Results 1 to 18 of 18
    2013 Spitfire and Reverb stealth
    Is it possible to route the cable from a Rock Shox Reverb stealth out of the seat tube where the tube ends above the lower pivot? If there is a way out of the seat tube that way I think it would be possible to route the cable underneath the bottom bracket. At least if no front der. is mounted.
    I have not received my frame yet, so I can't se for myself!
    Any comments?
    Hard funkin´ Kraut
    Reputation: NoStyle's Avatar
    May 2005
    Runes, Primes and Spitfires doesn´t have that Hole for Reverb Stealth. I have heard that this Hole is allowed to drill without Warranty-Issues - when it´s done professionally!!! Please ask the Banshee-Guys if you are allowed and where to drill.
    Reputation: rocketfuel's Avatar
    Is there anyone that has done this or should I try to source a KS Lev?
    351 views, looks like quite a few people who want to drill a hole in their new frame :-)
    Any update with the 'stealth hole'?
    Hard funkin´ Kraut
    May 2005
    Yes, the 2014er Primes, Runes and Spitfires do have them. For the 2013ers you have to DIY, see Post 2.
    Jan 2013
    Is this a modified 2013 or a 2014??
    Cable routing looks mega....
    Reputation: darkslide18's Avatar
    Quote Originally Posted by b15mo View Post
    Awesome! All I need to know is how you had this done? And can I do it to my 2013 Rune without affecting the warranty?
    I wonder if Builttoride would chime in on this for verification?
    Oct 2011
    I just installed the Reverb Stealth on my 2013 Rune. Dennis at Banshee gave me some great advice. There's a pre-existing hole in the frame if you look in the lower pivot box just above your BB. It's really tricky to see but if you shine a light down the seat-tube it helps to see it. I ran the Stealth cable down the seat-tube, through the hole, staying underneath the lower axle/yoke, around the bottom of the BB and up the lower frame tube using the front derailleur mounts (I run 1x10). I removed my cranks, chainguide and the lower axle to feed the stealth cable through. It's a tight fit when you re-install the axle/yoke but the stealth cable isn't squished. Maybe not ideal but the benefit of the Stealth was worth it to me and it's been working great.
    Oct 2011
    cable routing for the stealth
    Attached Thumbnails Attached Thumbnails 2013 Spitfire and Reverb stealth-stealth.jpg
    clever!
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    Thats cool. I wonder if it would work with the KS Lev integra, or if the cable housing bend would be too tight.
    Reputation: LP88's Avatar
    Sep 2013
    Any longevity issues with the Reverb Stealth since installing Ryan? I love this idea!
    Cheers
    Oct 2011
    Hey there LP88...no issues with the set-up. It seemed like a tight bend around the BB when I installed but that hasn't caused any problems and the Stealth has worked great since installation. It's a pretty clean set-up if you go for it.
    Reputation: filbike's Avatar
    it seems there's no rubber sealing/protection around hole.
    I'd have expected proper rubber or plastic fitting.
    Attached Thumbnails Attached Thumbnails 2013 Spitfire and Reverb stealth-p4pb9670885.jpg
    Quote Originally Posted by Ryan_nf View Post
    What's about the Reverb Stealth in the Spitty ? Do you had any problem since then ?
    Envoyé de mon iPad en utilisant Tapatalk
    Nobody to answer ?
  1. Reverb Stealth and The One
    By TheRage43 in forum Canfield
    Last Post: 10-26-2012, 11:04 AM
  2. Reverb Stealth?
    By iRider in forum Intense
    Last Post: 08-11-2012, 09:24 PM
  3. Stealth Reverb on a Chilcotin
    By geo025 in forum Knolly
    Last Post: 06-03-2012, 12:12 PM
  4. Looking for someone with a Reverb Stealth!!!
    By hardtailkid in forum Scott Sports
    Last Post: 02-06-2012, 04:58 PM
  5. 'Stealth' Reverb?
    By Eric. in forum SRAM
    Last Post: 02-11-2011, 09:57 PM
Members who have read this thread: 4
