheel, great chainline, works excellent with 73mm BB
    Quote Originally Posted by filbike View Post
    Chiming for Keith.
    It's just for future frame compatibility,and possibility to swap wheels.
    .....the world is insanely going boost direction.....I'd have gladly used 150x12
    Here, diagonally!
    Reputation: JACKL's Avatar
    I'm with Lynx on this one, since the frame has room for 150mm, that is the best way to go if building a wheel. That's the route I went, and I won't be going back.
    However if you have a Boost wheelset or hubs laying around, I can see where boost dropouts would be a benefit. From a marketing perspective, it might bring in a few new buyers if they are looking for a Boost frame.
    i'm guessing that 150 would require more material added to the frame to accommodate it, thus adding more material and weight to the trail bikes.
    there is a very fine balance between strengths/durability versus weight saving that us alum lovers need to have in check,
    give me a bike that i can chuck away when i have to bale out and not to worry too much if my spitfire can take it.
    MTB B'dos
    Have you even closely looked at your Spitfire, there are no mods needing to be done to run any of the various axle widths with the replaceable drop outs, the frames are made so that all are just bolt on and go, i.e. stays are wide enough and strong enough and the actual 150x12 drop outs weigh no more than the 142x12 or 135x10 drop outs, not in my hand. Only place you will gain a very small amount of weight is in the hub itself as that is wider than the narrower options.
    Quote Originally Posted by JACKL View Post
    I don't have boost wheel set (yet) but I think I'll pull the trigger on a boost front susp. frame, and I'd like to swap its plus wheels with Prime.
    Here comes the need of boost wheels...... I'd gladly stuck with 142x12
    Also when (read if) I'll change the Prime, the new frame will be quite surely boost, cause this the market will offer.
    just considering if new dropouts will increase chainstay length (27.5 style). Would be nice to have 26"length boost dropouts.
    Hard funkin´ Kraut
    May 2005
    Chiming for Keith.
    I would keep patience, as Eurobike will happen in a few days. All infos will released then.
    So far the MY17 (and following) dropouts seem to have 2-position geo-adjustment vs the 3-position of the current. I would wait how Banshee will come out with the new dropout-desingn and their compability to older frames.
    Apart from that, if I were you I would keep the 142x12 or go with the 150x12.
    nonsense to go 150 for future frame compatibility. Sure I'll wait news, just hope they'll be older frames frendly.
    Apr 2015
    Eurobike is on, cannot find any Banshee news, anyone that has?
    Quote Originally Posted by CastorTroll View Post
    ...........feverishly checking MTBR every 10 minutes...........
    Can't wait for goods to drool over!
    You too ?!!?!!
    Envoyé de mon iPhone en utilisant Tapatalk
    Apr 2014
    And me.
    Got all excited when I noticed this thread had new replies.
    Reputation: Andrewslice's Avatar
    Nov 2015
    Legend and Darkside looks pretty similar to this years lineup
    And where is the Spitfire ??
    Nov 2015
    @Samos these are not my pictures, just found them in the Internet. I'm also very curious about the spitfire. Hope for pictures soon
    Sep 2012
    I can't take it, I need to see the new Rune!!!
    Can see Prime in foreground and rune and spitfire in background here:
    https://www.instagram.com/p/BJx5su2gJq6/
    Apr 2014
    Maxle rear end and the webbing where a few have cracked on the seat tube/down tube has gone.
    Need to see more colours.
    Note: 2017 Rune and Spitfire on first page!
    Reputation: bigcrs's Avatar
    The 29ers look outstanding. I'm itching for info on the Prime!
    Reputation: Junersun's Avatar
    Jun 2014
    Love the new colors!
    Current Bikes
    2018 Santa Cruz Chameleon 27+
    2016 YT Tues AL
    2016 Banshee Rune
    MTB B'dos
    Would love to see some close ups of the new hydro formed tubing, curious how much different it is and how much weight it helped save. I'd love to give an XL Phantom a go with a 50mm stem and greater sweep bar to my Large with 70mmstem and 8 degree sweep bar, but will have to wait and see.
    Braaap
    May 2014
    Looks good! I spy a DT Swiss axle on the Spitty...sure would be nice if they were included as standard.
    Sep 2012
    Quote Originally Posted by bluearsedfly View Post
    My current 13 is cracked on the seat tube under the lower link mount. I'm hoping this was addressed as I know I've seen pictures of others cracked at the same spot. It looks the same though minus the gusset in front.
    I broke 2 of those original Maxle type axles, replaced it with a Rockshox maxle no failures
    I hope there is more colors to choose from, I'm not crazy about the yellow/orange colorway at all.
    Yeah this almost exactly.
    Off the back...
    Reputation: pinkrobe's Avatar
    More Prime please! Any signs of Boost rear ends?
    @pinkrobeyyc
    #pinkrobeyyc
    Sep 2012
    So as I pedaled away on the trainer tonight and my Rune sat right in front of me I pulled up the first page of the yellow/orange Rune. There's a bunch of subtle differences that don't stand out right away. This is what I noticed just from 1 picture.
    Top tube is totally different and upper gusset is slimmed down a bit.
    Seat tube appears to be a bit shorter.
    Front shock mount is different and looks to have some weight trimmed out of it.
    BB gusset to downtube gusset is gone.
    Bottom tube appears to be formed more but hard to tell for sure in picture.
    Rear triangle is different, its been slimmed down a bunch around the new drop out and looks to have more clearance by the derailleur.
    New rear drop out looks to be much smaller.
    I'm pretty stoked on it as of now. I wish I knew if my drop outs will fit or I need to buy new ones.
    May 2015
    New top tube with hydrofrormed gusset, new down tube that is formed at the bottom to reduce the need for the lower gusset, new lighter dropouts including boost 26"
    Seat tubes are 31.6 and lower for longer posts, seat angles steeper and reach increased on most frames too.
    They look sick!
    May 2013
    Quote Originally Posted by pedalsbikecare View Post
    They look sick!
    Please any information if the Prime is changed, too.
    May 2015
    From memory pretty sure all of the above
    Exact details out soon
    MTB B'dos
    To put it bluntly FVCK, exactly what I was hoping would not happen. ST on the FS are already too steep for me and already have my 30.9 dropper, can't say I think shimming is a great idea for them.
    They look sick!
    Shame on Banshee for not listening to you! Ha. Kidding/not kidding.
    But really it does bum out my wallet a bit about the seat post size change but if Keith thinks you gotta up diameter for more exposed post then I kinda believe him....
    Overall I'm kinda meh about the new frames right now not sure why. Guess we need more and better photos!!! And a full list of changes with numbers can't wait.
    May 2013
    To steep? How steep is your ST? I don't think shimming is a problem, have a 30.9 dropper too, but it's not a deal braker. Specialized shims the 2017 S-Works Enduro 29...
  67. #67
    Nope, this is from last year !!!!
  68. #68
    Quote Originally Posted by Samos View Post
    **** lol!
  69. #69
    MTB B'dos
    I run my Phantom in the steep setting, which has an ESTA of somewhere around 75-76 degrees, but I run a longer fork, so drops down to somewhere around 74 degrees and I like it around 72.5 degrees, so already using a setback head on my post. I guess not lots of people like to do anything but pedal up and bomb down, me, I like to do lots of flat/rolling stuff which requires lots of pedaling and those who don't complain generally run the chips in the slack setting.
    Quote Originally Posted by jack_steel View Post
  70. #70
    Sep 2012
    Is the reason for going to a larger seat post diameter strength at the link mount/seat tube junction or support for a longer seat post with a shorter seat tube? I'm kind of bummed about the seat post diameter change. A shim from 31.6 to 30.9 is really thin, the 34.9-30.9 shim on my other bike is 120mm long and totally trusyworthy.
  71. #71
    Hot damn! The Prime and Phantom look pretty damn nice to me. I need some frame weight and geometry numbers!
  72. #72
    Feb 2014
    They all seem like logical changes - if you don't like them, keep riding your old Banshee! I'm v happy with my 2014 Spitfire so see no reason to replace it.
    The Spitfire's down tube looks larger near the BB - combine that with the larger seat tube and I suspect that's a good part of the additional strength needed to do away with that gusset.
    The larger seat tube makes sense with the huge dropper posts that are becoming common, both so the dropper has more space for internals and to cope with the leverage it's exerting. A shorter seat tube allows riders to run bigger droppers which so definitely a good thing (I'm liking my new 170mm Reverb a lot!)
    The new dropouts look lighter. A steeper seat tube angle will be preferred by most riders, especially as a lot of Spitfire owners run a 160mm 27.5 fork which slackens the whole bike.
  73. #73
    Sep 2012
    Quote Originally Posted by threehats View Post
    Umm I cant it cracked at the seat tube/upper link mount
    I actually dig the changes mostly TBH, I just really didn't plan on having to buy new drop outs and a dropper.
  74. #74
    Feb 2014
    Plenty of 30.9 to 31.6 shims available and you can change the outer tube on quite a few droppers when servicing them
  75. #75
    Sep 2012
    I suppose that's really up to Banshee, lots of companies wont warranty a frame with a seat post spacer used IIRC. I wonder if Syntace makes one like the one in my other bike?
  76. #76
    vko
    vko is online now
    May 2013
    2017 Banshee bikes: News, rumours, speculation etc-14222146_1114215431949615_2376929079491052425_n.png
  77. #77
    Apr 2014
    Are those numbers for the spitfire? ^^^
    Any idea on other colours yet?
  78. #78
    Sep 2012
    Has to be 27.5/26 and shorter shock than the Rune.
  79. #79
    gosh!!!!!! good news for boost dropouts (26 & 27,5).....hoping for compatibility with older models...... c'mon Keith unzip your mouth.
    ...also see no PM caliper mount:
    P.S. where did you find this porn vko?
  80. #80
    vko
    vko is online now
    May 2013
    same shock different bushing size
    voila
    2017 Banshee bikes: News, rumours, speculation etc-14192036_1114215408616284_2347486130019525934_n.png
  81. #81
    Braaap
    May 2014
    Such anticipation!
    Peep our Facebook for answers
  82. #82
    Raw is back for the Rune!
  83. #83
    Prime updates are looking good for a switch from the 2013 Spitfire. Not impressed with the colors schemes though. Ongoing issue with Banshee, crap shoot.
  84. #84
    Dec 2015
    Not super relevant but I just came up with a new marketing campaign:
    2017 Spitfire- the Reginald Denny of bikes. Not even a brick to the head can keep this girl from truckin'.
    Edited for PC
    Banshee Bikes
    Slaphead Legion
    Wachusett Brewery
  85. #85
    Off the back...
    2017 Prime:
    2017 Banshee bikes: News, rumours, speculation etc-14188555_1212661325420694_1407444236105041822_o.jpg
    @pinkrobeyyc
    #pinkrobeyyc
  86. #86
    Quote Originally Posted by pinkrobe View Post
    2017 Prime:
    Dude! Where that come from? Spitty content pleeeeease!
  87. #87
    So far so good with the Prime. Just need some numbers for comparison. I wonder if its still cleared for a 160mm fork.
  88. #88
    Jul 2016
    Someone on the forum put up a link to the full details but then deleted it (think it was a dealer) - but here it is: https://www.dropbox.com/s/xx5jknplhy...20web.pdf?dl=0
  89. #89
    Jun 2014
    Dope. Thanks!
    Current Bikes
    2016 YT Tues AL
    2016 Banshee Rune
  90. #90
    Did anyone see that last custom painted dh rig by Peaty? i think banshee missed the opportunity of doing the same for their spitfire. I'm designing a copy of that decals to put on my bike.
  91. #91
    Jun 2014
    I wonder if those dropouts can fit on our current setup. Looking for a little shorter chainstay on my 650b rune....
    Current Bikes
    2016 YT Tues AL
    2016 Banshee Rune
  92. #92
    Sep 2012
    Quote Originally Posted by Junersun View Post
    If your running in the slack setting you can probably clear a 27.5 tire unless its really tall in the 26" drop out. What tire are you running? I can check clearance on mine if you want since I cant ride.
  93. #93
    Jun 2014
    Easton arc 30s with maxxis dhr2 wide. Thanks!
    Current Bikes
    2016 YT Tues AL
    2016 Banshee Rune
  94. #94
    Sep 2012
  95. #95
    Jun 2014
    Wow almost a pound off the weight of the frame is HuGe!
    Current Bikes
    2016 YT Tues AL
    2016 Banshee Rune
  96. #96
    Jun 2016
    Quote Originally Posted by dirtrider76 View Post
    I ran a 27.5 Schwalbe something, 2.4 Hans Dampf from memory, in my 26 dropouts. Could only get clearance in the slack setting.
  97. #97
    Sep 2012
    Yeah it will only work in slack, I know I tried a 27.5x2.4 Mavic Charge but it was rubbing and it dwarfs everything else I've ever run. IIRC I had a Roam, Slaughter and something else in mine.
  98. #98
    Jun 2014
    Interesting... Sorry this forum is for 2017 so I'll go to the rune build for more questions!
    Current Bikes
    2016 YT Tues AL
    2016 Banshee Rune
  99. #99
    May 2013
    They will not fit. Got that information a week ago from a banshee dealer.
  100. #100
    vko
    vko is online now
    May 2013
    Can anyone confirm that?
    How about stiffness ?
  1. GT 2017 Range - News
    By KarapA in forum GT
    Last Post: 07-22-2016, 06:44 PM
  2. 2017 Trek bikes?
    By kansasbike in forum Trek
    Last Post: 06-22-2016, 07:36 PM
  3. 2017 Enduro (29) Mk2 Speculation
    By tehllama in forum Specialized
    Last Post: 06-02-2016, 09:52 AM
  4. Kona Process bikes 2015 - rumours
    By Prestige in forum Kona
    Last Post: 03-24-2015, 05:28 PM
  5. rumours on new Bikes 2014
    By flowbike in forum Transition Bikes
    Last Post: 09-27-2013, 05:42 PM
Members who have read this thread: 98
